Question about HP Compaq Presario SR1300NX (PP195AA) PC Desktop
Not Loading when i turn on my pc and monitor, the black start up screen comes up and has options on how to start, safe mode, safe mode with networking, safe mode with command prompt. i tried all options, it then goes to the windows xp loading screen but just stays there like it is trying to load. I reset the computer, hit f10 to do a recovery, it then shows setting up for recovery the white bar goes across the bottom, then it goes to the compaq screen with the red dots/bar and stays on that screen. I ordered some recovery disc through compaq to try that. Is there something else that would be wrong with it?
  • 188 Answers
I m sure its some kind of maser problem with u r system...
because at the 1st time when u select safe mode it should work .....i think some big data dammage have made....and now u are unable to recover it....
so my suggession is that u can re install win xp on u r computer..
for any quarry u can mail me
Posted on May 18, 2008
I had accidently turned of the power as my PC was loading up , so then when i turned it back up it has come up in a black screen saying:- We apologize for the inconvenience , but windows did not start...
Now that PC works in Safe mode i suggest you to run the Disk Check.
Step1: Double click on My computer and then right click on C drive.
Step2: Choose properties and then click on tools option.
Step3: Click on the Check Now tab listed under Error Checking.
Step4: Select both the options under "Check Disk Option" then click on start.
Step5: It will prompt you to restart your computer.
Step6: The Disk Check gets initiated as soon as you your computer starts rebooting.
Step7: Allow it to finish.
Hope this helps.
Jan 15, 2011 | ASUS Eee PC 1000HE Netbook
My Dell monitor goes to sleep right after windows xp starts to load and it won't come on after that. my computer is still running but the monitor is a sleep. I have hit f8 and f12 with nothing happening....
Go into safe mode
Under settings, control panel, power options set "turn off monitor to never
I think this is not a sleep problem but the incorrect monitor settings were set. This will cause the screen to go black when the OS comes up. Boot in safe mode and change the display settings
to 640x480
in safe mode, delete your monitor. When you reboot it will load a default monitor and you should be OK
Oct 13, 2010 | Dell XPS 410 PC Desktop
PC monitor has blue USER MODE box that flashes and cannot get rid of it
The blue screen of death is incredibly frustrating. Windowsmag-glass_10x10.gif gives you an option called Safe Mode for whenever there is an internal Windows problem on your PC that needs to be resolved such as the blue screen of death or the display driver setting resolution is so low that you cannot navigate through Windows to alter the settings to a higher resolution. Safe mode allows the user to fix problems without these problems loading up.
  1. tep 1 Reboot your PC. If you can't restart normally by going to the start up menu, then hold in the power button for a few minutes. If you need to enter safe mode but can restart normally, do so.
  2. Step 2 After the hard drivemag-glass_10x10.gif mounts but BEFORE Windows starts to load, Press the F8 key repeatedly on your keyboard. If you do not get the menu with the safe mode option, then you did not begin tapping F8 soon enough. Try again.
  3. Step 3 There will be a menu that will appear. Select Safe Mode. Once you are in safe mode, you can fix what needs to be fixed without the problems loading up on your machine.
Nov 13, 2009 | LG Flatron L1715S 17" LCD Monitor
Hello I wonder if you can help. When we switch
Had a similar problem like this several times. Try choosing safe mode. Safe mode will load the required drivers. After safe mode finishes the loading process, restart your computer and choose to start windows normally. The problem you mention usually happens when the computer is turned off without using normal shut down procedures. Also happens when you have a sudden power outage.
Oct 24, 2009 | Computers & Internet
Windows xp will not load on my computer....
It could be your hard drive problem. Which I called it, "Crash." I would suggest you try to format the hard drive and reload the operation system with your installation CD.
Jul 22, 2009 | Acer Aspire™ T180 PC Desktop
HP 2133 PC Notebook Black Screen
win32corrupted boot sector try recovery cd which come along with ur laptop
Jun 06, 2009 | HP 2133 Notebook
Dell desktop running windows XP
You should be left-clicking when the option for safe mode comes up...
Dec 15, 2008 | Dell Inspiron 8500 Notebook
Computer will not load.
use safe a disc clean, defrag..and then reboot...sounds like the operating system headers went unhappy when you moved it(which I highly recommend you NOT do again)..
May 25, 2008 | Acer Aspire E380-UD420A (ASE380-UD420A)...
HCL Monitor type HCM580M display problem
Information about the Linux / UNIX less command. Thus, various display problems may result, such as long lines being split in the wrong place. -R --RAW-CONTROL-CHARS, Like -r
Device Manager information and help This section will also display what COM ports are detected; for example, ... CODE 13 - System Failure - Possible problem in Device Driver or Windows 95 Code.
Good Luck, Please dont for get to Vote, Thank You.
Dec 19, 2007 | Computers & Internet
HP Compaq Presario SR1300NX (PP195AA) PC Desktop Logo
135 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
