Question about Dryers
  • 2 more comments
  • lupa Jun 17, 2008
    everything seems to work fine but there is no heat, the drum spins with clothes in it but there is no hot air. I have taken the back and top off to look for obvious problems like loose wires or any damage but everything seems good
  • mattsletten Dec 06, 2008
    i replaced the thermostat and the heater regulator but it still dose not heat.
  • Fixer210 Dec 12, 2008
    just want ot clarify that I need to replace the theramal cutout and it is located in the back and I must unscrew the entire back to get to it , is that correct?
    I see a cover in the front botttem but I'm not ure if and how that would come off.
    My Model # is 110-79912990
    Type DDOT NAT 1206006CV22
    Thanks for your help
  • Brinson_Fam Jan 25, 2009
    I have a Frigidaire front load electric dryer Model FER211A that has stopped heating, the dryer will tumble the clothes but it will not heat. Is there anyway I can fix it?
  • 550 Answers
Most dryers have a thermal cutout, a non-resettable overheat protection, take the model and manufacturer details to your local repair store and you can buy one easily.
then its, take off the rear plate, and trace the exhaust air ducts back till you find an identical item screwed to a duct, unplug its connectors screw the new one in place, plug in the connectors.
Exact info cant be given as you did not tell what make and model the affected dryer is
Posted on May 18, 2008
My Gas Dryer WhirlPool Model (LGR4634JQ2) Stopped Working One Day In the first time in FIVE
YEARS.Was NO Heat and no flames in the pilot,But the drum was running with no heat.I have a solultion To help you with this.
First take the excaust pipe then take the black back panel with a couple screws (6's screws. Find The White Fuse On The Black Box Heater (On The Left Side). The Fuse Looks Like Plastic White (About An Inch And A Half)
With the two wires.The numbers repair guide (Number six) Part number-(3392519)
Replace for new. You can check the fuse in the car battery with the fuse tester TOGETHER.
Hopes this helps you ! Enjoy!
Posted on Jan 04, 2009
Dryer won't dry clothes
Heating element faulty not giving as much heat as it should
Nov 14, 2015 | Dryers
Kenmore Gas Dryer does not dry clothes.
If this is the electric version then after 15 years you probably need a new heating element, they are not difficult to install and are not terribly expensive as a DIY project.
Jan 12, 2013 | Dryers
I have a maytag dryer DE882. The dryer blows warm air but does not dry clothes. Any ideas what could be the problem.
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 18, 2012 | Maytag Dryers
My dryer is not heating the air clothes are rolling and air seems to be blowing but the clothes are damp when cycle ends and they are not warm. what do i need to fix this?
if the clothes are damp then I would disconnect the vent tube, and dry a load of clothes. If they are dry then the vent needs to cleaned. Hope this helps Tim
Feb 06, 2011 | Fisher and Paykel DEGX1 Electric Dryer
I have a Roper gas dryer (RGS7646KQ2) which is not heating up to dry clothes. The drum turns and the timer works as well. It appears to be acting normally, except it is blowing cold air instead of warm...
You have a bad thermostat, flame sensor, thermal fuse, gas valve solenoids, or the high limit thermostat. Below is a video to walk you thru the diagnostic testing and repair.
Jan 03, 2011 | Roper RGS7646KQ Gas Dryer
I have a Whirlpool LGN2000PW gas dryer. The dryer will heat up when it is first started and get warm, but after a few minutes it cools right back down. We removed all the duct work in the basement leading...
if it still quits heating after a minute or so then its either a weak cycling thermostat or moisture sensor thermistor,both located on the blower housing, or the moisture sensor bars located near the door opening on the dryer,or it could be a high limit thermostat thats bad on the burner tube itself
Oct 14, 2010 | Dryers
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
No heat coming from dryer
Double check the circuit breaker for the dryer (Electric Neptune). Turn it off, then turn it back on. Its possible that the breaker may have tripped for some reason, but wasn't able to trip all the way.
Does the interior of the dryer get warm at all? You could have a 1 of multiple heating elements that has shorted. If no heat at all, the likely a heating element has opened up. Unplug dryer from wall (turn off circuit breaker first!). Use a ohm meter to measure and check continuity of the heating elements.
There may also be a sail switch in the air path of the dryer. The purpose of the sail switch is to keep the elements turned off until there is enough air blowing through the dryer. This helps prevent fires, as well as shrunken denim.
Jan 04, 2010 | Maytag Neptune MCE8000AY Electric Dryer
Model DLE7177RM, takes about 3 hours to dry a load of clothes. Dryer is NOT overloaded.
Does the dryer heat up or is it just cool air drying the clothes ? If it does actually dry the clothes eventually then it sounds like it is heating up. First thing to check would be exhaust hose. Is warm air blowing out of it ? If warm you got heat. If cool then your heating element isn't working. It should be fairly strong current of very warm air. If weak but warm, then somewhere between lint filter and end of hose you have a blockage caused by lint buildup or hose is bent and blocking air flow. Check hose first. You can disassemble lint trap and go beyond the lint screen into metal duct within dryer and clean with a long brush and vacuum. You can also disconnect exhaust duct flexible hose at back of dryer and work through metal duct from that end too. If you notice increased air flow then it should solve problem,
Aug 05, 2009 | LG Dryers
The dryer will not heat up to dry clothes
youve probably got a bad heating element, also make sure air is blowing out back of dryer to the outside of house if its plugged it will cause element to break good luck
Mar 23, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Dryers Logo
805 people viewed this question
Top Dryers Experts
