Question about Roper RAS8445KQ Top Load Washer
Roper top load problem
1. Where do I find the model #
2. My machine will not spin. It just sits and makes a humming noise
3. Is there a place in my area that repairs this? Is this costly?
I live in Wyoming Mi. 49509
  • 246 Answers
The model number is usually under the lid on the machine towards the rear of the opening where you place your clothes. For a humming noise, I would first pull my washer forward and tilt it back about 45 degrees resting the top against the wall. I would look up at the front, center for the white peice of plastic. That's your pump.There is a clip on the top and on the bottom of it that will slide off (with a fair amount of pressure). After they are off slide the pump forward so it is not on the motor shaft any more. Now tilt the machine back down and try spinning it again. Does it still hum? Yes - probably bad contacts in yout timer and you need to repalce your timer. No - probably something stuck in your pump keeping it from turning. Disconnect the black hoses and drain the remaining water out. Look into the holes on the pump to see if you can remove the forign object.
Posted on Jun 15, 2008
The spin cycle is making a terrible noise - the drum seems very loose and even makes a starnge sound when moving it by hand. Can I repair this myself?
If this is a Whirlpool manufactured TOP LOADER (such as Roper, Estate, Kenmore, Amana, and Frigidaire), you may have a damaged or broken motor coupling. Whirlpool manufactured top loading washers use a motor coupling between the drive motor and gearcase (transmission) in place of a drive belt. This configuration is known as "direct-drive". The coupling can break through normal wear and tear. Washing frequent loads of heavy items and reduce the life span of the coupler. Common symptoms include the following:
1. No spin or agitation.
2. Washer will fill and empty.
3. Drive motor still runs.
4. Strange rattling, grinding or clicking noise during agitation or spin cycles as the drum sits still.
If your washer is exhibiting these symptoms, then its probably a safe bet that the motor coupling is bad.
The following link explains how to replace one:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The part number for a replacement motor coupling is inlcuded in the link I provided. Replacements can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I have listed also included helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need.
Jun 02, 2011 | Samsung SW62ASP Top Load Washer
Won"t spin or agitate. Makes a loud rattling noise
repairclinic.com
If you have any questions, please post back with your complete MODEL NUMBER (located on a nameplate along the wash tub rim under the lid) and let me know. I hope this helps you.
Dec 17, 2010 | Kenmore 24032\24036 Top Load Washer
The washing machine model # RTW4340SQ0 makes a humming noise
Roper is a division of Whirlpool and your machine is still under warranty if only a few months old. You should be able to find a factory authorized service company in your area.
Mar 30, 2009 | Roper RTW4300SQ Top Load Washer
My roper wont do anything
Is you washer sitting on a carpeted floor? If so ther is not enough air flow under it for the motor to not overheat. Maybe by now 4-3-09 it's functioning if not post me your model number. If it's on carpet raise it up with 3/4 inch boards under the feet.
Mar 09, 2009 | Roper RAS8445KQ Top Load Washer
Roper RAS7233KQ0 NO SPIN
chek the water elctrovalvles and replace it , this most be 1 solution another will the hyperstatic hose or sensor of load size
Mar 04, 2009 | Roper RAS8244KQ Top Load Washer
Roper wash machine ras7133kq1
no theres something in your pump,,it up against the impeller in your pump.....onthejob
Jan 31, 2009 | Roper RAS6233KQ Top Load Washer
My roper washer won't spin
Sounds like transmission went out. Very costly to have repaired. Best buy a new one, like I did.
Dec 21, 2008 | Roper RAS6233KQ Top Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
60 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
