Question about Kicker Solo-Baric L7 S12L7 Car Subwoofer
NEED HELP GOT 4 S12L7 SUBS. I HAVE A ROCKFORD FOSQATE ( T20001BD ) AMP. HOW WOULD YOU WIRE THE SUBS TO GET THE BEST QUALITY? THE AMP. IS 2000W * 1 @ 1-OHM ( MONO AMP. )
    Scholar:
  • 191 Answers
Wire them parallel and pray to god that amp dosnt explode. jkjk
it really depends on what the ohm ratings are for the voice coils you could wire two subs serial and the other two serial and then run both sets parallel.
Posted on Mar 16, 2009
I have two 4ohm dual kicker compr 12s in a ported box, wired to a Rockford Fosgate 10001x BD amp at 1ohm,with 4 gauge ground and power wire. I'm also using 12 gauge speaker wire, and my HU is a JVC AVC-60...
If by "whiting" you mean "whistling" then yes, you probably have a ground issue and you are picking up alternator noise. Or you might have a very noisy alternator due to failing diodes, but the most likely scenario is a grounding issue. If you unplug the signal input to the amplifier is the noise still present? If so, the grounding issue is likely with the amp itself. If not, then the grounding issue could be with the head unit or quality of RCA cables between the HU and the amp. Do you have a crossover on the Rockford amp for the subs?
I'm also curious why you are running these subs at 1ohm. Are they dual voice coil subs and each voice coil is 4 ohms? If so, why not be a bit gentler on the amp and run the sub voice coils in series, then parallel the two subs to the amp to run 4 ohms? Running at 1 ohm is likely going to generate a lot of heat from that Rockford amp which will likely decrease its service life.
Sep 21, 2017 | Car Audio & Video
Im looking at this rockford fosgate p700-1bd amp brand new for $300 it comes with a birth sheet it says 750 rms on a 1ohm load. i cant find any reviews about it 225 rms x 1 @ 4-Ohms 450 rms x 1 @ 2-Ohms...
You can't go wrong with Rockford, in my opinion. Everything they make is well built and high quality. I personally have two Rockford p500-1bd amps hooked up to four 12 inch subs in my car and those amps make those subs slam. I have them wired down to 1 ohm and the specs say that they should be pushing 500 rms a piece at 1 ohm so that p700-1bd amp really packs a punch. Depending on what you're hooking up to that amp I would defenitely recommend it to you. - Ryan in Alaska
Feb 15, 2011 | Rockford Fosgate P7001BD Car Amp
I just needed some help with wiring my p8002 rockford amp to 2 fosgate 10 inch subs i just bought. there 4 ohms a piece and dual voice coil. i dont know much about car stereos but people keep telling me...
Well i tried looking up that amp, but Fosgate sight is down. So assuming that the best power out of your amp is 2ohms off the bridged hookup, and the subs are 4 ohms per coil, the best way is to only use one side of each speaker and hook it straight the the bridge. Only using one hook up wont hurt anything, its just for giving you wiring options. And when adding up ohms of speakers, it goes like this. If you had two 4 ohm subs, that'll give you a 2 ohm load. If you hooked up all your hookups, it would be like having four 4 ohm subs, and would give you a 1 ohm load.
Jan 19, 2011 | Car Audio & Video
Problems with car system help! I have a little older model rockford bd1000 and 2 TXXAPX12RD audiopipe subs hooked up in parallel/parallel to give it 1 ohm, had it hooked up this way for a good solid 3...
Hello srolson,
When electronic components are brand new their tolerances will allow more variation. Once you get down to a 1 ohm load, the actual impedance may vary somewhat below what the amp is capable of handling. Maxxing anything out accelerates how quickly it degrades. When new the amp can deal with putting maximum power into a minimum load, but as the components heat up and wear with age, the tolerances change.
Hope this helps.
Sep 15, 2009 | Rockford Fosgate bd1000.1 Car Audio...
How do i wire my solo-baric L7 12"
how should i wire my s12 L7 2 ohm dual voice coil to my JL 500/1 amp
Sep 15, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Will my car handle a rockford fosgat 801s power load?
Hello dreww1005,
If your alternator and battery are in good condition, you probably don't need a capacitor. At maximum output, the 801S will need to draw a little over 30 amps at 12.8V. The specifications call for 8-gauge power and ground wiring and a 40A primary fuse. The Vibe's electrical system should be able to handle it OK.
Hope this helps.
May 08, 2009 | Rockford Fosgate Punch 801S Car Audio...
Rockford fostgate p500-2 amp overheating pls help!
Your Amplifier:
125W x 2 @ 4-Ohms RMS
250W x 2 @ 2-Ohms RMS
500W x 1 @ 4-Ohms bridged RMS
Your Subwoofers = Dual 4 ohm
Possible wiring configurations of (2) Dual 4 ohm voicecoil subwoofers are:
2 ohm Stereo
1 ohm mono
4 ohm mono
That amplifier is not 1 ohm mono stable.
You need to put a 4 ohm load on the "bridged" terminals of the amplifier
Your best wiring configuration is going to be Series-parallel.
CLICK HERE to see the pic Larger
4721108.jpg You can also get the same result (power) by having the subs wired in parallel independently. Put both + on one sub to one + on the amplifier and both - on one sub to the - of the same channel of the amplifier.
Repeat for channel 2.
This will be a 2 ohm stereo load.
You should only use this method if the subwoofers are in seperate enclosures... not one big cavity.
Thanks for using FixYa -a FixYa rating is appreciated for answering your FREE question.
May 03, 2009 | Rockford Fosgate Punch P5002 Car Audio...
Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
Feb 05, 2009 | Rockford Fosgate HE2 RFP4212 Car Subwoofer
Sub woofer wiring
If you have a 500a2 and two 4 ohm single voice coil speakers, you have only one option. Connect one speaker to each channel.
Dec 30, 2007 | Rockford Fosgate Punch 500a2 Car Audio...
Kicker Solo-Baric L7 S12L7 Car Subwoofer Logo
100 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
