Question about LG LRBN22514ST Bottom Freezer Refrigerator
Freezer door We have an LG bottom freezer (swing door) and it is 8 months old. When the upper door is open you can notice the freezer door is pulled in slightly. When the upper door is closed, the freezer door pops open approximately 1/4". It seems to be a new problem. Can you offer some suggestions on how to resolve this?
  • 489 Answers
You may have a door alignment problem and requires a qualified LG technician to find the problem.
Posted on Jun 11, 2008
The swing arm gets stuck behing the ice bucket and the drawyer won't open
Swing arm alignment can be restored by resetting the ice maker. There is a reset on the bottom, near the front of the ice maker. HOLD it down through a complete cycle, about 8 seconds, then wait for the two-tone chime to indicate the reset is complete. Failing that, a new ice maker may be needed, the old one may need thawing or there is debris under the bin or arm stopping the cycle. I have actually tore this thing off by opening the freezer at the the exact moment it was cycling too, arrrrgh.
Jul 09, 2014 | Samsung RF265AA Bottom Freezer French Door...
Why wont my refrigerator & freezer get cold?
If all is running, the compressor is not pumping properly, or the refrigerant is low. or blocked.
Apr 26, 2014 | LG Bottom Freezer Refrigerator w/ Swing...
LG Bottom freezer refrigerator Model LFC21760 does not cool
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages
Sep 28, 2009 | Refrigerators
I have a kenmore upright freezer model #253.9266411 there is a gap in the upper left side does anyone know how to adjust the door? The seal is fine
I'm assuming you don't want to replace the door seal. Open the freezer door. Stand "inside" the open door and place your foot at the right bottom corner (looking from the inside). Place your hand in the top right corner and pull it very slightly toward you. Do this in small amounts until the gap closes making sure you don't open one at the bottom.
An alternate method is to warm the gapped section of the door seal with a hair dryer to soften the rubber enough to allow the magnet within the rubber to pull the seal gap closed. This has worked for me numerous times by making small adjustments at a time. Good Luck
Sep 02, 2009 | Kenmore Freezers
Bottom freezer door opens when top door is open and then closed
the door pops open because freezer and frig. are connected together via duct. air pressure builds when you swing ref door closed. apply a small amount of vasoline to the surface of the hinge side of both gaskets. this will aid in door closure. also the unit may be not level
Jul 02, 2009 | Refrigerators
Bottom freezer door moves top to bottom by moving handle in & out
Hi, most models have adjustment screws near the track connected to the door if this is a slide out door. If this is a swing out door, you might be able to twist the door back in shape.
If the gap is only in the corner of the door, try inserting a piece of paper towl rolled/folded up behind the gasket to help stretch it.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 05, 2009 | LG LRBC22544 Stainless Steel Bottom...
Roaring sound
I have had the same issues. I have owned my LFX25960 for 18 months. All the cooling, noise, and condensation problems are related to 2 fans. One for the freezer/refrigerator compartments and One for the Ice Maker. The fans, apparently, are not sufficient to move enough air through the coils located behind a plastic panel in the freezer compartment. The part numbers for my fans are 1. Ice Maker 4681JB1029E and Refrig/Freezer 4681JK1004E. It is not impossible, but fairly difficult to replace them yourself. You have to remove the large slide out freezer drawer and glides. Then work the back freezer panel loose from the bottom. Be careful not to break it. It is plastic.
Routine maintenance: Pull the refrig out from the wall and blow-out the coils and fan located on the lower right rear. You might find it easier to do this by removing the cover on the lower, back of the refrig.
Apr 17, 2009 | LG LFX25960ST Stainless Steel French Door...
Freezer door not sealing well (Frigidaire side-by-side)
your house may be settling and now the refrigerator needs to be tiloted back slightly. take run the adjusters on the front in a little until the doo closes by it self.
Mar 28, 2009 | Frigidaire FRS26R4A Side by Side...
LG LRBN22514ST Bottom Freezer Refrigerator Logo
310 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
