Question about Lexmark Office Equipment & Supplies
I brought a second hand printer, which i saw works fine. I just got some ink and connected it up, but it wont install off the cd, only the reading documents are there. It is connected properly too. it is a lexmark Z25. the computer does recognise the device, but that it is not installed yet.
  • 300 Answers
How to reset ink level on my mx410
The question was for Mx410 but, below ya'll mention MX310. Is this solution for the MX 410 too.
Jan 10, 2012 | Canon Pixma MX410 All-In-One Printer
Printer ink
di u unplug it ?
and is there a reset on the printer some were?
try unplug it for five minites take the cartridges out and clean the termanials with some like cotton tip put them back in and turn on and then tell me what its doing
Sep 11, 2008 | Brother DCP 130C All-In-One InkJet Printer
Hi I brought some Wilkinson ink cartridges that are compatible with epsom T0715 for my Epsom sx210 printer. Everything worked fine, now after approx 2 weeks I'm unable to print as it keeps saying...
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
poor ink cartridge contacts.
May 10, 2011 | Office Equipment & Supplies
Kodal ESP 3 All In One won't print anything
There's only three ways this printer could not be working........
One way is .... that it does not have ink (sometimes kodak printers wont print unless both the black and color ink is above parr)
Second way is ..... it could be broken (which never happens to kodak printers, unless you hit them )
And the last way is .....the driver and the software is not installed ...therefore causing the printer not to print......
(See every printer has an installation cd...... On the cd is what they call a driver for the printer and also on the cd is a software that helps you printer/scan...etc)
Drivers for printers - Helps computer communicate with printer... (Drivers can be found at companies website under support and drivers or on installation cd)
software role for printers- Helps printers do they job.......
(Example. Lets say your printer does work, does have ink and does print.......If you don't have the software installed on the computer then the printer wont be able to scan pic and docs....thats the reason for the software sometimes or i could be worst if you don't have the software)
If you don't have the installation cd than...
Again drivers and softwares can be found at the companies website under drivers and support....
Please vote and rate....
Apr 04, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
My printer is not connecting wireless from my comp. I brought it over from my parents house to my new place and it wont work.
For installing a wireless printer on Windows XP, wireless router is an essential device.
Follow the recommended steps mentioned on the installation CD of the router, and set-up a wireless network.
Since several computers or laptops will access the printer, it is recommended to connect the wireless printer to the main computer through the USB port.
To begin the installation process on Windows XP, access the network setting in the Control Panel, and activate the file and printer sharing option in the LAN setting.
This will allow the operating system to recognize the availability of a wireless printer.
Now, click the Start button, go to Devices and Printers, select Add a Printer option.
Click the second option- Add a network, wireless or Bluetooth printer.
The computer will search for available printer and reflect it on the screen.
Click Finish; and the printer is ready to begin the printing process.
Jan 06, 2011 | Office Equipment & Supplies
The ink icon light is blinking
  1. Reset your printer if you are having communication problems with the computer. To do so, press the "Power" button to turn off the printer. Wait a few seconds and then power it back on.
  2. Power off the printer again if you are still running into problems and disconnect the power cable from the AC power. Wait a few seconds and reconnect the power cable. Power on the printer. This simple procedure resets the printer back to the default factory settings. Move to the next step if the reset does not work.
  3. Disconnect the USB cable from the printer. Insert the printer software installation CD into the CD-ROM drive on your computer and wait for it to automatically launch. Click the Windows "Start" button if it does not launch and click "My Computer. Right-click the CD-ROM drive with the disk and click "Autoplay to run the CD.
  4. Select "Setup" on the CD and select "Remove HP DeskJet 932c. The printer software and drivers are removed from your computer.
  5. Reconnect the USB cable to the printer. The installation disc automatically recognizes it and begins reinstalling the software and drivers.
  6. Print a test sheet to verify that the printer is now working. You can print a test sheet using a word processing application (e.g. Microsoft Word) or using the Internet.
May 13, 2010 | HP DeskJet 932c InkJet Printer
Need help with my printer canon MP190
I refilled my MP190 Black cartridge PG-37 by drilling a hole in the top (roughly in the middle) and using the syringe supplied with the ink refill kit. To make the printer work again, press and hold down the Stop/Reset button (on bottom right hand side of printer) for at least 5 seconds until the display reads 1 again. This bypasses the ink level detector and is explained in the trouble shooting section of the on screen manual supplied on the printer installation CD. It works. It then happened again with the colour cartridge, so I repeated the process. It worked again. This should also work for the PG40 and CL41 cartridges.
Apr 20, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Pg 40 and Cl 41 are too expensive
After you install the refilled cartridges and received the "you are out of ink" warning, press and hold the RESET button for about 5 seconds. Than a second time. The E-5 message should cleared.
Jan 19, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Dell 922 All In One Printer wont print
did you remove the seal of new catridge. bye
Sep 24, 2007 | Dell 922 All-In-One InkJet Printer
352 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
