Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
No picture when on TV/Sat mode on receiver
I get sound on my TV but no picture. I have the standard outputs from my cable box coming in to my receiver like it shows in the installation manual. Have tried both the standard RCA video connection and the S Video connection without luck. My TV sais, "unsupported video signal". I am using the HDMI output on my receiver to go to the HDMI input of the TV. I know the cable is good because I can watch a movie through my PS3 which is routed through the HDMI ports. Is there some kind of format setting I need to set up on the reciever, TV or cable box?
Any help you can provide would be appreciated.
  • jimbojones51 Aug 15, 2008
    Hello I have a toshiba 42av500u ( its a 42 inch lcd flat sceen TV )
    I have had it connected to my pc with a rgb connection. It was working great.Then for some reason my roomate tried to change the resolution. Bang no display at all. So i tried to fix it but still no way. It shows pc booting and windows logo but fails to get to login. I have changed the resolution back to 800x600 60 htz just like the manual for tv suggests. Still no display past windows logo. It was working and shows the boot and logo so the siganl is getting there and the cables are fine so now what?
    Thak you for your time and effort.
    Jimbojones
  • Anonymous Mar 18, 2014
    Video signal good but no audio when connected directly to a blu=ray player or a dvd player. Just stopped working yesterday. Tried switching HDMI cables also...no luck
    Scholar:
  • 183 Answers
Dear Customer,
Try another tv to this bales,
than try another cables with this your tv ,this way you got problem & find out solution on which you can spend time for ,
than try some channels to sets up your tv configuration,
or must not be imported from another country cause its not similar to your country's signal identification,
THNX
Posted on May 18, 2008
Why did I lose the video signal from the receiver to the TV?
I assume you have tried both hdmi cables from box to tv. If both works good.Cconnect to amp. Connect cable box also on other hdmi inputs like bd, dvd, etc to make sure the spesific port is not faulty. If still no picture try to lower hdmi video display on cable box. You amp may not be able to display the higher resolution.
May 06, 2015 | Onkyo TX-NR535 Receiver 5.2 Channels, 65...
How to hook up a denon avr -1706 receiver To a lg smart tv
If you are tuning in TV stations with the TV set, you will need either an optical or a coaxial audio cable to go from the digital audio out of the TV to a digital audio in on the receiver. This setup should give you 5.1 Dolby digital sound. You can also use a pair of red and white rca cables, but you will only have 2 channel sound. You may need to set the TV to output the audio to external speakers. You will need to set the receiver to the input the TV audio is connected to.
If you want to watch Sat or Cable, you probably need a couple of HDMI cables. One HDMI cable will go from the output of the Sat/Cable box to the appropriate HDMI input on the receiver. The second HDMI cable will go from the Monitor Out on the receiver to an HDMI Input on the TV. You may need to set the receiver to output HDMI audio from the receiver, and not the TV. You will need to set the TV to the HDMI Input you connected to on the TV. You will also need to set the receiver to the input the Sat/Cable box is connected to.
Details of both of these setups should be covered in the receiver and the TV manuals. Refer to them for the detailed connections and settings you need to make.
Good Luck!
Mar 02, 2015 | Denon Audio Players & Recorders
How do I hook up my HD TV to the kenwood kr-v7080 so I can hear stereo TV ?
Maybe hook up the actual source of the TV audio (not necessarily the TV) directly to the Kenwood. Cable and SAT boxes have nice standard digital audio outputs. They're wasted on TV's which typically have sucko speakers. Lower-end analog audio is also available if you want to watch Cable/SAT throught the TV speakers.
May 17, 2011 | Kenwood KR-V7080 Receiver
I have direct satalite tv VR 6050 kenwood surround sound tuner vizio tv, dvd player, and a vcr, Im confused on how its hook up and what order should it go something like sat in to sat box to kewood...
that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
you can still use it, but if you run the picture through the reciever, it will have poor quality.
heres how you are supposed to hook it up:
find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
Nov 25, 2010 | Kenwood VR-6050 Receiver
Just need to know how to hook up to tv to get sound
If you don't have a cable box or satellite receiver, you will use the "Audio Out" or "Monitor Out" from the TV to any audio input on the receiver. It's just a standard RCA cable or if you have an "Optical input" on the receiver, use that. If you are using a cable box or sat, the audio would come from the cable/sat receiver by standard RCA, Optical, or Digital Coaxial, whichever your AV receiver will support. Hope this helps. If you need further help, post a comment and I can walk you thru it.
Sep 27, 2009 | Zenith ZHD-311 300W Complete Home Theater...
Its not broken or nothin i was wondering how to put the input for cabel from cable/sat to colorstream hD1
Cable boxes or satellite receivers typically only come with audio/video output, RF output, and component output. You need an upgraded one which has the Hdmi output jack. The upgraded box will cost you a service fee around $5-10 a month, so if you don't want to pay to receive the 1080p service you can receive 720p by using the component video output leads from your cable box.
The quality is almost as good. The only difference will be that you won't be able to receive the hi-def channels that the cable company offers.
Apr 29, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Snow on screen and no picture on my DS35510
Hi and welcome to FixYa,
Offhand, if the previous system/connection works then we should leave that as it is. Coax-Sat Receiver-Coax-DVD Recorder-TV and TV should be Channel 3 (or 4).
On the new Sat Receiver, coax from LNB/Dish to Sat Receiver, yellow, red & white to TV. TV should be set to Video 1 or A/V or Video. There should be no snow, rather if no reception, it should be blue indicating video has muted in the absence of a good signal.
Good luck and Thank you for using FixYa.
Jan 04, 2009 | Sanyo DS35510 35" TV
Ps3 not working
  • Check that the input mode of the TV is appropriate for the connector in use on the PLAYSTATION®3 computer entertainment system.
  • There may be a problem with the cable in use. Try using another cable that is compatible with the PLAYSTATION®3.
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
if that does not work then call Sony at
1-800-345-7669 (SONY)
Mon - Sat 6:00AM - 8:00PM PST
Sun 7:00AM - 6:30PM PST
Apr 17, 2008 | Sony Playstation 3 (PS3) Console
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
490 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
