Question about Panasonic KX-FHD331 Plain Paper Thermal transfer Fax
Change from letter to A4
This fax only works with letter size paper. How can I change internal settings so that it will work also with A4 without printing a nasty message that this machine is designed only for letter sized paper?
    Genius:
  • 2,120 Answers
No can do!
You need a metric fax machine.
Posted on Oct 06, 2008
How to put the paper in the printer?
Loading Paper
1 Adjust the guides to the position for the paper size you are using.
2 Fan the paper well.
Push down the paper lever. Load the paper (with the lever down). Make sure the print side is toward the fax machine and the paper level is stacked below the paper mark. The feeder can hold up to 200 sheets of paper, or up to 10
envelopes.
Acceptable Paper
The FAX/MFC can handle paper that has the following specifications.
But please note that you can receive fax messages only on Letter, Legal and A4 paper. If you use legal or A4, change the Paper Size setting: (Menu/Set, 1, 1.)
Paper Type Paper Size
Cut sheet Letter, A4, Legal, B5, A5, Executive,
Custom size 2.75-8.5 × 5-14 inches (70-216 × 127-356 mm)
Envelopes DL, C5, COM-10, Monarch
Post Card 2.75-8.5 × 5-11 inches (70-216 × 127-279 mm)
Organizer Day-Timer® J, K, L, M 2.75-8.5 × 5-11 inches (70-216 × 127-279 mm)
Labels and Transparencies 2.75-8.5 × 5-14 inches (70-216 × 127-356 mm)
Dec 20, 2010 | Brother IntelliFAX 3800 Plain Paper Laser...
WHAT DOES LOAD CASSETTE PAPER CODE A4 ERROR ON A CANON MF3240 . WHAT DOES THIS MEAN? THANK YOU
I talked to tech support at Canon, and he explained that the document I was trying to print was originally scanned with an A4 paper size, and my printed is set to Letter paper size, thus producing the error code. A simple solution is to "uncheck" the box that says "choose paper source by PDF page size". It worked!!
Jan 18, 2010 | Canon Office Equipment & Supplies
Can't send or receive faxes after fixing error code problem
your printer CHANGE PAPER TO
A4/LTR/LGL PLAIN
The paper size setting is set to a size other than
A4, letter or legal in fax receive mode.
The paper type setting is set to a type other than
PLAIN in fax receive mode.
Set the paper size setting to A4, letter or
legal and load paper of the same size.
Set the paper type setting to PLAIN.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon pixma mp 780 message says:change paper to A4/letter/legal plain How do I do that??????
Go to Printer and Faxes in Control Panel, Right click on the printer for which you want to change the settings. click properties, go to printing preferences there look for paper size and select A4 or letter/legal as per your choice
Oct 01, 2009 | Canon Office Equipment & Supplies
How do I change the default paper size from Letter to A4 in my HP Officejet Pro 8500 Wireless?
Don't set by using the "Print" option.
Go to [Start]
[Printers and Faxes]
right-click on the HP Printer entry
! Don't select "Printing Preferences"! from there
Select [properties]
Select [Advanced] tab
Select [Printing Defaults]
[Advanced}
(I know, the screen looks the same, but it functions differently this way)
Change paper size to "Letter"
[OK, OK, OK]
*done*
Sep 25, 2009 | Office Equipment & Supplies
Whenever i change paper size from A4 to letter,
Go to [Start]
right-click on the HP printer entry
Select [properties]
[Advanced}
[OK, OK, OK]
*done*
Sep 25, 2009 | HP LaserJet 4350 Printer
Pc load letter
Hi there this issue is caused by your driver defaulting to letter and a4 paper being used set your default paper size to a4 in the driver and also set tray to a4 this should cure the problem Regards AL "alstech"
May 28, 2009 | HP LaserJet 4 plus Printer
Problem printing on matte photo paper
no thats why it is not working the right way you have to use the semi gloss paper thats what it requiers
Jan 03, 2009 | Brother MFC-3240C All-In-One InkJet...
When I print my letter, I set my defaults on my computer with Letter size. But pn the printer, I can't figure out how to change the cassette from A4 to letter. It's driving me crazy. Please help me default...
Go through the following
Start=Settings=printers and faxes=right click on the isatalled printer=printing preferences=change paper size from A4 to Letter. This will now remain as default.
Regards,
Manoj Joseph
+91 9352008418
Jun 18, 2008 | Canon Office Equipment & Supplies
Brother MFC6800 not printing
To answer more effectively - how is the printer connected to the iMac? Is it a USB connection, a printer cable, is the MFC 6800 connected to a print server, an AirPor, etc? A second question I have is if you are trying any kind of tricky printing such as manualduplex printing.
Also, a shot in the dark...Is the Auto Reduction set to on or off? To check:
1. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 4 (Auto Reduction).
2. Press the up or down navigation key (keys located above and below the
MENU/SET key) until the display shows "Reduction: ON?".
3. Press MENU/SET.
4. Press STOP/EXIT.
Another item to keep in mind:
You can use three sizes of paper for printing your faxes and
copies---letter, legal and A4. When you change the size of paper you ha
ve loaded in the Brother machine, you need to change the setting for the paper size so your Brother machine can fit the incoming
fax on the page. To set the Paper Size:
1. Press MENU/SET, 1 (General Setup), then 1 (Paper Size).
2. Press the up or down navigation key to select LETTER, LEGAL, or A4.
3. Press MENU/SET.
4. Press STOP/EXIT.
Nov 20, 2007 | Brother MFC 6800 All-In-One Laser Printer
Panasonic KX-FHD331 Plain Paper Thermal transfer Fax Logo
101 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
