Question about Philips 27PT6441 27" TV
Trouble with philps tv
Getting triple images and triple colors on screen, how to solve this problem?
  • 30 Answers
First check to see if all cables and settings are correct according to the manual, if not it could be a bad board inside the set that costs $180.00 to replacce
Posted on Jul 25, 2008
Horizontal line about 1 from bottom of picture
The t con board or LCD panel of the tv is faulty. Can confirm by replacing the t con board.
If you wish to get some details; check the site linked here. Pull up older posts.
Apr 13, 2016 | Samsung Ln32d403 32-inch 720p 60hz Lcd...
The picture started getting a triple image (everything was outlined in blue and yellow). We had a board replaced by a tv repair service, over $300 and the tv was ok for about 80 hours. (warranty on new...
Ur tv convergence board that was replaced for ur tv.The 2 STK convergence ICS was old it is not new it is those 2 STK convergence ICS on the tv convegence board is dead again and some of the resistors on the board maybe shorted and dies also must replaced too.The tv convegence board was put on ur tv those parts on the convergence board are old components parts,ur must repair tv convergence board again to fixed this problems called convergence pictures problems.
Aug 22, 2011 | Mitsubishi VS-60609 60" Rear Projection...
I have a Hitachi ultravision digital Hd Tv(Model: 43UWXtenB V2A04one295) which shows double or triple color images at the same time. How can I fix this easily ? Thanks for any advices. Sound speaker is...
This tv problems u can't fix it easily,u must take the tv aparts and change an electronic board that call the T-CON board to fixed this problems.If this problems double or triple images not causes by U or an objects by outer forces hitting the LCD screen panel itself,if yes this problems causes by U or an objects by outer forces hitting LCD screen panel itself.This tv problems can't not be repair,because the LCD screen panel itself it is dead and damages leaking radiation,if got hit by an outer forces,if screen damages by outer forces,this tv only can used as salvage tv for it electronic circuit boards for other tvs for as parts only now,because if the tv require a new LCD screen panel will cost the same as a new tv.This T-CON board sit at the bottom in the middle of the tv LCD screen panel.Tries websites like, to buy an refurbish T-CON board for the replacement.
Jul 28, 2011 | Hitachi ULTRAVISION L42V651 42 in. LCD...
Seeing triple images of everything
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignmenents,have colors shadows or 3D pictures look alike?The tv convergence board have dead 2 STK Convergence ICS and some or all of it resistors too.These parts on the convergence board must be replaced to fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 03, 2011 | Sony KP-57WS500 57" Rear Projection...
The picture has a triple image
Very common and easy fix. Install the RCA repair kit called ' ITC222 and ITC222A convergence option missing repair kit. Its available from and contains the parts and the CD with repair instructions.
Jul 11, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
The colors on my screen separate and triple the image I'm seeing.
The tv have an on going convergence problems.Just not total dead convergence effect yet.The tv convergence board require 2 STK convergence ICS,some or all it resistors to be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 06, 2010 | Philips 60PP9202 60" Rear Projection...
This would be the decoder/tuner board giving out, Your going to need to take it in for a replacment of that board.
you can try to unplug it for a while and see if it resets but i doubt that will cure anything long term. Proscan is known for this issue and have been known to have bad decoders in them.
Thanks for being considerate and leaving a ratings and feedback today.
May 29, 2010 | Proscan 42LA45H 42 in. LCD TV
The colors are distorted and there is triple images
triple images show failure of convergence out ICs in TV, these are two big black ICs mounted with aluminum heat sink on D board, replace these ICs with same number STK392-560 and problem in your Sony KP-46WT510 will be solved.
Required ICs are available in Part Store.
Let me know any further question, if any.
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Tripe image, blue, red and green color on image, not focus
you will need to replace the two STK392-560 ICs and also check the 4.7 ohm 1/2 watt resistors and the six 3.5 amp pico fuses.
May 05, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Triple color on screen
Go to this Blog. It "should " solve the problem.
Really, Really simple, do it your self solution !!
Instructions and pictures included :D
This blog covers many makes and models with many issues solved, just with that one solution
Give it a try, it's free and simple :D
Hope the blog helps you.
Feb 16, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Philips 27PT6441 27" TV Logo
41 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
