Question about Hitachi 37LD6600 37 in. LCD Television
Headphone socket won't work
I plug rcs plugs into the headphone outlet on this tv in order to take it to the amplifier, as they are the only outlet sockets on the TV - the only problem is, the sockets don't seem to work. I have tried just pluggin headphones into them and they don't mute the sound from the internal speakers and nothing comes through the headphones
  • nikwak May 18, 2008
    I can't see what other connections I can make as there are no other connections on the television other than Scart
    Just managed to sove this problem - there are two output sockets on the side of the television. However, they only work with inputs TV, EXT1 EXT 3 and EXT4 + PC which is a pain. It also means you have to do a bit of changing around in the menu to get it to work - another pain.
    Thanks for all your help anyway - much appreciated
    Scholar:
  • 183 Answers
Dear Customer,
Try this to solve your problem,
you have to check your headset in other system that your headset properly work or not .THIS WAY YOU CAN FIND YOUR HEADSET OR ITS PIN DAMAGE OR NOT.
than you can attach another speaker or another headset to your lcd output ,THIS WAY YOU CAN FIND YOUR PINOUT IS WORKING OR NOT .
than you have to realize that your lcd is not importing cause some models are design for proper country for porper signal identification code,so YOUR LCD MUST NOT IMPORT FROM ANOTHER COUNTRY,
check your volume level of your headset or amplifier,THIS WAY YOU MAY BE GOT YOUR SOUND IF ABOVE ALL ARE SUCCEDED.
5
you can check your power plug for your amplifier & volume settings also,
THIS WAY YOU CAN CHECK YOUR AMPLIFIER PROPERLY SETDUP OR NOT,
6
approximate 1200 pounds you had spent on this LCD ,
& at last i must have to tell you that before you many customer have same problem with sounds & video also so its failure model in hitachi if you have any warrenty than than replace or try to buy inplace of this model like panasonic LCD's are best,
or you can use your customer number for given with your documents buy on lcd to replace or any damage,USING THIS YOU CAN GET YOUR NEW SOUNDS FROM YOUR DEALER,
I AM SURE THAT YOU WILL GET SOLVE YOUR PROBLEM TROUGH THIS ARTICLE,
if you get still unsolved than contact me personaly
thnx
Posted on May 18, 2008
    Guru:
  • 1,894 Answers
Ur connection are wrong i thin
please chek ur owners manual for right ones
  • 1 more comment
  • dewan nafees ahmed May 18, 2008
    i think then headphones jack(place u insert ur headphones) is bad..
    u wil have to replace the headphones jack in ur TV sir..
    please do it by a tech or do it urself at ur own risk
    tat s the only solution u have got..
    but make sure tat it is the headphones socket u r trying with..
    that socket is surely dead..
    may be due to some loose connections inside ur power board or the socket has gone dead...
  • dewan nafees ahmed May 19, 2008
    i said u to luk into manual right..
    that is it..
    great job done..
We have a Tevion 45967, we want to just play records on it. Do we need to plug it into external speakers
Not directly.
You can:
play it via AUDACITY on your computer, or
amplify it from the line-out RCA sockets*, via your sound-card line in or a separate hi-fi amplifier with equalizer, or
use a headphone-splitter cable and amplify from that to powered speakers.
*The downside of RCA sockets is that your player's internal speakers still work.
Anything plugged into the headphone socket cuts out internal speaker. The headphone splitter allows monitoring via a headphone aaas well.
Nov 20, 2017 | Audio Players & Recorders
Have hearing problem, need to attach speakers to TV. We can't find a port for plug
Most TVs have a headphone socket. Some have an audio output socket and others have a scart socket but I haven't seen a TV that has a means of attaching speakers directly.
If there is an audio output it can be connected to a hi-fi or an amplifier and speakers and similarly a scart adaptor can be used for the same purpose.
Probably the best and easiest way is to use the headphone socket and plug in a pair of powered computer speakers
Mar 26, 2017 | Audio Players & Recorders
No sound ?
Hi Ada
Sounds like someone left the headphones plugged into the socket?
No
Then the Amplifier might be bad
Plug some headphones in.... Any Sound?
Might need a technician
Rca Projector TV L42FH037YX8 YouTube
Mar 14, 2016 | RCA Televison & Video
Will my mp3 play in my sonyTa-Ax301 Integrated Amplifier
You need a 3.5mm to stereo phono/RCA cable
Plug the red and white ends in to any of the following sockets that are free - Tuner, Tape In, CD, Aux, Video In. They all do the same job. The names are just suggestions, they're not mandatory.
Plug the headphone jack plug in to the MP3 player's headphone socket. Turn the volume up on the MP3 player to about half way. Then select the source input on the amp that matches where you plugged the cable.
That's it. Hope this helps
Sep 16, 2014 | Audio Players & Recorders
Will a ipod player play in my sony TA-AX301 AMPLIFIER-No sound
That's it. Hope this helps..
Wires connect stereo
Assuming that your TV has a headphone socket, the easiest way is to connect a lead from the headphone socket on your TV to a spare line (or auxiliary) input on the Sony amp. You will need a 3.5mm stereo plug to twin RCA plug cable, long enough to reach both pieces of equipment. Most electrical stores should have a suitable cable available at modest cost :o)
Aug 19, 2013 | Sony TA-FE370 2-Channel Amplifier
My sony wireless headphones will not work with my new 32" Veira TV when I plug them into the audio ports white/red?
Hi,All the RCA sockets are inputs so you won't be able to plug in your heaphone transmitter into those.
From what I can gather you will need to plug the headphone transmitter into the 3.5mm Jack socket located on the right hand side of the TV near the RCA sockets.
If you only have RCA plugs on your heaphone transmitter you will need one of these pictured below.
You can get them from Maplins electronics or Radioshack if in the us or any good audio outlet.
Hope this helps.
Feb 11, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
I have a Toshiba 46XV550 LCD TV. It has a headphone jack but this mutes the TV speakers when I plug in wireless headphones. Can I use another outlet (with an adapter) so the TV speakers stay on and I can...
I went to the local electronics store and bought one 2xRCA sockets-3.5mm stereo socket splitter and 2 RCA joiner/couplers and plugged that into the monitor audio plugs at the back of the TV. Works great for a total of $12.00.
Sep 14, 2009 | Televison & Video
If I jiggle the cord in the stereo outliet, the sound switches from left to right earpiece and has to be just right in the outlet to get both earpieces working at the same time.
If you plug the headphones into another device do they stay on solid?
The problem can be the cord/plug (headphones) or the socket which your plugging into. Socket might need re-soldered or replaced.
Jul 26, 2009 | Bose QuietComfort 3 Acoustic Noise...
Hitachi 37LD6600 37 in. LCD Television Logo
240 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
