Question about Mitsubishi WD-52825 52" Rear Projection HDTV
WD-62825 TIMER BLINKING CONTANTLY
I HAVE REPLACE THE CAPACITORS ON THE PWB,DM,FMT BOARDS AND MY TV STILL IS NOT POWERING ON ,DO ANY ONE KNOWS ANY OTHER IDEA OF WHAT ELSE COULD IT BE ANY HELP WOULD BE GREATLY APPRICIATED.
  • 2 more comments
  • FIDO2527 May 18, 2008
    no i have not replace the 3300uf caps, are does the big brown ones?and when can i purchase the thermal sensor?
  • lembo Jun 17, 2008
    I have a WD-52825 with the green light constantly flashing. I have tried numerous resets with no help. I have unplugged the set for 24 hours and still have the green light flashing. Is there any idea on what could be the cause and the cost to repair?
  • sbl5 Sep 19, 2008
    My wd-52825 has the same problem. The timer light does not stop blinking and the set can't be turned on.
  • guerns Dec 08, 2008
    I have tried to reset the blinking green light of death several times. I had a luck a few times in the past year, but this time it doesn't want to kick back on. I have heard it could be the capacitors, the power supply or something else. All was fine until the lamp burnt out. A month after replacing it, all heck began, not to mention the lines on the screen, that seem to be related to the power supply issue also.
  • Mitsubishi Master
  • 8,617 Answers
Did you replace the two 3300uf caps on the PWB? how about the thermal sensor?
Posted on May 18, 2008
  • Sonny Berry
    Sonny Berry May 18, 2008
    They have been made different colors so i cant say for sure, but there are only two 3300 uf @16V caps on the PWB and you can get the thermal reistance if you need it at the following link but you would have to leave an email as they dont list alot of their little components. Just leave your model number and the name of the part your needing.
    http://servicemanuals.vstore.ca/
Blinking "Timer" light for WD-62725
If this is a DLP, you may have problems on the FMT/DM boards in the sealed electrical chassis.
That's a big problem, because Mits doesn't make the DM/FMT boards available anymore. They are only available for rebuild from Mitsubishi and other qualified places.
There is a chance that there are some vented capacitors on the DM and FMT boards you might be able to replace, but it's for someone really comfortable with completely disassembling a set, soldering in 8 new caps and rebuilding the chassis.
Rebuilds will run you $400-$500 in rebuild costs and an additional $200-$400 in labor, depending on the joint.
Jul 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Could be anything if we don't know where to start, even the jungle chip that has blown.
Sep 06, 2008 | Televison & Video
Mitsubishi 62825 flashing green light on timer set wont come on,try reset same problem ?
Your main boards are bad. The FMT, DM, & Power Supply. They are no longer available, You have to have the chasis rebuilt. Mitsubishi is rebuilding these chasis. You have to pull it without any cut wires & ship to Georgia.
tvdoctor, T.O., Ca
Jan 19, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Sep 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mit 52525 from blinking green light to still green light.
bad capacitors 1000uf on the PWB, FMT and DM boards will cause those symptoms. All capacitors 9 in all need to be replaced
May 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TIMER BLINKING RED
That set is plaqued with bad capacitors on the PWB, FMT and DM doards. Usually all problems assosciated with that model can be attributed to those capacitors. You can purchase a service manual that they will email you at the following link, and they will provide free tech support to help you straighten it out. Heres the link.
May 03, 2008 | Mitsubishi WD-52825 52" Rear Projection...
Green blinking light
the PWB , FMT and DM boards all have capacitor issuses with that chassis. If the power light is blinking there are 4 1000uf capacitors on the DM that need replacing. If you need more info let me know.
May 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Wd62825 blinking green light
if you have replaced the caps on the DM and the FMT and power supply. you can unplug the e2p. the set will run without it if it is the problem, however it will take 5 to 10 minutes to boot up so be patient.
if it boots try turning it on. the picture should look terrible because no
light engine data is getting to the dm. chances are it is not the e2p, in the over 300 of these chassis i have repaired maybe 10 had a bad e2p. most likely the chassis needs to be rebuilt. check out www.tv-techs.com
Apr 17, 2008 | Mitsubishi WD62628 62" Projection HDTV
Wd 62525 honeycomb pictues
The DM board wont cause that symptom. The DM only directs power that is recieved from the PWB to the ballast fans and etc. That sounds like a problem with the FMT. capacitors 1000uf @16volts numbers C8F21, C8F22, C8F19, and C8F27. those will cause distortions in the video on the V26 chassis. Let me know if you need more info
Mar 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Oct 29, 2007 | Mitsubishi WD-62825 62" Rear Projection...
Open Questions:
Mitsubishi WD-52825 52" Rear Projection HDTV Logo
209 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
