Question about Sega Genesis 2 Console
SEGA 32X SYSTEM
HI THERE,HAVE JUST BOUGHT A 32X SYSTEM & THE SEGA RF BOX IS MISSING,THE BLOKE I BOUGHT IT OFF SAYS YOU CAN USE THE ORIGINAL SEGA MD ONE!,BUT YOU CANT COS ON THE BACK OF THE 32X THE A/V OUT PLUG NEEDS A 8PIN MALE PLUG THEN CONVERTS THROUGH THE SEGA BOX TO A NORMAL MALE PLUG FOR TV,PLEASE CAN SOMEBODY HELP ME WITH THIS PROB? & WHERE WOULD I GET THIS LEAD,ALSO THE 2 METAL STATIC PLATES?,MANY THANKS GARY
OK HERE's where I found some of those plates and the wire www.ebay.com/electronics
Posted on Jun 27, 2008
How to connect sega master system 2 to lcd plasma tv
If your TV comes with a composite video input then this may not be an issue. You need the RCA AV cable. Sega outputs only mono audio so put Yellow in TV video In and White in TV audio In (white connector).
http://www.gametrog.com/GAMETROG/HOW_to_connect_Hook_Up_SEGA_Master_System_Instructions.html
If you still have the RF box for the Sega then you should be able to put RF from Sega and TV antenna to the RF box and connect RF box to TV antenna in.
If TV is only HDMI input then you need a converter like this
Composite Video to HDMI Converter
Sep 04, 2014 | Video Game Consoles & Games
Hi i have a sega megadrive 2 and have only just got it out, but now have a Bush digital TV and the Sega is on (power) but I can't either locate the channel or am confused on how it connects up to the Tv to...
I think those have the old style RF connectors.A coaxial cable with a grey or black box in the connection cable.Plug the coaxial cable from outside into the RF cable.Plug the RF cable into the TV coaxial input(regular cable input).On the back of the Sega,there should be a switch for CH3 or CH 4.Put the TV on the appropriate channel.If the signal looks bad,switch the selector on the Sega and change the TV channel.If you do not have the RF cable there is a place that still sells Sega accessories,but not Sega.They must have contracted with Sega.If you need the site let me know.
Aug 02, 2010 | Sega Megadrive Black Console
I recently found my old sega megadrive/mega-cd and I've dusted it off and tried to reconnect it but have found i'm missing the cable which links it to the tv. According to the instruction manual I'm...
I searched and Sega themselves do not deal with older systems,however here is a phone number to the place that can probably help.They are contracted for the older systems I guess.It is called an RF connector or RF cable too.(714)836-4981.I don't see your system on the list on the link but it wasn't on Sega.com either.
http://sega-parts.com/ is the older systems link.
Sega's main number is 1-800-USA-SEGA but good luck trying to actually talk to someone.No surprise there huh?
Good luck and game on!
Jul 26, 2010 | Sega Genesis 2 Console
Have just bought a hardly used sega megasystem 2 console but it doesnt seem to work. does anyone know where all the leads etc should go? thanks
Hi, Sega master system 2 are connected to your TV via an RF cable. One end is RCA which connects to your console the other end is Pal which connects to you TV's antenna inlet if your using the sega RF switch then the RF switch connects to your antenna inlet on your TV and you should have a RCA to RCA cable which connects the console to the switch. Please note these cables and power adaptors can in some cases be faulty. These console are manually tune to VHF-1 frequency so make sure your TV has this frequency. some do tune to UHF but most tune to VHF-1 if you need parts www.gameoz.com.au stock the a huge range.
Mar 20, 2010 | Sega Master System Console
Sega 32X Connection Requirements
No, the 32X doesn't need an independent "rf" connection to the TV.
It does however, require a separate power supply as well as that cable to the console.
Mar 03, 2010 | Sega Genesis Console
Help connecting a Sega Genesis 16bit system!
What you will need to do with the RF cable is to take your incoming cable thast goes to your TV and screw it into one side of the RF box. Then the adjacent short cable wire that is on the other side needs to be screwed into your TV. The long end of the cord plugs into the back of the sgea unit. Good luck! Any other questions, feel free to ask.
Nov 07, 2009 | Sega Genesis Console
Bad picture with Sega Genesis model 1
Taking your problem in a whole new direction, why don't you try purchasing an 8 or 9-pin (depending on the type of Genesis you have) DIN RCA cable. This will improve picture and sound, and you won't have to worry about malfunctioning RF converters. Your problem sounds like the RF adapters are inadequate.
Sep 16, 2009 | Nintendo Super NES Console
BOX THINGY
the box is a RF switching box
the lead you require is a phono to ariel lead (megadrive, master system or any old computer will do)
or if you get an old video lead and cut of one end and wire a phono plug to it it will also work.
or you try ebay
http://shop.ebay.co.uk/items/_W0QQ_dmptZUKQ5fVideoGamesQ5fVideoGameAccessoriesQ5fVideoGameAccessoriesQ5fJN?_nkw=sega+rf++Master+System++&_sacat=0&_fromfsb=&_trksid=m270.l1313&_odkw=sega+rf&_osacat=0
a basic lead for £2.50
replacments upto £10
both work
Oct 15, 2008 | Sega Master System Console
I am trying to locate a auto rf switch box for my sega master system 2
Looks as if Nesfixxa400 has never seen athe back of a Mastersystem 2, there is only an rf lead port!
so you are looking for a RF splitter
you can seach for the following
master system rf switch box
Megadrive 1 rf lead with switch box
I also remeber at a 99p shop seeing a 3 way TV switching box
search for MK-3088 on ebay (below) they are compatable
http://search.ebay.co.uk/search/search.dll?sofocus=bs&sbrftog=1&dfsp=1&catref=C6&from=R40&satitle=MK-3088+&sacat=-1%26catref%3DC6&a14=-24&a6=-24&a10244=-24&alist=a14%2Ca6%2Ca51%2Ca10244%2Ca3801&pfmode=1&reqtype=1&gcs=1132&pfid=1621&pf_query=MK-3088+&sargn=-1%26saslc%3D3&sadis=200&fpos=IG7+5BP&sabfmts=1&ga10244=10425&ftrt=1&ftrv=1&saprclo=&saprchi=&sass=&fsop=1%26fsoo%3D1&coaction=compare&copagenum=1&coentrypage=search
Jul 01, 2008 | Sega Master System Console
Sega Genesis 2 Console Logo
114 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
