Question about HP LaserJet P2015dn Printer
Hp laserjet p1250 error
Turn off and turn on , sometime i get the Jam Led and the Toner led both together in a solid state and usb not recognize in hp p1250
  • Writer089 Jun 13, 2008
    I've suddenly just had the exact same problem.  Out of nowhere.
    My Macintosh stopped recognizing it.  Tried to re-install to no avail.
    Low toner lights up when I just added new toner and I get the paper jam light. Unbelievable!
Check this out the paper i was using was cheap then it rained all week the humidity caused my paper to be to heavy to grab and pickup i changed the paper with hp paper and a new batch and wallah it started working again!
Posted on Jul 08, 2008
How can fix this error. i seen this "the hp laser jet 1018 has the front cover door open or the toner cartridge is missing"
Hello !!
For tha particular error you are facing, here is the reason. These printers have a switch that triggers an interrupt when the toner door is closed. Usually there is an arm on the door that pushes the switch. It is quite sensitive and delicate. Then sometimes there is a tab on the printer's toner and if that breaks off then that error will be generated.
But in your case as you have not removed or inserted the toner, I think option 1 is applicable to you.
Now, if this printer is in warranty you should send it to HP for Free repair/replacement.
and chek BLOW links too for paper jam and cleaning
Paper jam Message Displays for HP LaserJet 1018 1018s 1020 and 1020 Plus... Cleaning the Printer
Dec 23, 2014 | HP LaserJet 1018 Laser Printer -...
I just replaced the Fuser as well as a new Toner cartridge in my HP Laserjet P3005. Getting an error message after initializing that states "13.20.00 Jam Inside Rear Bin". I've taken it all back apart and...
First, make sure that both wire connectors on the right side of the fuser are seated correctly.
Then, see if there is paper sticking a little way out of the fuser. If so, chances are the exit sensor in the fuser is not functioning correctly.
You can put the old fuser back in and verify this if no error codes come up.
Oct 25, 2010 | HP LaserJet P3005d Printer
I just replaced the Fuser as well as a new Toner cartridge in my HP Laserjet P3005. Getting an error message after initializing that states "13.20.00 Jam Inside Rear Bin". I've taken it all back apart...
The problem is in the fuser exit sensor wich is behind the rear cover of the printer.Take of the rear cover and look if the lever of the paper sensor is in the wright place(the end of the lever should be between the two diods of the sensor).If the lever is in wrong position the printer will think that there is paper jam. If you need any other help please write to me. Please vote if this was helpfull.
Oct 21, 2010 | HP LaserJet P3005d Printer
HP Laserjet M1522nf - displaying an "install black cartridge"
this error can be caused by a paper jam, or a little piece of paper in the toner area, Take the cartridge out and use a flashlight to check in the sides looking for paper. Other reason is that sometimes the sensor that detect the toner is out of place and in that case you can try to power cycle with the toner out before you install it again. Good luck
Sep 08, 2010 | HP LaserJet M1522nf Multifunction Printer...
My HP P2015 reports a Jam when there isn't one
Take the Tray 2 out and check if all the paper guides are moving freely if they are than remove the toner cartridge and check if any toner sensor is not align correctly.
If they are aligned correctly than next to the pickup roller there is a small piece of plastic make sure it should be hanging freely if it is than we need to perform cold reset of the printer.
Switch off the printer press and hold down the go button and switch the printer on keep holding down go button till the time three lights lit up on control panel, as soon as three lights lits up release the go button and let the printer initialise of it s own.
If that doesn't fix than Formatter Board of the printer is faulty.
Logic:
If there is no paper jam and printer rep[orts the jam means either any of the sensors is not aligned correctly and reporting the jam or formatter Board(Motherboard) of the printer is faulty and showing incorrect display.
Thanks and Regards
Jun 20, 2009 | HP LaserJet P2015d Printer
Imaging drum LED stays on continuously
When the Imaging Drum LED stays solid on, it means your imaging drum is running low and will soon need to be replaced. You can unseat, then reseat it and see if that solves the problem.
If everything is printing fine, don't do anything until the LED starts flashing. HP will tell you to replace the drum immediately, but mine was on for a year, with moderate printing, before going to the flashing, "empty" state. This is the same advice as for toner cartridges, which are sometimes as much as 50% full when the light comes on.
However, I suggest sourcing a new drum so you can be prepared for when the existing one goes out. Also, despite HP's warnings of gloom and doom, aftermarket products work acceptably.
Apr 22, 2009 | HP Color LaserJet 2550n printer + HP Color...
HP P2015 Has Paper LED Solid Lit. Will not go off. Help!
It seems that none of the printer's sensor is faulty, in fact, the printer has a faulty firmware on the formatter.
Your printer may need replacement of the formatter board, however, please try the following before swapping the formatter.
HP LaserJet P2015 Printer Series - Paper Jam Light Solid ISSUE: The HP LaserJet P2015 may come up with Paper Jam Light solid and would show the same light pattern even if the printer is power cycled.
SOLUTION: The Light pattern is as shown in the diagram below.
Perform the following tasks in the order listed.
1. Reset the printer using the Super NVRAM initialization. The procedure is
a. Turn off the printer
b. Press and hold the GO button
c. Turn on the printer and continue to hold the Go button for at least 50 seconds. During this process the Attention, Ready and Go light turns on. Then the Attention and Ready light turns off, leaving just the Go light illuminated.
d. Release the Go button. The Go, Attention and Ready lights turn on.
e. Press and hold the Go button. All lights turn off. During the next three seconds, the Go, Ready and Attention lights turn on in that order, one per second.
f. Release the Go button to perform the initialization. The control panel lights begin cycling from front to back. After the Super NVRAM initialization process is complete, the printer returns to the ready state.
2.Unplug the power cord when the printer is on and leave it unplugged for 10 Seconds.
3. Turn the printer back on.
If the above steps resolve the issue, then print a configuration page and check the firmware version and the formatter board no.,
If the firmware version is below: 20080312, then your printer needs to upgrade the firmware, however the firmware can be upgraded only onl those models whole formatter board's third number from left is 0, 1 or 2, eg: JK0xxxx
If the 3rd number from left of the formatter board no is anything other than 0, 1, 2, then firmware cannot be flashed.
Please let me know the next update.
- Nikhil
Nov 08, 2008 | HP LaserJet P2015dn Printer
Wont print
If the paper jam and the toner lights are on, then the printer has an issue with the firmware on the formatter board.
Perform cold reset, if that does not resolve the issue, printer needs a formatter swap out or a repair.
Cold reset A cold reset also resets all the HP Jetdirect settings as well as the printer settings.
Use the following procedure to perform a cold reset.
  1. Turn off the printer.
  2. Press and hold the Go button.
  3. Turn the printer on, and continue to hold the Go button for at least 5 seconds, but not longer than 15 seconds. During this process, the Attention LED turns on.
  4. Release the Go button.
    If both the Attention and the Ready LEDs turn on before you release the Go button, you must start the procedure again with step 1.
The printer's LEDs begin cycling. The cold-reset process runs until completion, and the printer returns to the ready state.
Aug 15, 2008 | HP LaserJet P2015dn Printer
Hp laserjet 1320 problem
This is an error state that is not described at HP site.
Try to do a hard reset:
1) Turn off the printer
2) Press and hold down the green GO button
3) Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
4) Release the GO button.NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
5) The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state.
Hope it will help you
Jan 24, 2008 | HP LaserJet 1320 Printer
HP laserjet P2015D , JAM LED in a solid state ??
Dear gentlemen,
Hope this helps you sort out the problem. Please check paper jammed pieces of paper remains from paper in to out paper path. Check if the paper is properly picked-up, else check rubber roller pick-up and the solinoid motors that control to fed on and off the tray to engage pick-up. Check paper path sensors if possible. If you can determine when is the paper Jam happens please advice. Other means you can also refer your manual and machine diagnostic menu which part of the operation the paper will jam.
Best regards,
Rosener Guyano
Jan 10, 2008 | HP LaserJet P2015dn Printer
HP LaserJet P2015dn Printer Logo
164 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
