Question about Kenmore 63932 Electric Dryer
Dryer won't heat
I replace the fuse and the heating element. The dryer still won't generate any heat. Should I go after the thermostat next? What else could it be? How can I test it and/or narrow it down?
Thanx for your help
    Sergeant:
  • 229 Answers
A common problem here can be any one of the (up to four) heat safety switches. On many models they are found close to the drum along the rear heat exhaust area. They are usually circular in shape and have two wires attached. Your appliance parts house can test them Then at this point your could remove the thermostat assembly and have it tested as well - this should get you back in business. Good Luck!!!
Posted on Nov 07, 2008
Dryer not drying
another user's Q&A for the same issue try that or call may tag, they are supper helpful
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
8574d88.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
d5b5af3.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
77d6bd4.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
    Oct 08, 2012 | Whirlpool LGQ9858P Gas Dryer
    Hoover VHW654D-80 not heating
    see the causes, and proceed. God bless you
    Heating Element
    hermal Fuse
    Thermostat
    Timer motor
    A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
    Sep 22, 2012 | Washing Machines
    My dryer will run, but will not heat.
    Hello there
    Heating Element
    Thermal Fuse
    Thermostat
    Timer motor
    Jan 25, 2010 | Speed Queen AES28AWF Electric Dryer
    My tumble dryers not drying my clothes, i've had it coming up 6 years
    Proper Voltage
    dryer_heating-element.jpg Heating Element
    dryer_thermal-fuse.jpg Thermal Fuse
    dryer_thermostat.jpg Thermostat
    dryer_timer.jpg Timer motor
    Jan 22, 2010 | Whirlpool LER5636P Electric Dryer
    The dryer is not drying. The drying temperature
    Hello there:
    Proper Voltage
    Jan 19, 2010 | Kenmore 500 6952 Dryer
    DRyer is turning just not drying clothes Maytag
    Hello there:
    Proper Voltage
    Jan 19, 2010 | Dryers
    Heavy duty kenmore dryer model # 76680100 not heating up to dry cloths
    Hello there:
    please try this
    Proper Voltage
    Will run but won't heat
    HELLO THERE
    There are 5 things that can make a dryer not heat please review the following items that i have provided for you
    investigate these five areas if your dryer is not heating up:
    Proper Voltage
    Jan 18, 2010 | Whirlpool LER4634J Electric Dryer
    The dryer does not give heat
    Hello there:
    Proper Voltage
    Jan 14, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
    Does not heat- three of the temp sensors read 0 ohms, one is at 7.4 K ohms. Can it be the cause
    Hello there
    Here is a list of item for you to check Hope this is very helpful for you
    Best regards Richard
    My dryer will not heat up. Investigate these five areas if your dryer is not heating up:
    Proper Voltage
    Dec 15, 2009 | Whirlpool LTE6234D Top Load Stacked...
    Kenmore 63932 Electric Dryer Logo
    168 people viewed this question
    Top Kenmore Dryers Experts
    Dan Webster
    Dan Webster
    Sal DeAngelo
    Tim Whalen
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
