Question about HP PSC 2110 Color Printer
Printer issue My printer makes a clicking noise and paper will not feed...is this fixable all other parts of the unit work will...how much would it cost
  • 4 Answers
This printer is having mechanical problem,it will cost you something high & in this range u can go for new printer.
Posted on Sep 04, 2008
My 6500 OfficeJet has stopped feeding paper? How do I fix it?
Step one: Check the media and print settings
While the printer is on, remove the power cord from the back of the printer. Wait 30 seconds and then plug the power cord into the back of the printer.
If the printer is not already on, turn it on by pushing the power button.
Replace any paper that is ripped, dusty, wrinkled, or bent. If the paper is curled, uncurl the paper by gently bending it in the opposite direction of the curl or replace the paper.
NOTE: Use plain paper in the unit until the issue is resolved.
Make sure that all the paper is the same size and type.
Tap the stack of paper on a flat surface to align the edges.
Make sure that the stack of paper to be loaded in the unit contains from 10 to 25 sheets of paper.
NOTE: Do not load too much paper in the printer.
Insert the stack of paper into the printer and gently push the paper guides snugly against the paper.
Adjust the paper settings in the print driver. The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
Open a document in the program in which it was created.
Click File .
Click Print .
Click Properties . The Printer Properties dialog box displays.
Click the Paper/Quality tab.
In the Size is drop-down menu, select the size of the paper loaded in the unit.
In the Type is drop-down menu, select the type of paper loaded in the unit.
Click OK .
NOTE: These changes do not change the default print settings. The print settings will revert to the default print settings the next time the program is opened.
On the Print dialog box, click OK to print the document.
Try printing again. If the issue is not solved, continue on to the next section.
NOTE: If the issue is resolved and you want to print on another type of paper, change the paper in the unit and then repeat steps 2 through 7 for the new paper.
Step two: If necessary, obtain the HP Paper Feed Cleaning Kit
Some inkjet products require a special kit to resolve this issue.
Determine if the serial number is in the appropriate range
Locate the serial number on your product.
If the third and fourth digit of the serial number is 56, 57, 58, 59, 5A, 5B, 5C, or 61 , then use one of the Contact HP links on this page to contact a support representative. If your product is still under warranty, tell the representative that you need a free HP Paper Feed Cleaning Kit (part number c9000-67901). If your product is no longer under warranty, you can purchase this kit online from HP. Click here for region/country ordering information.
If the third and fourth digits of the serial number are not listed above, you do not need the special cleaning kit. Continue on to the next section.
NOTE: A USB connection is required for your Windows 98SE, Me, 2000, or XP computer to use the HP Paper Feed Cleaning Kit. If the product is not already connected by USB, connect it through USB before using the patch, or the kit will not work.
Step three: Clean the rollers
Turn off the unit and unplug the power cord.
Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. Refer to the product User' Guide for information on locating the rollers.
Clean the rubber rollers with a lint-free cloth lightly moistened with water.
NOTE: Purified or distilled water is recommended for cleaning the rollers.
Close the access door and plug the power cord in.
Step four: Service the product
If you have completed all of the steps listed above and are still experiencing a problem, service your product.
Cause
This issue might be caused by any of the following:
The paper trays are empty or overloaded.
The paper is curled.
The paper-width guide is pressed against the paper stack too tightly.
The paper tray is not completely inserted into the unit.
The paper settings in the printer driver do not match the paper loaded in the paper tray.
The rear rubber paper feed rollers are coated with dust.
Jan 11, 2011 | HP Officejet 6500 Wireless All-in-One...
Paper feed problem
The clicking noise is an indication that something's not right in the printer. But try taking out the cartridges from the printer. Then, close the cover. Remove all sheets of paper. Unplug the power supply from the printer. The power supply is the black box behind the printer where the power cord is attached. Wait at least 10-15 seconds before plugging it back in. Once printer's ready, reload the cartridges. Load some paper and try to print again. If this doesn't help and you're still getting that continuous clicking noise, it's a hardware issue. If that's the case, I strongly suggest you contact Lexmark Technical Support for further assistance. I hope I can assist you more on this.
May 28, 2010 | Lexmark X83 All-In-One InkJet Printer
Paper feed won't work
Sorry no solution but I have exactly the same problem. I have tried everything mentioned in the on-line solutions. Is this problem fixable or is a service required? Thanks to anyone who can help.
May 05, 2010 | HP Officejet J5780 All-In-One InkJet...
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Clear the jammed paper as follows.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
4. Close the front cover.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
My Lexmark X73 made a snapping noise and stopped
My printer did the same thing, after tearing into it, I found one of the plastic gears had broke in two.
Aug 08, 2009 | Lexmark X73 All-In-One InkJet Printer
Paper won't feed
clean out ur printer u possible have paper sticking inside ur printer follow the help line...if printer is clean it will work well again.....clicking noise indicates ur printer needs cleaning out
May 06, 2009 | Computers & Internet
Paper jambs in the feed. The right side seems to pull down first then just jambs up.
Solution: Remove foreign objects from Rear Tray MP210
Remove foreign objects from Rear Tray When printing, if there is any foreign material (such as a piece of metal or a pencil) in the printer, the printer my be damaged. If there is any foreign material, remove it at once. Follow these instructions to remove foreign objects from the Rear Tray.
  1. Power the printer off.
  2. Open the paper support and confirm that there is not any foreign material in the auto sheet feeder. (If there is any foreign material, remove it by hand or with tweezers.)
Open the scanning unit (printer cover) and confirm that there is not any foreign material in the printer. (If there is any foreign material, remove it by hand or with tweezers.)
Note : After confirming that the scanning unit support < 1 > is fixed into position, release your hands.
Caution: To prevent injury or damaging the unit, avoid touching the inner parts.
  1. Close the scanning unit (printer cover).
    Caution: Be careful not to pinch fingers when closing the cover.
  2. Power the printer on and confirm that the printer operates normally.
    Note: If you cannot remove the foreign material in the above procedure, the printer may require servicing.
And
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the Printers folder.
    - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
    - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
    - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
    - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
  2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
  3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  1. Remove all sheets of paper from the rear tray, then click 'OK'.
  2. Confirm the following message, and click 'OK'.
  1. Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
6efb7a7.jpg After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
Note: The following message is displayed when the paper is fed and ejected.
  1. Click 'OK'.
Roller Cleaning is completed.
Cyber Kaka
Dec 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Lexmark x7550 Printer, Scanner, Fax - Clicking Noise Question
top feeder for the scanner (on my x6570) had a loose piece of rubber stuck between the feed wheels. The rubber is part of the guiding mechanism that guides the paper to the feed wheels. Remove rubber strip and reattach it where it belongs.
Feb 19, 2008 | Office Equipment & Supplies
Load Noises
If the HP LaserJet series printer is experiencing a grinding or odd noise when printing or on power-up, open the printer and remove the print cartridge. Close the printer door.
If the noise does not recur with the print cartridge removed, replace the print cartridge.
If the noise persists, this may indicate a hardware failure. If possible, isolate and identify the location of the noise and contact a local HP sales and service ofice at the number noted in the product User's Guide . A list of phone numbers can be found at
http://www.hp.com/support .
Feb 15, 2008 | HP LaserJet 1320 Printer
Paper will not feed
These are basically throw away printers. But you might try checking the paper path. There are small plastic "arms" that guide the paper as its picked up and goes throught he printer. Sometimes one of these may get stuck in a position that makes the printer think there is paper in the path somewhere.
Mar 19, 2007 | Apple Epson Stylus Color 777i InkJet...
HP PSC 2110 Color Printer Logo
54 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
