Question about Maxtor Hard Drive
Maxtor dimond 21 hard drive
I have just bought a maxtor diamond 21 hard drive . when i connected as per instuctions it came up failure to boot any idea's please.
  • Eric Smale
    Eric Smale May 11, 2010
    Is this a replacement hard drive because your boot drive failed? If it is, you need to put on your operating system. If you are using this drive as just more space (storage), then you have hooked it up so as to make the computer think its the boot drive. Did you make it a slave? or is it hooked up as master?
Problem solved .didn't know i had to press f2 as soon as bios appears to enter setup.also used bootable disk to load windows.
thanks any way.
Posted on May 19, 2008
Need maxtor Diamond 21 320 gb slave setting
Take a look at this pdf:
So If this is layout " : : : . : "
slave -----------
master -------- " [:]: : . : "
cable select -- " :[:]: . : "
Jun 23, 2012 | Maxtor DiamondMax Computers & Internet
How do I install my320 GB Diamond Max 21 internal Harddrive setup as a external drive with USB 2.0 to computer, The S/N is 9QF09BA4, STM3320620A and firmware3.AAE Date Code is 07143. I have two that I...
I am unsure if you are trying to take a currently external drive and mount it internally, or if you are trying to make an internal drive into an external. Please clarify.
Feb 13, 2011 | Maxtor 7L320S0 320GB 7200RPM 16MB SATA/150...
Need jumper settings wd800 as Mast. & maxtor as slave??
To use the WD 800 as a master there must be no jumper attached to it.The maxtor has a diagram for the jumper and it MUST be set to slave not cable select.
Mar 24, 2010 | Maxtor DiamondMax Plus 9 160 GB Hard Drive
Jumper settings
25870e5.jpgCheck this diagram. it shows all configuration in detail..
good luck!!
Jan 02, 2010 | Maxtor Hard Drive
Maxtor one touch 4 mini suddenly not recognised by any PC
I am sorry to be the bearer of bad news but you are describing a hard disk failure.
Maxtor, Hitachi and IBM disks have unusually high failure rates. I have replaced hundreds of these disks.
I recommend replacing with a Seagate or Western Digital disk.
If this helps please vote for my solution.
Sep 14, 2009 | Maxtor Hard Drive
Maxtor slave jumper settings
Find the jumper settings for the maxtor harddrive on the following link. As per the model number you gave ,it seems like you have the maxtor diamond max drive.
Nov 29, 2008 | Maxtor Hard Drive
Can i use this maxtoe diamond max 21 500 gb drive for a c drive i am removing a 80 gig that is defective
If you mean remove your old 80 gb drive and replacing with the Maxtor 500 gb drive you should be able to. The Maxtor 21 series is equiped with SATA. Just make sure that your computer can run SATA. If not, I believe that there are adapters out there.
Oct 01, 2008 | Computers & Internet
Maxtor 500 gig internal diamondmax 21
external USB hard drives do not need to be jumpered, if your computer does not recognize the ext. drive probably it is because the enclosure is defective, when you connect the USB cable you should get the "ding-dong" connection sound.
If you think that your computer recognizes the hard drive then jumper it as "secondary" or "cable select" and install it INTERNALLY, then transfer your data, that will prove that there's a problem with the ext. enclosure.
One more thing, maybe the USB port you use is malfunctioning, try one that you know that works (assuming that you have other USB devices that work).
May 04, 2008 | Maxtor Hard Drive
Maxtor Hard Drive Logo
93 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
