Question about JVC HD-52G886 52" Rear Projection HDTV
Replacement lamp I need to find a replacement lamp for my JVC HD-52G886. Where will be the best place to find one?
  • Anonymous Aug 11, 2008
    color is distorted and tv has double image.  bought tv in 2002.  could it be the lamp that needs to be changed?
What do i do if i dont have a manuel????
Posted on Aug 31, 2010
  • JVC Master
  • 8,617 Answers
Www.alltvlamps.com should have the lamp your needing
Posted on May 18, 2008
JVC HD-52G886 HDTV Television screen is dark
usually it is the lamp this set uses, has it been replaced or is over 2 years old?
Oct 29, 2012 | JVC HD-52G886 52" Rear Projection HDTV
Have a jvc hd rear proj, m#hd52g886 new lamp light on front keep flashing and no picture...Help
seagoblin28,
If you haven't replaced the lamp you should. If you have replaced the lamp you may just need to reset the unit. Go to my tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains where to get the lamp at the best price and how to replace it as well as links to additional problems.
Thanks for using Fix Ya and for the great rating.]
hardrocko
Feb 18, 2011 | JVC HD-52G886 52" Rear Projection HDTV
Jvc tv
when both the blue light and red light are blinking it means 1 of 3 things. 1. lamp replacement. This often works everytime for the repair. TIP!!! DO NOT USE ANY OTHER LAMPS OTHER THAN JVC AUTHENTIC LAMPS. ANY OTHERS AND YOU RISK DAMAGING YOUR TV FURTHER. 2. the fans are not working properly or need to be replaced. They need to be cleaned every so often and they will stop working from burn-out if not done so. This repair will cost you less than 100 dollars. 3. The ballasts are defective and need to be replaced. The ballasts themselves run about 150 dollars. I tell you I have fixed this TV more times than I care to count, not to mention the number of lamps I have gone through. The guy at the TV repair place now knows me by name when i come to buy lamps. :(
Aug 25, 2008 | JVC HD-52G886 52" Rear Projection HDTV
TV not turning on
This is the lamp error code. The lamp part# for your unit is
TS-CL110U. Hope this Helps.
Mar 21, 2008 | JVC HD-52G886 52" Rear Projection HDTV
Jvc tv
It may be lamp, Look at the lamp and see if there is any discoloration inside, but do not touch the lamp glass. The oils from your hand will heat up and blow the lamp. The lamp part# for your model is TS-CL110u. Hope this helps.
Dec 15, 2007 | JVC HD-52G886 52" Rear Projection HDTV
Hd 52g886
Your Lamp is burned out.
Sep 04, 2007 | JVC HD-52G886 52" Rear Projection HDTV
JVC HD-52G886 52" Rear Projection HDTV Logo
230 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
