Question about Sony Playstation 3 (PS3) Console
Ps3 error 80130128
Hi my ps3 was working fine on wireless aside from the fact that I had nat type 3 but I was able to play online and chat w/o problem most of the time. One day I came home and the ps3 didn't want to connect to the internet. It didn't even recognize my router. The green light under my ps3 wasn't on as usual. I have several ports opened up for the ps3 with my ps3's ip address and I tried resetting my router and turning off the security on my router. My ps3's mac address is also in my mac filter. LIke I said everything was fine then 1 day i get home and it says error 80130128. This has happened several times with my ps3 where 1 day it doesn't work on the internet then like a month later, it starts working on the internet again. I don't know if this is because my ps3 has a problem with the wi-fi card or something like that. Please help me fix this never ending problem.
  • smokske Jan 01, 2009
    i have been looking on these websites for time and mine is showing the same message ive tried everything except ringing sony cuz i know ill jus get nothing useful from then does anyone actually no how to sort out this problem?
I fixed it myself. Basically I bought a long ethernet cable and put all auto settings and it worked fine.
Posted on May 20, 2008
2 Suggested Answers
Ezrahite
  • 2632 Answers
SOURCE: Need help to make a
Welcome to Fixya. Do you have a password on your wireless network? Were you able to connect other wireless device on the router? Do you know if the security of the router is WEP or WPA? Please provide the information needed to be able to fix the issue.
Thanks
Posted on Sep 08, 2011
(ps3) How to change Nat type 3. I found a guide online it was to complicated.
Nat 3 means that your PS3 is having problems accessing the internet connection. The best way to resolve this is to not play online using wifi just connect your PS3 directly into your router via an Ethernet cable.If this doesn't work call your internet provider and they will be more than glad to fix your problem.
Mar 03, 2011 | Red Dead Redemption: Undead Nightmare -...
Cant get full online with ps3
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
Jun 17, 2010 | NetGear WGR614 Wireless Router
Ps3 nat bs purdon the french!
I had the same Problem with a Linksys WRT54G router had to get different router to fix it for me
Feb 24, 2010 | Sony PlayStation® 3 (60 GB) Console
Ps3 nat bs purdon the f858ABAD4 rench!
Nat type strict on ps3
I have windstream and it is always strict. You may want to go into your modem and make the router a DMZ. Just make sure your firewall stuff has not been changed on the router. Then DMZ your ps3 static ip. If that does not work I have been told i need to call my isp to get them to change it somehow. Or you could supposedly bridge it, but I gave up on it. I just accept the fact that sometimes I cant play with certain people or chat with certain people.
Jan 30, 2010 | Video Game Consoles & Games
I had bought a wireless router today
You need to do port forwarding. Port forwarding will open your NAT type to 1. Just call Sony and ask what port should you open on your router's admin page.
Apr 01, 2009 | NetGear WGB511 802.11G Wireless...
Ps3 setting up static nat
are you in ireland and with eircom?
Feb 19, 2009 | Netopia 2247NWG-VGx Wireless Router...
Cant to get a friend to join online playing Smackdown vs Raw 2008
There is usually two reasons for this.
The first one is the game is just having server problems.
The second one is usually the problem and that has to do with your router settings causing you to have a 'NAT Type 3' connection which can cause connection issues with other players.
Having a closed or limited NAT on your gaming console will cause a variety of issues. Similar to strict, moderate or open on an Xbox 360, the PS3 offers Type 3, Type 2 and Type 1 NAT results. These break down as follows:
Type 1 - Connected directly to the internet (no router/firewall). Should have no issues.Type 2 - Connected through a router properly. Should have no issues.Type 3 - Connected through a router without open ports or DMZ setup for PS3. Everything should function properly, but you may have connection, voice chat or other issues.While most everything will function properly regardless of what your NAT setting is, your best bet is to set up your PS3 so that you can obtain a Type 1 or Type 2 NAT. Since most of us have routers at home for connecting multiple computers or devices to the internet, chances are the best we will get will be Type 2. Thankfully that's fine and everything will work properly.
If you have not adjusted your settings on your PS3 or router, chances are you have a Type 3 NAT and probably never knew it. With a few simple changes you too can have a Type 2 NAT. Order now for just $19.99. But wait, there's more. joker.gif
The first thing you will want to do is check your network connection. Head on over to the Network Settings tab on the XMB. It looks like this:
Once there choose the Internet Connection Test item. It looks like this:
You will receive a warning letting you know that you will be signed out in order to perform the test. Choose okay. If you have not made any setting changes in your PS3 or Router, chances are you will receive the following message:
The warning reads: "When the NAT type is type 3, chat or the communication features of games may be restricted. For more information, refer to the online instruction manual."
If you run the test and have Type 2 or Type 1, stop fooling around and go play some games! If, however, you have Type 3, read on for help on opening up your NAT.
In order to open up your NAT on your PS3 you will need to make an adjustment on your PS3 and on your router. First you will want to set up your PS3 for a static IP address. This means turning off DHCP and assigning your PS3 a single, static IP address. Before you start this process head over to the network tab on the XMB and choose "Internet Connection Status." From here note your current IP address, your subnet mask, your default router and primary and secondary DNS settings. Write these down, you will need them in the following steps.
To do this, visit the Internet Connection Settings tab on the XMB. It looks like this:
From here most of the settings can simply be passed through with default settings. There are two areas, however, that you have to change. The first is choosing a Custom address setting (instead of Easy).
From here, you will want to choose Manual IP Address Setting:
Remember the settings you wrote down from your status page? You will need them here. You will have to enter in the static IP Address you want to assign to your PS3, the Subnet Mask (which is usually 255.255.255.0), the default router (the IP address of your router, most often 192.168.1.1 or 192.168.100.1), and the Primary and Secondary DNS settings. You will have to input all of these numbers. This is made much easier with a DVD Remote or keyboard.
Please NOTE - You will want to set the last number of your IP address high enough that other wireless or wired items on your network will not be assigned the same number through DHCP. While DHCP had chosen .3 as an IP address for my PS3 initially, I bumped it up to .23 because I have less than 23 items in my network. If you do not have DHCP enabled on your router, you do not need to worry about this and can simply choose an IP address that does not conflict with your other devices and which is available through your router.
Once you have all of the settings input, press X to save them. Your settings will change and the PS3 will offer to perform an Internet Connection Test for you. If you let it do the test now chances are you will still get a Type 3 NAT connection. Don't fret little bear, we still have one more step.
In addition to making the necessary changes on your PS3, you will also have to open up some ports on your router. The ports you need to open are:
TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658
I have a Linksys Router and my port forward settings page looks like this:
Depending on what type of router you have, your settings page may look different. In order to obtain an open or Type 2 NAT, you will need to open those ports listed above.
You can see in my screen capture that my PS3 is listed with its static IP address that I set above (.23) and that all of the necessary ports are forwarded to that IP address. The X listed items above (.24) are for my Xbox 360 so you don't have to worry about those.
Once you have forwarded these ports and saved your settings its a good idea to unplug and plug back in your router. This will refresh everything on your network connected to your router. Once done head back to your PS3 and perform an Internet Connection Test. If you did everything correctly you should receive the following page:
Congratulations, your NAT is now setup and working properly!
Jan 07, 2009 | Sony Playstation 3 (PS3) Console
My ps3 HAS A dns problem
Whenever you are dealin with a DNS error, it is a problem on your internet service provider's end. Contact them for a solution. Thanks
Dec 31, 2008 | NetGear WGR614 Wireless Router
PS3 NAT type problem using Zyxel P-660R-D1 series DSL Modem
thanks for help , the error was from user that have viruse on his pc , thanks again
Nov 11, 2008 | Zyxel P660HW-D1 Router
Sony Playstation 3 (PS3) Console Logo
2,830 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
