Question about Hitachi 61UWX10B 61" Rear Projection Television
Hitachi 61UDX10B My tv will not turn on it just blinks a red light on front and has a clicking noise with it. No picture and no sound. I have unpluged the cord and that still has not solved the problem. Is there a reset button on it somewhere. hitachi 61UDX10B replaced stk392-110 with stk392-150 went to do a manual DCAM.after a few minutes trying to do the manual DCAM tv shut off red blinking light on front panel and 1 red light on in the back of the middle internal board and 2 green blinking lights and 1 green light thats on. all on the same middle board.
  • Anonymous May 23, 2008
    hi have the same problem with my Hitachi 43uwx10b ic and resistors has ben replaced flashing red light no power if any one can help please
  • baberuth55 May 27, 2008
    Hitachi tv that will not come on and no sound. I don't have the original remote. bought tv from someone .
  • Hitachi Master
  • 8,617 Answers
I would check for burnt resistors as the 150s are interchangeable with the 110s however in alot of hitachis I have seen resistors blow after upgradeing to the higher wattage ICs. I Usually switch out the convergence resistors whenever I go to a higher wattage IC just to be sure. If you need more help let me know.
Posted on May 18, 2008
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: hitachi 61udx10b
Check the resistors near the Ics especially the 3.9 ohm 1 watt resistors often one or two will be open then when you install the higher wattage Ics which run cooler you can actually wipe out all the convergence resistors which are 3.9 2.7 and 4.7 ohm 1 watt resistors
Posted on May 20, 2008
No picture, sound or fan noise
Call the maker of the television and ask for common problems, check their web site or goggle it for others with the same problem. Let me know what it is.
Cynthia
Feb 01, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
Hitachi 53uwx10ba turns on & off when off red flashing light/clic
Same problem. Replaced both convergence ICs about 5 months ago. Worked fince since then and just recently no sound, no video, blinking red on front panel and clicking sound. I suspect that the ICs went bad again and blew a resistor or two. I used cheap Chinese ICs instead of the Sanyo ones and thing this is why. I'll be looking at it again and post solution.
Jan 21, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Hitachi 61udx10b
Replace Both of your STK ICs they are your convergence ics they are big black ICs will have Part# on them for example STK392-110, if they are 110s use 180s, if 020s use 040s other wise replace with exact same number. To get Parts call Electronix 1-800-223-3205
Dec 30, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 55FX20B 55 in. Rear Projection - no picture or sound
TV always has high voltage shock risk while repair. As you said you are not familiar with TV repair so better to handle repair person this issue.
Oct 01, 2008 | Hitachi 55FX20B 55" Rear Projection...
Hitachi Plasma TV model P50H401
I think you have problems with the digital main PWB.
If the power PWB failed, turn off and change the pilot ligth to red.
Aug 31, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi 61UDX10B
[BRAND SPECIFIC][TOSHIBA][QUICK FIXES]
Flashing LED
<< Back to Quick Fixes Page
If your set all of a sudden won't come on, e.g., the screen is blank, but the LED on the under the screen next to the on/off switch keeps flashing, then there may be an internal fault on the set that needs to be reset.
To force the reset, try this:
  • Unplug the set and wait a few seconds
  • Replug and see if the video returns
Whenever the set senses an internal fault through its monitoring circuitry, it essentially shuts down the set. The flashing LED provides the indication that a fault has been detected. Removing power to the set resets the monitoring circuitry. When plugged back in, the circuitry again does a check of the system. If it finds that there truly is a problem, then the set is shut down and the LED will again flash.
Jan 22, 2008 | Hitachi 61UWX10B 61" Rear Projection...
Hitachi 61UWX10B 61" Rear Projection Television Logo
291 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
