Question about Compaq Presario 5000 PC Desktop
Compaq Presario V6000
My computer will not power up. When I hit the power button the lights come on briefly then shut off. Sometimes the lights will stay on for several minutes then but it does not boot up. I cannot get it to boot up at all any more.
  • 5 more comments
  • Andrew Fisher Jul 20, 2008
    i have the same problem with the v6000
    when i press the power button the lights come on for a few seconds then shuts it self down again,,and it does the same when running from battery only..cant get anything on the screen.
    just lights up for a few seconds and thats it.
    any idea's?
  • dasher66 Jul 25, 2008
    My customer has the same problem as the others listed on the Compaq V6000. Indicator lights are on but Screen does not come on. I'm afraid that if I replace the mainboard, it might be a bad cpu. I don't have another cpu to try replacement. Please let me know if anyone else has fixed this issue and how it was repaired. My email is dasher66@hotmail.com.
    Thanks
    Joe
  • jbbowron Jul 28, 2008
    Yes, I'm having the same problem with my v6000. Remove the battery and put the laptop in the refrigerator for 20 minutes. When you take it out, press the power button and f8 at he same time. This will allow reboot at the last known good configuration. HP has extended the warranty on this model for non-start problems like this. Good luck!
  • Anonymous Aug 22, 2008
    This is the same problem I am experiencing with my son's V6000. He was done using it the other day and 'locked' the computer. Now it will not start up; no video, just two short beeps in a series of three attempts to start, then the laptop 'powers off'..??? HP and Compaq. Don't think I purchase any more. I had problems with my dv9000 less than a year ago. i'm tired of speaking to the help desk in India! Any ideas? I tried other memory, pulled and replaced the hard drive making sure it was seated properly and tried with and without the power supply connected.
  • rydersdad Nov 19, 2008
    v6000 not working.
    It was working then it just switched off.
    Press the power button, all lights come on for a few seconds - then Click - OFF.
    Take the plug out and try to start with the battery only: Nothing happens
    Take the battery out and plug the computer in - all lights come on for a few seconds - then Click - OFF.
  • avrkrishna Dec 22, 2008
    The screen is black and the leds blink
  • simriach Feb 28, 2009
    So I , I tried also to disconnect the Bios Battery with no luck ...
    what about the warenty ? and how we should proceed .?
Pick up the laptop and put it in water. now again pick it up and throw it from your terrace.
now restart the computer if you can and be happy.
Posted on Oct 04, 2008
V6000 - V6305NR doesnt boot but now I press the power button and f8 at he same time. This will allow reboot at the last known good configuration... WORKS !!!!!
Posted on Sep 29, 2009
  • herr-billy Sep 29, 2009
  • Jon Cuellar Jan 07, 2011
    WOW!!! Herr-billy, this solution really worked for me! Power button F8. I swear I thought it was the mobo. I would power up my V6305NR (v6000) and get the blinking lights and it would shut down. I spent several calls to HP support and they agreed my mobo was fried. This was on July 6, 2010. Today is January 7, 2011. I just happened across this forum while researching the Nvidia GPU Litigation class action lawsuit that the Compaq V6305NR and HP V6000 fall under. They'll be replacing them for free starting later this month. Anyway, my V6305NR qualifies for replacement and I was just doing a search on the motherboard make when I came across this. I can't believe it. I powered up with F8 and it started and booted up with NO problem. I shut it down and powered back up without F8 and I got the blinking lights again. So I tried Power F8 again and it booted up fine. I then RESTARTED instead of shutting down. Now I can shut down and power up without F8 just fine. I did a system restore to July 1, 2010 and I'm set! Thanks soooo much for the tip! I can now use my data transfer cable to move all my data to safe storage before shipping this P.O.S. off for replacement. The V6305NR is really a LEMON. It has a history of mobo/ cooling fan/ bios probs, wifi probs, battery probs and a few other common problems. I'm definitely doing the free replacement program. You get to keep the hard drive too. I will just stick the stock ram back in and keep my upgraded ram. Anyway, thanks so much for the awesome tip!
I can't take credit for this as I saw it on another post when researching this same issue for a friend. There's a recall on these and you can find details here:
HP/Compaq Recall
Charles
Posted on Sep 26, 2008
The Presario V6000 is part of a huge recall where HP is fixing their defective design for free. The have rebuilt 2 of mine and I have 2 more in the wings.
Here is the direct page for the recall. PS: Mine is running great with a clean install of Windows 7 on it, and it will also upgrade that wonder full Vista to something that will actually run!
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01087277
Posted on Jun 03, 2009
Call HP
Spend 30 minutes trying to understand what the tech support is saying
Come to the conclusion that you knew in the beginning: that it won't start
Send it to HP when the box arrives to put it in
Lose computer for 3-4 weeks
lose all data - including pics and video of baby son
go to www.apple.com
buy a mac
Posted on Nov 19, 2008
    Scholar:
  • 160 Answers
For Solving the problem do the following:
1. Check the Power Cables are working
2. See that the SMPS fan rotates
3. If not check the SMPS power is +12 or not
4. Replace the SMPS and the CMOS battery
5. Set the BIOS settings and restart the system
Let me know! that your problem is solved and rate me as FIXYA!!!
Posted on Jul 29, 2008
  • JON NASH May 11, 2013
    You are an impetuous, pompous technician, for implying that your basic tech support steps from English that is not understandable from India that every average consumer already knows how to troubleshoot. You are under warranty, but please try everything that you have done fifteen times already while you are on the phone to make sure it's not the consumer's fault and wait do it one more time. Give me a break! People like you are an insult to the world of computing so grow a pair, lick your wounds, honor someone other than your pathetic self and become an honorable person before you get lost in your false sense of intellectual superiority. You are no better than anyone else in this world, get over yourself, get a life and stop thinking like you make two dollars an hour on the phone trying to screw people over on getting their computers replaced. GET OFF THE INTERNET YOU ARE PATHETIC!@!
Black screen and led's periodically blink.
Power off, dsiconnect power cord, remove battery then hold down power button for at least 15 seconsd, at one point you will see a quick blink of led's. This is a hard reset. Before putting in battery l\plug in adapter and power up. Fixed mine!
Posted on Jan 30, 2011
Called HP on the compaq notebook i got second hand. They said that it was out of warranty and out of the extended warranty they offered to fix the known issues. But the lady said that since it is a known issue that they would offer a reduced repair cost (259 compared to the regular 299). Your own personal call with the cost of laptops getting lower...
Posted on May 08, 2010
  • 4 Answers
Here is the only available solution for this problem over the internet
http://amritbera.blogspot.com/2009/09/solved-hp-infinite-restarts.html
enjoy
Posted on Sep 10, 2009
Jnkljlkj;kljkljklj
Posted on Aug 22, 2008
    Scholar:
  • 183 Answers
Dear Customer,
than you have to check your power sockets,its not working batter,
if its working batter than check your power lines go to your system,or you can check your SMPS & all the switches which connected to your systems,
THNX
Posted on May 18, 2008
4 Suggested Answers
SOURCE: user manual for compaq presario
my desktop turns on but nothing shows onthe monitor and a beeping sound comes from the tower
Posted on Apr 03, 2009
Marcfl35
  • 54 Answers
SOURCE: compaq presario power supply
You probably need a new power supply. Check the capacitors inside the power supply, they're probably popped. If they're not popped, bring it to a computer repair shop and have them test it. Your board could be bad, too.
Posted on Jul 04, 2009
bob_computer
  • 3153 Answers
SOURCE: compaq presario 5000 desktop won't boot!
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes P
c
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Posted on Sep 24, 2009
4 beeps in compaq v6000 lp
ok try this shut down laptop hold down function key microsoft button the B button and power all at the same time will put you in bios look forset to default settings and save and exit let me know what happens
Mar 03, 2013 | HP Compaq Presario V6000T Notebook PC
My laptop compaq presario v6000 does not switch on but the power light comes on when the chager is on. when i try to turn the computer on it just flick the light on then back off. can anyone yep me to
The DC pin on your laptop is bent/broken/loose. Look at where your power adapter plugs in on your laptop. Get a paper clip, bend it out to make a long paper clip and slightly push its tip on the pin inside your laptop. If the pin moves chances are either the DC pin needs to be soldered down or needs to be replaced. The part is usually cheap around $10 but the labor can cost more than $50.
http://www.chargerbuy.com/original-compaq-presario-v6000-ac-adapter-65w.html
Dec 16, 2012 | Computers & Internet
My compaq presario V6000 is stop working out of blue..Don't know why..the power cable is connected but hit the power button,nothing happens..any solution ??
Disconnect all cables from the computer. Press and hold down the power button for about 20 seconds. Reconnect only the power cable and try to turn on the computer on pressing the power button If it turns on then good otherwise, switch the power cable of the computer with the power cable of the monitor as they are the same cable as the power cable could be bad but this rarely happens. Open the computer and see if you see any light on the motherboard, if you do then the power supply is bad. If you dont then both power supply and the motherboard could be bad.
May 03, 2010 | Compaq Presario 5000 PC Desktop
My Compaq v6000 notebook doesnt power on it just
You could be having a problem with your power source....(not the plugin) but the actual power unit inside of the laptop. Or could be dirty inside and sometimes they get touchy with a lot of dust build up. Try cleaning out the inside of the laptop be removing some panels on the bottom and the keyboard. Try using a can of air to blow the crud out.
You can also take it to a shop and have them test the power source.
Sep 19, 2009 | Compaq Presario Notebook
My compaq v6000 does not come on. Shuts itself down when power power is pushed.
it is a hardware problem. SMPS or CPU fan has been faulty of your system. so pls ckecked it from computer vendor
Sep 09, 2009 | Compaq Presario 5000 PC Desktop
My compaq presario v6000 laptop does not power at all even when i put the mains on and switch on power. the power indicator shows there is power alright but the laptop lights do not appaer let alone for...
Sounds like the motherboard needs to be replaced. I have 2 laptops here that are doing the same thing. Lites come on and shut down after 3 seconds. It will charge the battery, thats it.
May 03, 2009 | Compaq Presario Notebook
How to activate mute button in laptop compaq presario V6000
goto google enter "compact presario drivers" click on link to HP Support and drivers. once there, enter your product name/number. it should show you a list of all drivers available for your model. download your audio driver and reload it to your laptop. sometimes drivers get currupt and dont work right. hope this helps...good luck
Mar 18, 2009 | Compaq 220W Power Supply for Presario...
Compaq v6000
i want ALL drivers for my compaq presario v3500 model no is V3611AU FOR WINDOW XP PROFs.
Sep 11, 2008 | HP Compaq Presario V6000T Notebook
Compaq Presario 5000 PC Desktop Logo
6,655 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
