Question about Canon Cameras
My memory card on my Canon PowerShot SD700 IS is on "card lock." I have idea what that means or how to fix it. It's not in the user guide or online. I'm wondering if it has to do with a setting that can be fixed on the computer or though the camera.
  • Canon Master
  • 4,738 Answers
Remove the SD memory card from the camera. On its left side is a tiny slide switch. Slide it from the "Lock" position (written right by it) to the "unlocked" position. If already in the unlocked position, sldie it once to Lock, and then back to the unlocked position. Reinsert it in your camera and try it out.
The lock switch is a feature on SD cards that temporarily prevents writing any more data to the card. The idea being that you may wish to protect an extra special picture that you don't want to accidentally erase until you get home and download it to your computer.
Posted on May 18, 2008
Hi there! I have a Canon PowerShot SD700 is. I have bought a Sandisk 8 GB. My camera cannot read it. It says: Memory Card Error. What can I do about it? Many thanks for your help
The SD700 works with MMC and SD cards. Your 8GB card is an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards, which max out at 2GB.
Apr 23, 2011 | Canon PowerShot SD700 IS Digital ELPH /...
Cant format new 4 mb memory card on PowerShot sd700 is digital elph
If you cannot format the memory card using the format function of the camera, please connect the camera to your computer and use the computer to access your memory card and format fromt the computer.
Alternatively you can also use a memory card reader and connect the memory card to your reader and connect it inturn to your computer and format it from the computer
Dec 25, 2010 | Canon PowerShot SD700 IS Digital ELPH /...
I have a memory card error on my canon powershot SD 1200 IS. It says " memory card is locked. How do I fix it ?
Your memory card is an SD type. These cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
Nov 03, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
Message on screen says card locked. how can I fix this?
Remove the memory card from the camera (after the power is turned off). On the memory card itself you will, if you look closely, see a tiny plastic piece which slides back and forth. Slide this switch to the opposite side it is on now and this will unlock the memory card. Once this is done return the card to the camera and it should work fine. You can use the switch to ensure images aren't inadvertently erased.
Oct 30, 2010 | Canon PowerShot SD700 IS Digital ELPH /...
I just purchased a 4gb memory card for my canon powershot sd700 and it reads memory card error-card locked. I put my old 2gb card in and it works just fine. I took the 4gb back to the store and bought...
ok, first off:
make sure the card is compatible with the camera and the camera is compatible with the card (reffer to the manuals of both products).
if all checks out, contact the manufacturer of the camera first, then do the same with the card.
if everything works up to this point, but you still cant get it to work, get a new camera.
Oct 27, 2009 | Canon PowerShot SD700 IS Digital ELPH /...
Display screen reads "card locked" on my powershot sd700
Make sure the write protect lock is off by taking the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg .
Good luck.
Jul 01, 2009 | Canon PowerShot SD700 IS Digital ELPH /...
Memory Card Error
Use USB card reader&writer to retrieve the pictures directly from the card.
Nov 28, 2007 | Canon PowerShot SD700 IS Digital ELPH /...
Cameras Logo
98 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
