Back to:
Tags:
Motorola RAZR V3 Cellular Phone
Buttons don't work (by 7 users)
posted by 1213joec on May 18, 2008
The only button that works is the red off button.The phone will still receive calls if it is closed
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
6 Other Users Have The Same Problem
Comment by Guest, posted on Aug 13, 2008
none of my buttons work either! but my phone does work in my car when i use sync.... how annoying! It doesn't turn off unless i take out the battery.
Comment by nmac, posted on May 23, 2008
Have same problem. Neither the side buttons nor the key pad buttons. Can call using car bluetooth and can answer the phone when I get in coming calls. Nothing else works. Took it to AT&T and was told I would have to get a new phone! This phone is 2 years old.
Comment by Guest, posted on May 19, 2008
Same problem. Only the red button works to put it on. No asking foor SIM-code, just Hellomoto appears on the screen. To power off i have to remove the battery.
Comment by viogil, posted on May 19, 2008
My phone worked fine & then all of the sudden they stopped working. The key pad & the side buttons won't work. The only button that works is the red on/off button. I still receive phone calls but I'm unable to awnser them. Please help.
Comment by gandon, posted on May 19, 2008
No buttons would work except the off button, and it automatically dials number 7, and 9, and go on to voice record by itself, and starts deleting dialed calls. then it started working the next day for about 5 minutes, and stopped.. I took care of it like a baby, never dropped, no scratches even. Should not have happened, very pissed.
Best Solution
posted on Jun 02, 2008
Helpful (85)
Bajanguru
Rank:Wiz Wiz
Rating: 82%, 1883 votes
Try mobile2mobile.net, unlockitnow.com or take it to a mobile service center to have it unlock there for a small fee.
1213joec - the flexcable on the phone needs to be replaced.
Slayer57689 - the flexcable needs to be replaced
gandon - you need to have a keypad flex file reloaded on the phone to get this problem fix.
viogil - replaced both the flexcable and the cable connected on the earpiece of the phone.
nmac - replaced both the flexcable and the cable connected on the earpiece of the phone.
Guest - keypad needs to be replaced and phone needs to be reflash.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Buttons don't work:
I don't want to Accept this solution
Can you Help with these Cellular Phones problems?
display and keypad shuts off and will not come back on...
utilice los trucos para ampliar memoria del v3 y ahora no...
hy could someone help me please. i have a motrolla v3...
I purchased a Motorola V3 RAZR cellular phone, but I...
Displaying PHONE CODE SIG. ERROR can someone plez help...!
6 Other Users Have The Same Problem - Continued
Comment by Slayer57689, posted on May 18, 2008
None of my buttons will work either.
Except i can turn it off.
It's really strange and starting to really irritate me.
It's a pretty new phone but the keyboard and side buttons wont work
HELP!
Loading problems.
Repair Service
Find Cellular Phone Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
