Question about Intel D945GTP Motherboard
Intel MB D945GTP
The fan was very durty. We cleaned with a vacuum cleaner. To clean we have separated the fan from the CPU. Once cleaned we put it back. We have put back all peripherals and tried to start. Did not start. Though there is a light close to the power input indicating there is power. We have also erased the CMOS thinking that the computer had an automatic ON control. Thank you for your help. Guido.
  • 593 Answers
Give it 3 hours with no P/S plugged in, it might come back up. I just read a similar post. Dies when you unplug anything "active" from mobo, like fan, drive or floppy. MOBO senses voltage difference and shuts down.
Posted on May 20, 2008
My system suddenly hang when we restart it, monitor does not get any signal. After when we get rid hard drive motherboard was working. on other system my HDD is working fine.
This is usually dust clogging up the CPU cooler.
When the owner of the PC forgets to clean the fins and the fan of the CPU cooler it plugs up with dust and dirt and looks like the inside of a vacuum cleaner.
There is not enough airflow and thus not enough cooling, so the CPU overheats and the safety circuit shuts the CPU off until it cools down, and the CPU will not reboot the PC until it is cool enough that the safety circuit can reset.
First step remove the CPU fan and check the fins of the CPU cooler. If they are clean, the problem is usually somewhere else.
Oct 03, 2015 | Intel DG31PR Motherboard
Intel D945GTP power comes for one second and suddenly off
open the tower/ ATX cabinet and then check the two small power cable pins that connects the power button on the ATX cabinet and the motherboard, remove the same from the motherboards end (make sure you note down from where you removed the 2 power pins and then using a insulated screwdriver short the power pins on the motherboard for a second until you see the power coming on let go of the pins as soon as you see the CPU fan moving if it stays on and works normally it is a faulty power switch on the ATX cabinet and then you can either replace only the power switch or get a new ATX cabinet to fix it
you can also check if motherboard stays on if you remove the RAM chip from the motherboard. if yes its a faulty Ram and replacing the same should do the trick
you can also try cleaning the dust accumalated under the CPU fan and between the heat sink as some motherboard cuts off the power depending on the temperature
also if nothing works you can try using a different power supply unit to see if that's the case,
if still no luck then its time to buy a new motherboard.
Feb 06, 2012 | Intel D945GTP Motherboard
The computer turns on but does not boot, I get 3 long beeps
i think the problem was memory try to remove and clean it using pencil eraser. and back it properly..
Nov 11, 2011 | Intel D945GTP Motherboard
My computer keeps turning off i not sure what happening with it my hard drvie is fine and power supply but you see the fan that keeps it cool well i don't know but the cpu is a hp with window 7 and...
do you mean 1gb of ram.no this is not a ram issue ,sounds more like overheating or cpu fan is failing.how old is pc and have you clean the fans since owning it.Its a common problem .where do you keep your pc tower ,if on the floor then you may find your fans for your cpu,power,graphic are coated in dust,and you may find your fans are overheat due to the weight add and no Im not joking .try clean your fans and cpu cooler fins.don't use a vacuum cleaner like some people do as you can damage your chip-sets on your motherboard .buy a can of compressed air from pc store and make shore the fans dont spin when clean as it can short your cpu,graphics card.cpu fan clean gentle with cotton bud.if this does not work try replace your cpu fan. hope this helps let me know how you get on. ..............DT
Sep 07, 2011 | Microsoft Windows 7 Ultimate for PC
I have intel d865glc bord . when i on my computer ofter five minte the borad are much heated (mean get heat in a wile) and ofter that the speed of pc is so slow plz send me the soultion
If the computer is overheating, you need to give the PC a good clean.
All the fans, the CPU heatsink and fan, case fans, PSU fan and grills.
A small brush (paintbrush) and a vacuum cleaner if you are very carefull is all you need.
You can also buy an AIR DUSTER to blow all the dirt away
Use google to search for YOUTUBE cleaning guides
Aug 06, 2010 | Intel D865GLC Motherboard
Rebot continuos
It is possible that the CPU fan is spinning too slow which allows the CPU to over heat and restarts you're system. (A safety feature for all MB's). Or the CPU fan has built up too much dust. Try cleaning the CPU fan with canned air and a clean paint brush. Try to free the dust from the under side of the fan blades with the paint brush. You can also add a case fan or two. This will supply more fresh air and help keep the MB and CPU cooler. If you're MB is five years old or older it is a good idea to replace the thermal past between the heatsink assembly and the CPU. If you decide to replace the thermal past spend a little more and replace the heat sink assembly too. Socket 423 replacement; http://www.directron.com/cck7015.html#caption
Mike
Apr 19, 2010 | MSI MS-6339 Motherboard
Dell Inspiron 1525 keeps overheating and switching off.
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some
good guides here.
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on.
You may also want to remove the hard drive and ROM drive.
Take a
peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand.
To make newer laptops last longer between cleaning a good 3 fan cooling pad is suggested.
never use a laptop on soft surfaces as the ventilation can act as a mini vacuum cleaner and encourage dirt build up.
Soft surfaces also block the vents causing fans to run more and burn out sooner.
Hope this gives you the information you need
Nov 21, 2009 | Intel Cpu Core 2 Duo T8100 2.10Ghz...
Cpu high temperature problem
Overheating problem
Remove case side and clean all fans
remove fan from heat sink usually 4 screws or little clips
Do NOT remove heatsink stuck on with heat paste
clean vanes in heat sink replace fan
use stiff brush and vacuum cleaner to clean outside of power supply
vacuum out case include all vent holes
reboot computer should work ok
replace case side
Nov 29, 2008 | ASUS P5PE-VM Motherboard
About cpu fan prob
A noisy fan us caused by 1. dirt and dust built up -Remedy carefully clean the fan blades ,case and cooling fins, with a soft brush and vacuum cleaner nozzle. and 2 dry bearing. Remedy -carefully peel back the foil label in the centre boss and in the recess place a drip if light oil[3in1 or sewing machine- do Not Use WD40 this is a drying agent- will make things worse. Replace the label. It is possubly best to do all this with the fan off the computer- usually 4 self tap screws into the coolin fins and a 2 pint plug.
Jun 01, 2007 | Asrock 775i65GV Motherboard
Intel D945GTP Motherboard Logo
103 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
