Question about Cell Phones
I want to reset my blackberry perl to manufactury settings
    President:
  • 1,944 Answers
Try this:
Go to Options / Security Settings / General Settings, and click Menu button and choose Wipe Handheld. Then punch in blackberry to confirm. Then the device should restart and default to factory settings.
Posted on May 19, 2008
Connect to sagemcom f@st 2864
1) reset the phone to the original manufactury default see your Menu AND do it 2) call to the supplier manufacturer Modem, and get the support via ONLINE chat for to fix it.
God bless you
Nov 24, 2013 | Polycom SoundPoint 330 IP Phone
Tip
How to Reset your Blackberry (Wipe Handheld)
If you want to reset your Blackberry phone just follow the simple steps below and you phone will be reset to factory settings in less than 5 minutes.
Step 1.
From the Home Screen choose Options
Step 2.
Now choose Security Options
Step 3.
Select General Settings
Step 4.
Press the Blackberry Button (the button to the left of the trackball)
Step 5.
Scroll down to Wipe Handheld
Step 6.
A new screen will pop up asking if you are sure. Choose Yes to continue and then you will be prompted to type the word "blackberry" for confirmation.
Step 7.
Wait for your device to reboot and viola your Blackberry has been reset.
on Jan 27, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
How can I reset my blackberry curve8520 myself?
The fastest way to reset your BlackBerry Curve 8520 back to factory settings is to peform a security wipe. it will result in the loss of all user data! It is recommended to perform a backup of the BlackBerry 8520 data. .
To reset BlackBerry Curve 8520 to factory settings: Press the BlackBerry key, Go To Options > Security Options > General Settings > Menu > Wipe Handheld > Scroll to Continue, press the Trackpad. it will reset your BlackBerry 8520 quickly.
Hope this helps, if so do rate the solution
Jan 04, 2011 | RIM BlackBerry Curve 8520 Smartphone
Reload software552
How to reset BlackBerry Curve 8520 to factory settings:Press the BlackBerry key, Go To Options > Security Options > General Settings > Menu > Wipe Handheld > Scroll to Continue, press the Trackpad. it will reset your BlackBerry 8520 quickly.
Nov 25, 2010 | RIM BlackBerry Curve 8520 Smartphone
I want to clear all contacts on verizon blackberry curve
You can do a master reset which will wipe everything from the phone and reset to factory settings, the way it was when it was brand new.
To reset the phone back to factory state:
Go to Options -> Security Options -> General Settings
Press the BlackBerry Menu key and select "Wipe Handheld." Then it will ask you to enter the word "blackberry" just to make sure you really want to perform the reset, so type in "blackberry" and the phone will do the hard reset. Give it the time it needs to boot back up, and do not interrupt it or take the battery out. That would cause harm to the phone. Otherwise, you'll be all set!
Good luck!! EJ Kudelka
Oct 18, 2010 | RIM BlackBerry Curve 8310 Smartphone
My fw1907 compaq monitor wont stop flickering...i tried to reset to manufactury default settings but it wont stop flickering
Check the singnal cable if it is equipped wirh ferrite filter rings near the ends. If not, replace the cable with one with ferrites.
If equpped, dismantle the monitor and look for blown capacitors. Replace the low voltage capacitors even if not visible bad. Check for loose solders around the inverter transformers and resolder them.
Aug 14, 2010 | HP Compaq WF1907 Monitor
Blueant st3 not recognising 0000 passcode, trying to connect blackberry and lg viewety to blueant
I had similar problem with Motorola and Blackberry Perl. It seems that the device may have been used or demoed at the store, and had to be re-set to factory defaults. The procedure is simple.
  1. Make sure that the device is OFF
  2. Press and hold Volume UP and green ON buttom at the same time
  3. After reset, power the device OFF and wait for approximately 10 seconds
  4. Power the device ON, select a language, and follow voice prompts to complete pairing
Jul 25, 2009 | Cell Phones
How do i reset blackberry curve 8330 to factory settings
how to reset the Curve back to factory state (a complete wipe-out). Please note if you just want to reboot the device, you only need to take out the battery.
Press the BlackBerry Menu key and select "Wipe Handheld" and type in "blackberry"
Dec 28, 2008 | RIM BlackBerry? Curve 8330 Cellular Phone
Cell Phones Logo
199 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
