Samsung tv will the wii harm he samsung hd tv if we hook it up to it
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey tj1217,
The most common problem that may occur when you connect a video game console to a TV (especially front and rear-projection models) is a condition that is often called "image burn" or "image retention." This typically happens if the same image is left on the screen for a prolonged period of time, like when playing a video game that has many stationary images or if the game is left on pause for an extended period. In some cases, this may even be caused by test patterns, on-screen programming menus, or picture-in-picture boxes.
Before connecting your Nintendo Wii, I would first suggest checking the owner's manual for the TV itself to see if Samsung has any warnings or disclaimers against doing so. If you are unable to find your owner's manual or are unsure of what to do next, you may always contact Samsung directly for more information.
Should you choose to connect the Wii based on the manufacturer's suggestions/warnings, keep in mind that you can usually avoid issues like image burn by taking simple precautions such as turning the TV off when taking a break. The less time that the same images (or backgrounds) are displayed on the screen, the lower the risk is of image burn occurring.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on May 27, 2008
Got a brand new hdmi tv, hooked it up to wii, and the main screen is white, color is poor and cannot read anything
The resolution of your TV is over 720 pixels per inch (PPI)
The Nintendo Wii console can only handle 480 PPI
You may need to buy the adapter to hook the console to the HD components (R/G/B) instead of the standard composite (Y/R/W)
Here is one for cheap on Amazon:
480p HD Component Cable for Nintendo Wii
- Matt
Mar 01, 2014 | Nintendo Wii Video Game Consoles & Games
I have no colour and crappy picutre with my wii hooked up to ou samsung HD plasma. Any suggestion how to adjust this? Alos, I have a red,white and yellow wire that is attached with yellow into green at...
try something else for the Wii to see if the unit is ok, to be honest it sounds like it is not hooked up correctly but since not there I cannot tell from your description.
Dec 21, 2012 | Samsung HP-R4252 42 in. Plasma HDTV
WHEN I MOVED I LEFT THE WII IN TACT AND ONLY UNPLUGGED THE CABLES FROM TV. NOW WHEN I HAVE HOOKED IT UP AGAIN IT IS IN BLACK AND WHITE? WHAT DID I DO?
you did nothing wrong, i had a similar problem, but then i realized that i plugged the cables into the TV in to the HD Ports.... you need the Wii's HD connector cables for HD. sounds like you had a HD TV and just plugged it into the wrong ports.
try the other ports till you get what you want, or try buying the wii's hd cable, does not cost much if you buy from like k-mart or walmart.
Sep 13, 2010 | Nintendo Wii Console
Hello, when I connect my Wii to a Samsung 3D plasma tv I get a black and white (non-crisp) picture but I do get sound. When I do the same set up on a tube tv everything works. I tried the set up on...
a 3D tv is another form of an HD TV, you need the Wii HD cable to play it right, and make sure you plug it into the HD ports on the TV to get the color and sound back.
Sep 12, 2010 | Nintendo Wii Console
I tried to plug my 480P HD cable to my wii but, when i turned it on it wasnt showing right. The tv screen image kept sliding sidways rapedly or something like that. How do i fix it or can i fix it?
this happend to me when i took my wii to a frends,, he had a older tv and i have a hd lcd,, i had to hook it back up to my tv and change the video setings to get it to work on his tv..
hook it up to a newer/older tv [[the opposite of the one your useing now]]
and change the video setings,,
This happens on cracked wii's alot.
Mar 14, 2010 | Nintendo Wii Console
Having trouble with the colors on my WIi, everything seems yellow and there is no red anywhere
I just wanted to add that I recently bought a WII and I have the exact same problem. I have a Samsung HD TV and I bought the additional HD cable that has the multiple jacks (i.e. green, blue etc.) I will post if I find a specific answer to the probem.
Dec 24, 2009 | Nintendo Wii Console
I have a Samsung and just hooked up a Wii and am getting only black and white on the screen. How do I troubleshoot this? Thanks.
Your TV is probably an HDTV. Change the settings of your Wii to HD and it should have color. If you don't want to do that, make sure your RCA cables are pluged into the non-HD RCA slots on your TV and that the yellow cable goes to the yellow non-HD slot and not the green HD one.
Dec 14, 2009 | Nintendo Wii Console
Cannot get wii hooked up to our new tv HD
try changing cables use diffrent input output don't
forget to set dvr on right setting , AV, L1 ect
have you got manual , if you are realy desperate to fix this you can call 0403960527 jeff
Feb 16, 2009 | Sanyo DS31590 31" TV
No sound when Wii is switched on
DID YOU TRY PLUGGING YOUR COMPONENT CABLE INTO A SCART ADAPTOR FOR YOUR TV...THIS SHOULD FIX IT FOR YOU.... I TAKE IT YOUR TV IS A 5 SERIES OR A 6 SERIES SAMSUNG.. GREAT TVS HAVE ONE MYSELF, BETTER WHEN MORE CHANNELS ARE BROADCAST ON FULL HD BUT...
Jan 11, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
