Question about Electrolux Lux 7000 Bagged Canister Vacuum
Ambassador electrolux c101j
How to open
  • 1 more comment
  • jose malave May 18, 2008
    I believe also...thats a owner manual
    I am trying to open the vacuum to fix the wires to the motor the two straps in side
  • Anonymous Mar 15, 2014
    Motor is running but brush does not opperate
    Genius:
  • 1,665 Answers
A service manual is needed
http://www.electrolux.com/
Posted on May 18, 2008
  • 319 Answers
Hi
I believe that your model (Ambassador) was manufactured by Aerus. They have a different website than Electrolux.
I have found a service manual for an Ambassador here. Please let me know if that helps.
Brian
  • Brian Berndt
    Brian Berndt May 18, 2008
    What is it exactly that you are trying to open? Are you trying to open the access to the motor, or other parts?
    Or are you trying to open the belt access?
    Please be a little more specific, thanks!
2 Suggested Answers
  • 694 Answers
SOURCE: how do i open the
This can be a complex undertaking, so I highly recommend taking it to the nearest Aerus Electrolux store for repair. I've seen many disassembled machines come in to the shop because the owner couldn't figure out how to put it back together. Any misplaced wires during reassembly can result in nonworking vacuum, shock and even fire hazard.
Taking it to the shop may cost more, but I believe is less expensive in the long run. They'll do it right.
http://www.aerushome.com/storelocator/
Posted on Dec 14, 2010
My electrolux ambassador power head goes on and off as I try to sweep. What can I do?
Most probably the hose has gone bad. You would new a new one. this will fit your vacuum
http://www.ezvacuum.com/electrolux-hose-with-switch-control-for-electrolux-canister-vacuum-vnotch-generic-p-1525.html
Jan 11, 2013 | Electrolux Vacuums
How do i open the housing of an electrolux ambassador model #c101j to fix cord recoil
Dec 14, 2010 | Electrolux Lux 5500 Canister Vacuum
Following old directions found online I opened an Electrolux Ambassador III to fix the cord winder. When reassembling, I found a loose white wire. Where should it be reconnected?
A white wire is part of the power wiring (neutral), but if the machine runs ok, it may be a left-over from previous work or original manufacturing. If the machine does not run now, then look obvious bare connectors to reinstall it. Hope this helps!
Oct 02, 2010 | Electrolux Vacuums
ElectroLex Cannister model C101J Cord won't retract, trying to remove hard plastc side strips. Appears to be 'one-way' lock in 'T' channel - suggestions unlock?
Use a screwdriver to pry on the top or bottom of REAR cover. I t is held by 4 prongs that fit into 4 holes in tabs. It took a little effort to do mine but it came off. From there you can access retractor mechanism.
Jan 09, 2010 | Electrolux Lux 7000 Bagged Canister Vacuum
How do I dismantle an Electrolux Ambassador II?
you don't, as a repairman, even i have a hard time opening them, and then the hardest part is putting it back together.
Sep 14, 2009 | Vacuums
Hi, I have an electrolux Ambassador and the other day I was vacuuming a fringe carpet and the fringe made the electrolux stop (has happened before) and when I pressed the reset button, the motor is on but...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=678083
Generic problem for all Vacuums
Hi, I have an Electrolux Ambassador
Posted by greenforest on Jun 17, 2008
Hi, I have an Electrolux Ambassador and the other day I was vacuuming a fringe carpet and the fringe made the Electrolux stop (has happened before) and when I pressed the reset button, the motor is on but the wheel does not spin. Any suggestions?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are 2 possibilities that could be happening. Either the belt is broken of which you can replace the belt @ least one a year for proper maintenance or there may be a reset for the vacuum in case you get something caught in the brushroll section of the vacuum. Check both of those items and it should work unless you have a motor burn out – if you did there would be a burning smell. Feel free to contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 17, 2008 | Vacuums
Electrolux Ambassador stainless lower wand
http://geeksquad.fixya.com/ThreadView.aspx?prdid=113654&thid=638738
Posted by Cuyler on Jun 01, 2008
I am trying to locate a stainless lower wand for an Electrolux Ambassador model 1623. The search has proven fruitless so far. Any suggestions?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. A couple of thought came to mind that you can try. Look in the yellow pages for your local vacuum dealer to see if they carry it to contact your Electrolux factory @ the phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Go Ahead. Use Us.
Jun 01, 2008 | Electrolux Guardian Bagged Canister Vacuum
Electrolux Lux 7000 Bagged Canister Vacuum Logo
1,477 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
