Question about Toshiba 43A10 43" Rear Projection Television
Toshiba Rear Projection TV
Turns on makes a click noise , front blue light stays on , can hear slight sound from speakers as if no channel is tuned in , just blank screen , when i pull it out the power plug , a sharp bright light flashed through the center
No picture
Posted on May 26, 2008
I have a Toshiba 51h84.I push the power button and I get a solid red power light. There is a click from inside, kind of like a relay clicking on. No picture, no sound. If I leave it on I get an occasional...
Tv have "LAMP" indication LED light blinking?The tv projection lamp is dead,require changing.Hearing alot of clickings sound too?Mean the board,call the Ballast board is dead.Require change the Ballast too.The Ballast board,the board that help to ignite the projection lamp.
Aug 06, 2010 | Toshiba 51H84 51" Rear Projection...
Whenever i plug the unit in i hear a clicking sound from the back of the television it is for about 3 seconds and it usually takes 2-5 seconds before it starts the noise. The power light only comes on for...
Ur tv turn on now,hear alot of clicking?The tv LED light "lamp" on front panel flashes or light up?The tv projection lamp is dead.The Ballast board dead too,if hear alot of clicking?The ballast board help to ignite the projection lamp.
Jul 16, 2010 | JVC AV-56P575 56" Rear Projection...
No display or audio
I had the same problem after replacing several things and still having same problem, it ended up being a capacitor.
Jul 03, 2010 | Toshiba TP55H60 55" Rear Projection...
ICs + resistors swapped= blue power light auto on clicking noise
Unplug the power to the convergence board. If it turns on, you still have a problem in the convergence circuit.
Dec 16, 2009 | JVC AV-56P575 56" Rear Projection...
Convergence IC + Resistor swap = Blue light clicking noise
Good Day,
It sounds like you may have slightly diconnected a cable. Look for the large RED cable/wire that goes to the Blue tube and make sure that they are very secure. When doing this make sure the TV is off.
Good Luck, BIG IRISH.
Dec 16, 2009 | JVC AV-56WP74 56" Rear Projection...
52'' sony tv rear projection turns blue
it sounds like the blue crt is failing Pull the front off and turn the tv on
When it still has a good picture tap the blue crt
if it flashes blue with lines across the screen then you know it is a bad crt
It might not be worth fixing
Good luck
Jan 26, 2009 | Sony KP-57HW40 57" Rear Projection...
Toshiba tv-model tz55v61
If the red,green and blue mixture adjustment is what you want...
remove front lower speaker grill & access panel..locate RGB
adjust on Screen / focus block.......slightly adjust screen controls for best mixture....do not adjust focus controls.....T.
Jan 10, 2008 | Toshiba TZ55V61 55" Rear Projection...
NO picture no sound
blinks three times?, do you hear any clicking?
Dec 05, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba 65"HD rear projection tv
is the light flashing? Many things will cause a no power condition, might be shorted Convergence IC's, Z801 Ic could cause trouble, might want to call service man.
Jun 02, 2007 | Toshiba 65HDX82 65" Rear Projection...
Toshiba 43A10 43" Rear Projection Television Logo
125 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
