Question about Hotpoint 24 in. DWF32P Free-standing Dishwasher
Hotpoint aquarius dwf30 dishwasher
My hotpoint aquarius dwf30 dishwasher is washing with cold water its not heating up i have been told it may be the element.What is to stop me plumbing it in to the hot supply under my sink.
Hope you can help Lee
  • milvy1 Jul 09, 2008
    my hotpoint aquarius dwf30 dishwasher is washing with cold water its not heating up i have been told it may be the element.
  • 1,462 Answers
You can plumb into hot but there are some snags
first hot water pressure is often a lot lower than cold so the machine may take a long time to fill
second if the water is too hot it will destroy the resin of the water softener and you will see brown marks on the crockery.
third it a bit uneconomical as you will use a lot of hot water
Posted on Jun 25, 2008
Hotpoint aquarius will not heat water
Although I do not know your particular machine I strongly suspect that the heater element is malfunctioning/broken. Even if it is a hot and cold fill it still requires the element to heat the water up to the correct temperature for the selected wash. If it is cold fill only it certainly needs the element all of the time- apart from rinses!
Sorry but it depends now on who you have at hand to repair as to your next step.
John C
Feb 09, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint dishwasher dwf30 washing as normal but no heat
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Oct 24, 2010 | Dishwashers
My hotpoint aquarius dwf30 will not drain so will not wash...
Do you hear the motor run or is there deadly silence when you select drain.
Does the wash cycle start - do you hear water getting in and washer arms move?
Are there any lights flashing?
Jul 06, 2010 | Hotpoint 24 in. DWF32P Free-standing...
Where is the element on a Hotpoint Aquarius dwf30 dishwasher?
It sits in the base of the machine and you would need to remove the complete top section of the dishwasher to gain access to it, which involves removing the door first, then the balance weight and finaly the stainless steel top section
Mar 17, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hi i have a dwf30 for some reason all the items are coming out with lots of grease marks on them the tablet pops out ok as you can hear it but everything seems as if its not been rinsed out i thought it...
is there any strange rumbling or moaning coming from the drum ??? if so the oil and greace may be from the back bearing due to the bearing oil seal becoming faulty allowing water through to the bearings
Feb 08, 2010 | Hotpoint Aquarius WD640 Front Load...
Does it use cold water to wash then heat it up
Yes that is correct, as all washers are now cold fill only, they incorporate a heating element to heat the water,unless of course it has a cold wash programme only.
Hope this helps.
Jan 30, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hot point aquarius 1100 - does this have a heating element for cold water feed ? or does is need direct hot water feed ? (there is a inlet at back for both hot and cold so presume no heating element ?)
All Hotpoint washers have heater element regardless of whether they are cold fill only, or hot and cold fill.
if 2 connections at rear, then it is hot and cold fill, if only 1 connection, then it is cold fill only.
Please rate my solution.
Jul 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Dishwasher Hotpoint 7885 Aquarius Ultra Plus
sounds like the heater for sure. engineer job.
Jan 25, 2009 | Hotpoint Aquarius WD640 Front Load...
Washing m/c water not heating up.
Make sure the economy button is not selected if it has one, as this bypasses the heater..
you say you have had element checked and seems o/k, to be certain it is o/k then test with a meter when it is on heat stage in the prog, and make sure you have a 240V reading across the heater terminals, if you have and it does not heat, then the element is faulty.
Plz rate my solution.
Dec 23, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius Dishwasher DWF31
Jan 03, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint 24 in. DWF32P Free-standing Dishwasher Logo
1,693 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
