Question about Memorex MVD4543A
UNIVERSAL REMOTE CODE
I ALREADY HAVE A REMOTE HOWEVER I THROW OUT THE LIST. I NEED THE CODE FOR AN RCA UNIVERSAL REMOTE FOR METVMOREX
    President:
  • 2,712 Answers
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 18, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 7 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
Code list , for element [hd] tv on a rca remote control list
If your RCA remote is universal, use code search to find something that can handle some or all functions of your Element TV. If a search through all codes stored in the RCA remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Aug 16, 2016 | Element Electronics HD LCD TV ELDFT404-B
Tip
RCA Universal Remote Code List Models RCR312W - RCR311BN - RCR311BIN RCR311SN -...
RCR311SN - RCR311STN
Would like to program your RCA Universal Remote, but have lost your code list?
The RCA Universal Remote code list can be downloaded here.
I hope that helps.
on Apr 07, 2010 | RCA Universal Remote Control
Need code for RCA Universal remote RCR314WR To set up RCA TV detg188r
Here's a link to the RCA RCR314WR remote control user manual and code list:
Information Owner Manual Remote Code List and Support for the RCA RCR314WR...
Click on the link for the codes to find the code you need for your RCA TV
Apr 10, 2016 | RCA Universal Remote Control
Needs codes rca remote
I'm not sure which remote and device you have. The header says a GE remote and the text says RCA remote. I'll provide locations for both types of remotes.
Try the following web site: http://remotefinder.rca.com/default.aspx?site=rca for RCA universal remotes. Enter the model of the remote as well as the brand and type of device to be controlled.
GE Universal remotes use either a three or four digit code. Find the code lists here: http://www.jascoproducts.com/support/universal-remote-codes.asp . Then determine if you have #24912 remote or which of the remote code lists that applies to your remote.
The code lists for any given remote will be limited to codes for devices released 6 months or more before the universal remote was programmed. If your device is newer than that date, the codes may not work.
I hope this helps.
Nov 20, 2010 | Universal Remote Control GE174Universal...
Need code for RCA universal remote #RCR 4358
You can download the complete list of codes and the instruction manual in PDF format from the RCA website by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Jul 05, 2010 | RCA Universal Remote Control
WHATS THE CODE FOR RCA TV ..I HAVE A ONE FOR ALL UNIVERSAL REMOTE NEED THE CODES TO PROGRAM MY RCA TV
You received a list of ALL Codes with your universal.
I got this off the internet. But I do not know what type of universal you bought. You didn't mention it.
Good Luck.
Here is the link if you need it. :0)
http://www.google.com/search?q=universal+code+for+rca+tv&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&sourceid=ie7&rlz=1I7GGLL_en
rca
Nov 07, 2009 | Universal Remote Control P000203220-1...
Cannot find remote code for panasonic TV/VCR combo for RCA remote
Here is a list of codes for your remote. Please follow any of the links below to get your codes.
Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
Search Results
  1. RCA Universal Remote Control-Programming Codes RCA Universal Remote Control-Programming Codes. ... The remote may already be set up to operate your brand of TV, VCR, or Cable Box. ...
    www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
  2. How to Program an RCA Universal Remote Without a "Code Search ... wikiHow article about How to Program an RCA Universal Remote Without a.
    www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
  3. Universal Remote Control Codes Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For All and more.
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
May 05, 2009 | RCA Universal Remote 3 Device Remote...
I have a rca r401a1 universal remote i am trying to get to control a APEX television set, no longer have universal codes
I have an RCA conversion guide but do not find an APEX or Insignia TV conversion code listed. It does, however, list a HELP LINE of 1-800-269-9143 for additional set up assistance. If you have already replaced the remote with another, I am looking for an RCA R404A1 remote as I've lost the one to my RCA tv so I might be in the market. jas64075@hotmail.com
Jun 22, 2008 | Televison & Video
Memorex MVD4543A Logo
269 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
