Question about Dell OptiPlex GX110 PC Desktop
GX270 Problem started out locking up at mup.sys and giving an Thermal event error. I did the following: 1. Replaced the fan. 2. Removed CMOS battery for 15 minutes. 3. Reinstalled XP 4. Ran CHKDSK (from repair console). Now it won't boot up. Won't get to post. Acts like it wants to start (fan starts, HD SOMETIMES acts like it wants to start) but will not start. Was able to get it going for a few seconds and then nothing. HELP! mhclupe@gmail.com
  • Roberta Smith
    Roberta Smith May 11, 2010
    when you boot .... look at the list of devices... you can hit the pause key when you get to that point.... does it recognize the hard drive properly ?
    it also appears to be a hardware related issue.... if you have a way check your power supply. also some nvidia related issues can cause this problem
    Robert
Thanks for the response but I figured the problem out a couple of months ago (it was the mb).
Again, thanks for your response.
Regards,
Lupe
Posted on Sep 02, 2008
Why is my Sony VAIO VPCEB33FM green power light flashing?
It won't be the cpu. If it was, nothing would happen. I would look for a GPU issue, possible over heat.
Jan 01, 2015 | Sony Vaio Vpceb33fm
Previous CPU Fan failure
You have me at a loss
"Previous CPU fan failure", and What?
1) Was the Processor fan replaced?
2) Was the top of the Processor, and bottom of the Heatsink properly cleaned, and fresh, new Thermal Paste PROPERLY applied?
3) Is there a CMOS Error Code stored now?
4) Will Mary ever find true love, and will Biff return home?
Just wanted to see if you were following along
Clarify further as to what the problem is.
Post back in a Comment.
Regards,
joecoolvette
Mar 07, 2013 | Dell OptiPlex 760 PC Desktop
Thermal event won't ever allow computer to boot at all
"Computer unplugged from power, press the Power On button in, and hold it in. Hold it in for a count of 10 seconds. let go. Do this procedure two more times. (If the Power On LED lights up, do it again) What you are doing is clearing CMOS Error Codes. Check the Processor fan, check the Thermal Paste. Cheap as Thermal Paste is, and what it does for a job, best advice is to simply replace it. Need guidance post back in a Comment. Before beginning make sure the computer is unplugged from power, and you are FOLLOWING Anti-Static Precautions. Regards, joecoolvette"
Brian Packard;
"I cleared CMOS a few times (has jumper on board too) and even put new thermal grese on it....what finally did it was taking out the CMOS battery. As long as it's outl it works just fine, putting it back in causes an error again. Thank you all for your time however and I hope this post can help somebody else too."
Aug 20, 2012 | Gateway 507GR PC Desktop
I have a Dell GX270 running Win XP Pro SP3. Couple of days back when I started the computer, it gave me an error message which says "Thermal Event and so fort". Press F1 to continue and F2 to run...
Yes system board capacitors near the processor that have bulges and are leaking are signs of burnt out capacitors. This can cause a computer to randomly freeze. My Computer was checked by a dell certified tech that had similar freezing options.
Please replace the motherboard and make sure when installing the processor you use thermal paste and use an anti static wristband so that you don't by accident burn out any other components.
May 06, 2011 | Dell Optiplex GX270 Intel Refurbished...
Hi there, So, my problem is the following: My pc worked well until i changed my cpu cooler, it didint turn on, i hear only two short bips after i pushed the turn on button (during this the leds are...
Sounds like the CPU may not be seated properly, did you remove the processor when you replaced the cooler (Heatsync I assume you mean)?
Try powering down and unplugging. removing the heat sync removing the processor. Re-seating the processor making sure it falls into place. then re add the thermal paste(if needed) and heat sync. Check the memory and video card to make sure they are firmly in and then power back on and see if it will boot.
Another thing you can do is check your motherboards manual or website and there is a description of "beep codes" that you can listen for yours and see exactly what its telling you is wrong.
Good luck
Jan 24, 2011 | Gigabyte Core 2 Quad Intel X48 FSB 1600...
Thermal Event
This is likely one of the following:
1) the thermal paste under the fan is dried up and needs to be redone
2) The case needs to be blown out of accumulated dust
3) the motherboard has an electrical problem (old capacitors failing etc.)
It could be all 3 issues.
If you are somewhat skilled the first 2 are easy.
The last one can be fixed in many cases
Aug 06, 2009 | Computers & Internet
Dell opteplix gx270 problem
It is either dust build up on the CPU heatsink under the fan or that model is known for blown capacitors...
Open case and check motherboard for blown capicitors and / or dust build up on CPU heatsink
And if there are any bad capacitors then you will need to replace the motherboard.
Sep 10, 2008 | Dell (4T274-DE) Motherboard
Error 10E716045D
When I first trying system recovery the recovery would complete and when rebooting it hang at mup.sys in the drivers, now I get this error 10E716045D.
Toshiba A105-2716
Apr 18, 2008 | Toshiba Computers & Internet
Power
You might have to change your power supply..(ex:SMPS or ATX)
Oct 23, 2007 | Dell OptiPlex GX270 PC Desktop
Dell OptiPlex GX110 PC Desktop Logo
145 people viewed this question
Alun Cox
