Question about LG WD-14124RD Front Load Washer / Dryer
PE error code on LG WF-T653A
You guys are great and this site is amazing and saving many a person 100's of $ when sometimes it's just a simple part that needs replacing. Anyway - I have an LG top loader Fuzzy Logic WF-T653A machine that has a 'PE' code coming up about 10 seconds after turning the machine on. I have looked through as many problems of other people's before I bothered you and I saw another person had an 'LE' code problem, could it be the same problem? Many thanks for your help.
  • Anonymous Mar 15, 2014
    WF-T6517TCT LG
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
PE is a pressure switch problem. Could be a bad switch or it could be that the hose is plugged. The switch looks like a diapharm switch and is located on the main board. It has a black hose that connects under the bottom of the tub. See if that end is clogged. Otherwise you may need a new switch.
Sgt 48
Posted on Jun 02, 2008
    Problem Solver:
  • 6 Answers
Model: WFT8501
Country: Canada
Error Code: PE
I am new to this forum. I followed the suggestion above and blew down the clear, plastic tube, and turned on machine, and walllla, it worked. My wife was amazed. Can\'t thank this forum enough and all the people who posted suggestions and helpful hints.
My machine was working just fine two days ago. Today, it showed PE code and it showed right at the get-go, no water, nothing worked, just PE and the beeping sound.
Hope this helps.
1. Unplugged the machine. Meaning not connected to the wall sockets.
2. I took two screws in the front off
3. I took two screws in the back off.
4. Forgot to unscrew the hose connecting to my sink. So I did that.
5. For my machine, model number above, the round unit is located on the far left side, left to me as I am standing and working from behind the machine.
6. The unit is round, perfectly round, and it is about 2 inches big, maybe 2.5 inches. It is connected to a plug, when unplugged, there are three wires.
7. The unit is sorta loose. This tells me there must be an easy way to remove it.
8. On top of the unit, there appears to be a screw, and it looks plastic-like. I initially wanted to use my screw driver on it, glad I didn\'t.
9. Look closely at the rounded part, it should have three tiny plastic (the whole thing is made of plastic and the ring around it, is also plastic), but upon closer inspection, you will find three little plastic groves, that is designed to hold the unit in place, I bent the plastic parts back, there are three but I only needed to do to two of the plastic prongs and that is all is required to pull the round unit (Pressure Sensor) right up and away.
10. Unit is connected by plastic, clear hose and maybe some other wires, so you can lift it up but not completely, as it is still tied down.
11. You will see a small metal clip, that holds the plastic tube to the Pressure Sensor, use small needle nose. Remove plastic hose, blow down it. Put it back.
12. I didn\'t even put the back cover back on. Just wanted to make sure it works first.
13. I did put the two screws in the front back though. After all the machine will be spinning and doing things at high speed.
14. As I write this, I can hear my beautiful LG humming in the background.
Again, with gratitude. Glad I found the answer and glad I joined this community. Will be posting more in the future.
Posted on Oct 25, 2014
Is making loud noise when the water is draining and spinning
Posted on Oct 31, 2009
Lg wf-t1022tp gives a PE error code.
Try this first before replacing any parts or disassembling your LG washer:
- Unplug the washing machine for 1 minute.
- Plug the washing machine back into power.
- Restart the wash cycle.
- The washing machine may now have cleared the PE error code, if not see below...
You will need to check the wiring harness that connects the water level pressure sensor to the main control board.
- Check for a loose wire harness, a damaged wire harness, or a burnt faulty wire.
- Check that you get continuity through the wire harness by checking it with a multimeter.
- If the wire harness from the water level pressure sensor to the main control board is found to be faulty, replace it.
- If you get continuity and the wiring harness is securely connected to both the water level pressure sensor and the main control board, then proceed to the step below...
LG WASHER PE ERROR CODE - FIX METHOD #2
Water Level Pressure Sensor Switch Is Faulty And Needs To Be Cleaned Or Removed And Replaced.
Most commonly, if the wire harness is secure, tight, and not damaged, the part that needs to be checked is the water level pressure sensor.
- First check to be sure the water level pressure sensor is not caked with hard water or other debris.
- If the water level pressure sensor is not clean, the PE error can display.
- Remove the water level pressure sensor from your LG washer and clean off any hard water or debris.
- Clean out the tube that connects to the
- If you found the water level pressure sensor was caked with debris and you have cleaned it, replace it back into the washer and run a test.
- If the washer runs without the PE error code displaying, the washer is fixed and the PE error has been cleared.
- If you find that the water level pressure sensor is faulty, remove it and replace with a new OEM part.
lg-electronics-washing-machine-water-level-sensor-pressure-switch-hth0u4ums0hor52ud1sodlv4-2-1.jpg
Replacing the water level pressure sensor simply involves locating the sensor in your LG washer. Remove it from the washer and replace it with a new genuine LG washer part. Test washer to be sure the PE error code has cleared and the washer is now working properly
Mar 20, 2017 | LG Washing Machines
Fault PE....How do I replace the pressure sensor on an LG fuzzy logic 5kg wf-t502 top loader and where can I purchase this part?
PE Means pressure sensor error this spares is very rare to defect 1st check full pressure sensor the wiring harness any damage or wire cut means the error will show in display
Mar 26, 2015 | LG Washing Machines
Lg intellowasher wf t8501tp
My washer WF-T8501tp shows a PE error code.
Can anyone tell me what's wrong with it
Nov 17, 2013 | Washing Machines
My LG Fuzzy Logic WF T653A machine deposits little black unknown deposits on my clothes after every 2nd or 3rd wash, they look like little bits of black wet paper ?? some-one said to change the lint bags,...
Its called scrud.
Solution is to use a couple of quantum dishwasher tablets on a hot empty heavy wash.
Doing this on advice from an LG rep. May need to repeat it 3 times.
Brendan
Mar 24, 2013 | Washing Machines
Error PE on model wm2016cw, is this an easy fix?
Error Code PE mean Pressure sensor Error code
Check wiring connection to the pressure sensor; to solve it replace pressure sensor. The sensor repair is simple and straight forward.
Additonal details could find in this link: LG_Knowledge_Base
Hope this helps.
Aug 02, 2011 | LG Washing Machines
Whenever i given its shows error peep sound ,its indicate error worrd -PE
Hello, LG Washing Machine Error Code "PE" -Pressure sensor error code -Check wiring connection to the pressure sensor. -Replace pressure sensor The sensor repair is simple and straight forward. If this helps please rate me thanks..
Jun 08, 2011 | Washing Machines
What is the problem if the LG Fuzzy WF-T1330TP top loader shows error code PE.
Pressure Switch faulty.
Replace with P/N: 6501EN1001A
Reply if you need directions for removal & installation.
Good Luck!
* If you found this solution helpfull, please rate with 4 thumbs up & a testimonial.
Apr 08, 2011 | LG Washing Machines
MANUAL FOR LG WASHING MACHINE, MODEL NUMBER WF-T653A
You can get the manual on the link below. Just click on where it says it is free top right.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T653A-_E
Good Luck and please rate 4 thumbs up for the free answer
Sep 06, 2010 | Washing Machines
LG WD-14124RD Front Load Washer / Dryer Logo
2,040 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
