Question about Maytag Heating & Cooling
Fan Stops blowing air
My Maytag air conditioner won't blow out any air. If I turn it to the fan only position, it sounds like it wants to start up (a little hum) and if I turn it to slow/medium/high cool (ac) that starts up fine, you can hear it, but no fan to blow it out. Is there anything that can be done?
  • DeeZaster May 19, 2008
    Yes this is a window unit, fairly large one too. I was suspected that the fan is stuck but I wanted to ask before I attempt to repair it, as I've never serviced an air conditioner before, I don't know where the fan is located, so taking off the front from inside the room or going outside and taking off the top. Its like this model here:
    I can't find the exact model # I have, I've misplaced the manual and havn't taken a look on the back of it, all I can read on the front is a little gold Diamond logo on the top right and it has two dials, left one for fan/cooling and right one for temp, no remote and also a slider for open or closed vent. I believe its 15,000btu, paid around $600 I think it was at home depot 6 years ago. I have a good knowledge of electronics, I've been working with car audio installations for over 10 years and also work on some house electrical installs, so I won't have a problem testing components, but as I havn't seen the inside of an air conditioner, would you start with the front off or work outside on removing the top/back casing? I won't be able to remove it from the window for awhile as its extremely heavy and don't have the help to remove it, so I have those options. The switch I'm sure is fine as it sounds like the fan wants to start up but is stuck, this happens in all 3 fan speeds, even all 3 cooling.
    Thanks for the help.
  • 50 Answers
Isthis a window unit? It sounds like it. There could be a problem with your fan switch or the fan motor itself? Multi-speed motors can lose one speed at a time. It really sounds like the fan motor is bad. If the compressor starts in the cool mode, and the fan doesn't, the fan motor could be locked up. See, if you can spin the motor by hand? If you can, then something is bad within the motor. Now, if the motor has a capacitor, check for a loose or burned wire. Good luck.
Posted on May 18, 2008
Why won't the air conditioner blow air?
The very first thing you need to do is to check for fuses or say faulty fuse. Secondly check fan which starts along with air conditioner, it might be manually switched off or the fan may have been clogged. Also reason can be lack of refrigerant - charge your air conditioner with refrigerant. Last thing you need to check is cooling coil - the cooling coil may freeze if there is no refrigerant in the system.
Jun 11, 2013 | Ford Explorer Cars & Trucks
My pacr10 blows air but compressor wont kick on
sounds like a blockage in the refrigerant circuit, the compressor is shutting down, protecting itself. possibly the compressor is overheating, possibly it's overcharged.
Oct 13, 2017 | Windchaser PACR10 Portable Air Conditioner
Maytag air conditioner turns on but fan does not blow. When I put the unit to fan only, I hear the hum of the fan, but no air coming out.
Either the capcitor has gone bad for the fan motor or the motor has siezed up or gone bad... you cold try to replace the cap. first and move on from there....
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
Aug 17, 2010 | Maytag M7D24E7A Air Conditioner
Hampton air conditioner. When I turn it on it blows out cold air but after about an hour the blowing stops.
Check your control setting if it is an electronic one. Check thermostat / thermistor. If the fan stops check the fan relay. Could be controller problem also. Take assistance from service provider.
May 26, 2010 | Hampton Bay HBLG5004 Air Conditioner
Fan Blower Makes noise
Sounds like the fan needs to be replaced. But first, to check for obstructions, remove the carpet liner from the underside of the dash on the passenger side and you'll see the blower motor under the dash held in with three screws. If there's something obvious blocking it, remove it and reinstall the fan. If there's nothing blocking it, then you'll probably need to replace the fan. Any auto parts store, or E-Bay will have the correct fan for your Grand Prix.
May 26, 2010 | 1998 Pontiac Grand Prix
Ac doesent blow air
If the fan is not working,then the fan motor is bad,or the start capacitor is bad.Pull the unit out so you can work on it,near the plug in.Be carefull,and use a stick,backscratcher,or something like that.Turn the ac on to cool,high blower,and turn the fan bladeclockwise to see if it will try to start turning on it`s own.Careful not to gouge the coils,and try to turn the fan reall good.If it starts,let it run,for about 15 minutes.If the fan,does not quit,then replace the start capacitor.If the fan wont start turning on it`s own,or the fan stops after a while,replace the fan motor.I hope this was some help.
Oct 06, 2009 | Frigidaire FAH106N1 Wall/Window Air...
AC Fan doesn't blow cold air, frozen coil noticed outside, resetting power resolves temporarily
You need to call a reputable service technician.  The freezing up usually is associated with a low refrigerant charge or low air flow.  Check your return air filter and replace as needed.
May 30, 2009 | Heating & Cooling
Is the fan blowing. If so your compressor is probably the source. If the fan isn't blowing you might have a bad fan motor
Jun 10, 2008 | Maytag M6P09S2ACOM Air Conditioner
Heating & Cooling Logo
323 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
