Question about Samsung HLN617W 61" Rear Projection HDTV
Samsung 61" DLP TV color issue
I've had my Samsung 61" DLP TV for over 3 years and after 1.5 years i noticed on occasion that i would lose all red and pink color suddenly which would leave the screen looking very green. A simple turning the TV on and off would fix the problem most times. After seeing the problem for a few months it went away for a good 6 to 9 months now the same problem has returned, worse then ever meaning most times when the tv is turned on it starts with no red or pink and tuning the set on and off does'nt fix the problem anymore. At times i also noticed the red trying to come back with visual flickering but for the most part the past 2 months i'm stuck watching Movies and TV with a green tint that i can't change or get rid of no matter what i try. Any suggestions on what happening and what i can do to fix this problem?? Thanks Jay G.
  • Samsung Master
  • 8,617 Answers
The color wheel is either defective or needs to be re indexed.
Posted on May 21, 2008
Is it possible to have only the red tint projector lamp replaced on 61" projector Samsung tv
No. This is a DLP TV. It gets it's color by a color wheel. If color seems to drift across screen or there is a loud-ish whining noise from back of TV that you can here clear across a room, then this color wheel may be bad. They wear out.
Jan 07, 2015 | Samsung HLN617W 61" Rear Projection HDTV
DLP TV 61 inch TV
It sound like the set has a red CRT down. I will get a manual and post it to here soon for you.
Mar 08, 2008 | Televison & Video
Have a 61" dlp samsung tv, making a humming sound
Bad Color Wheel.will cause this and it is a common problem for DLP Samsungs.
Part number is BP96-01103A
Samsung Parts 1-800-627-4368
Jun 24, 2011 | Samsung HLR6178W 61" HDTV
Colors are flashing green and yellow and red
Try a power cycle and unhook all your devices from the back. Plug all them in separately and see which is causing the issue. Otherwise, call Samsung and see if you still have warranty on the tv
Mar 12, 2011 | Samsung HLT6187SAX 61" DLP HDTV
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W DLP 61" TV only show green color
BINGO! Light Engine, Maybe listed as- Assy Engine Go to website Encompass Parts Distr their you will find what you need or Call 1-800-638-3328 ,or Try UED 1-800-648-6657
Dec 01, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Samsung 61' DLP Color problem.
If you are using Component inputs, check to make sure that the Blue Video Cable has not backed out of its connecting jack at either end or the cable it's self being bad. If you are using HDMI I would suspect that the Digital Board being bad. It would be odd for the Color Wheel to cause the problem but cannot eliminate it as a cause. The Lamp would cause the picture to be darker but not cause a color to drop out.
I would call a professional to trouble shoot it unless you have the knowledge and the tools to do so.
Hope this helps,
Jul 04, 2009 | Samsung HL-P6163W 61" TV
Samsung 61 inch DLP Has a strobe light affect
possible color wheel,call for est cost of repair
Jul 29, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Mar 26, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Buzzing Noise
Set has a defective color wheel. This needs to be replaced and your tv will go back to normal.
Jan 07, 2008 | Samsung HL-R6167W 61" HDTV
Samsung HLN617W 61" Rear Projection HDTV Logo
545 people viewed this question
Jerry Greenberg
Jerry Greenberg
