Question about Toshiba Satellite A205-S4777 Notebook
My laptop won't start up and i can't use the recovery media to sort it out.
When I switch on my laptop it prompts me for my BIOS password as usual. However, after I swipe my finger, the laptop shows the windows bar at the bottom of the screen for a few seconds and then goes to a black screen where it just stays. I've tried using the recovery media but my laptop just says "windows is loading files" and then repeats the same start up process as before (without prompting for the Bios password this time).
Please help!!
  • Jules77 May 29, 2008
    i've tried starting in safe mode and the system hangs at the crcdisk.sys file. does this mean my hard drive is dead or can i do anything about it without having to change my hdd and lose all my information?
  • Garry Morgan Jul 08, 2008
    I am also having exactly the same problem as Jules77's on my Toshiba A205 model and was wondering if Jules77's or any one else got a solution before I start replacing hardware. Can anyone shed some light on this for me?
  • 655 Answers
Its sounds either your windows has been currepted or you have some missing driver/software wich cause re-start.
  • Try to boot in safe mode.
  • Start pressing F8 after making on your lap til the boot option menu appears.
  • Select Safe Mode and press enter.
  • If your lap boots well then, goto Start -> Run and type msconfig in the commad box and press enter key.
  • In System Configuration Utility click on Services tab and click Hide All Microsoft Services after that click on disable all. Then press Ok and reboot your lap normally. After do same as above and enable one by one service to get which cause problem.
If it even does not boot in safe mode, then i think you should re-install windows.
Thanks & good luck
Posted on May 18, 2008
0x00000024 (0x00190203,0x83EE9898, 0xc0000102, 0x00000000)
Hey Brian,
Follow the information below to hopefully, resolve this error message.
Configure your PC to boot from CD if it isn't already set up that way. You may need to enter the BIOS to configure the PC to boot from the CD.
Set the boot order to
floppy (if present)
Hard disk
Start your PC with the Setup CD in the drive. When you see the "Press any key to boot from CD..." prompt, do so and let the CD-based boot process begin.
When the Recovery Console option is offered (Press R to start the Recovery Console), do so. You may be asked which Windows installation to enter, in which case type the number of the Windows installation you wish to work on (usually 1).
When prompted, enter the Administrator's password for that Windows installation. If you did not set a password just press ENTER
At the command prompt, type
chkdsk /r (there is a space before the /)
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 09, 2014 | Dell Dimension 3100 PC Desktop
Reset password, recover back to factory restore point
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Dec 02, 2012 | Toshiba Satellite C655-S5132 Laptop...
Dell laptop won't reboot can't remember password
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
It will prompt you to enter the new password.
Enter the new password and the password is changed
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Hope this helps.
Nov 25, 2012 | Dell Inspiron 1525 Laptop
Hello, i am selling my acer extensa 5620z, i want to put the laptop back to factory settings, i have no password or recovery disk which the new owner will need, could you please help, Many Thanks, Mary.
-If you want back to factory setting, try in BIOS system your pc laptops
-if you want back to factory setting windows, go to "system restored"
another trik :
  • Go to "Start," then perform a search for "Command Prompt." The Windows Start button is located in the lower-left corner of your computer screen.
  • Double-click on "Command Prompt" to open the application. You will need to use MS-DOS commands to reset the BIOS password.
  • Type the following commands one by one in the order shown:
    o 70 2E
    o 71 FF
    Make sure that you are typing the letter "o" and not a zero at the beginning of the second and third commands.
  • Reboot your computer by clicking "Start," "Shutdown," and then "Restart." The BIOS password will now be reset to default.
Jun 19, 2011 | Acer Computers & Internet
Had a problem with Toshiba Satellite A205-S5800. Could not remember password, or the laptop created a new password after 3 tries at trying to remember. Ran recovery disc, and now the HDD password box...
Power the laptop off. Unplug it. Remove the battery. Turn it over. Open the bottom panels. Look for a small battery. Unplug this battery. Press and hold the power button for 30 seconds. RE-Assemble everything. Turn it back on - hopefully it has cleared the settings and you will be prompted to enter the BIOS.
Apr 15, 2011 | Computers & Internet
How do i restore my c650 back to factory settings as i cant access my desktop because i changed my windows password and forgot it
If you want to use the recovery disk to reset all to Factory settings, you need to press either F10 or F11 when you start the Laptop.
Switch laptop on and start pressing F10 once every 2 seconds till you see the recovery starts. Then follow the recovery wizard.
If F10 does not work try the "F" keys usually the F8 takes you to safe mode options and F12 to the Bios setup.
Hope this helps
Feb 15, 2011 | Toshiba Satellite C650DST2N02 Laptop
Hdd password
my laptop has been in storage for 14months now i switch it on it asked me for a hdd password it never did b4
Jul 25, 2009 | Acer TravelMate 3260-4874 Notebook
My Toshiba A205 S4777 won't start up and I can't use the recovery media to fix it.
Try flashing the bios by pulling the chord out attached to the "watch" battery.
Oct 12, 2008 | Toshiba Satellite A205-S4617 Notebook
may be u av change background of d system, right click on d desktop go to properties and change it. its just a guess
Jun 05, 2008 | Toshiba Satellite A205-S4777 Notebook
Toshiba Satellite A205-S4777 Notebook Logo
330 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
