Question about Sharp AL-1217 Copier
Corpier will not respond to any of the controls
Continuous display of 4 and H
  • claire623 Oct 14, 2008
    does not respond to any control and it flashes CH, I just changed the toner by the way, please help
No it's not doing a thing, it still flash CH and does not respond no matter what I do. Sharp AL - 1217
Claire
Posted on Oct 31, 2008
Minolta Photocopier EP 2030 Internal setup code such as Sharp al1217 C-photo-C-photo
please help me
    New Friend:
    Problem Solver:
  • 8 Answers
RESET TROUBLE C-PHOTO- C-PHOTO-14-P
Posted on May 18, 2008
TEMP dISPLAY
No, according to the following video, there's no way to keep that display on. This is a general video for all their side-by-side units:
http://link.brightcove.com/services/player/bcpid1910171499001?bckey=AQ~~,AAABAWGODxk~,hLHEX2tm6AFlgSDzRIBPGX7yjI__nHLT&bctid=1970389062001
Dec 19, 2013 | GE GSE26HSESS GSE26HSESS 36" EnerStar 25.9...
I have f150 kingranch 2005 ...i have two problems 1)the 4*4 will not engaged regardless of the rotary elect sw postion no sound under and no light...2)the ac when i switch it on the compressor will run but...
The 4WD issue
Operationally vacuum holds the IWE ( Integrated Wheel Ends ) out, and once vac is removed the spring engages the IWE.
Lift and support the front of the truck so the front wheels are off the ground ( take safety precautions, chock wheels, jack stands, etc )
Key on, engage 4x4 and try to turn the front drive shaft.
If it turns it is a problem with the transfer case.
If it doesn't it is a front axle engagement problem.
- If the front drive shaft does not turn :
Shut of the truck ( still jacked up, and supported ) remove the vac lines from the IWE. The spring should push the gears in, without the vac line on.
Check the vent line ( tube that is routed into the engine compartment with nothing attached to it ), for blockages.
If the vent line is clear, and with the vac lines off the IWE should be engaged ( both front wheels locked ).
If they lock, the problem is with the IWE solenoid not shutting off vacuum to the IWEs. There is a TSB on the 2004-2006 IWE solenoids, a newer revision has been made, and used from 2007 and newer MYs.
Here is a block diagram of the IWE system
The fan issue, is this just with the AC or with the heat / vent also ?
The KR has the EATC ( Electronic Auto Temp Control ) HVAC system, so the blower motor speed is controlled by the Front blower motor speed control. This is mounted where the Blower motor resistor is located ( for the EMTC HVAC ) and could be the cause of the issue.
Try the EATC self test :
Electronic Automatic Temperature Control Module On-Demand Self-Test The EATC module on-demand self-test will retrieve on-demand (hard fault) DTCs only, it will not retrieve continuous DTCs. Continuous DTCs can be cleared when exiting the EATC module on-demand self-test. Make sure to retrieve continuous DTCs by carrying out the Electronic Automatic Temperature Control Module - Retrieve Continuous DTCs procedure before clearing any continuous DTCs.
•The EATC module on-demand self-test will not detect concerns associated with data link messages like engine coolant temperature or vehicle speed signals. A diagnostic tool must be used to retrieve these concerns.
•The EATC module on-demand self-test will detect concerns in the system control functions and will display on-demand (hard fault) DTCs for concerns that are present during the self-test. The vehicle interior temperature should be between 4°-38°C (40°-100°F) when performing the self-test. If the temperatures are not within the specified ranges, false DTCs may be displayed.
•The self-test can be initiated after cycling the ignition switch from OFF to ON. Normal operation of the climate control system stops when the self-test is activated.
•To enter the self-test, press the OFF and DEFROST buttons simultaneously and release, then press the AUTO button within 2 seconds . The display will show a flashing blower icon for 20 seconds , after which all vacuum fluorescent segments will be displayed if there are no on-demand DTCs present. If DTCs are present the EATC module will display "00 00" and then on-demand DTCs. Record all DTCs displayed.
•If any DTCs appear during the self-test, carry out the diagnostic procedure. Refer to the Electronic Automatic Temperature Control Module Diagnostic Trouble Code Index and follow the ACTION for each DTC given. See: Diagnostic Trouble Code Descriptions
•If a condition exists but no DTCs appear during the self-test, GO to Symptom Chart Condition: The EATC System Is Inoperative, Intermittent or Incorrect Operation. See: Symptom Related Diagnostic Procedures
•To exit the self-test and retain all DTCs, press any button except DEFROST. The EATC module will exit the self-test and retain all DTCs.
•To exit the self-test and clear all DTCs, press the DEFROST button. The EATC module will exit the self-test and all DTCs will be cleared.
•Always exit the self-test before powering the system down (system turned OFF). Once the self-test is exited, the ignition switch must remain ON for at least 30 seconds to allow the door actuators to automatically recalibrate.
•Continuous DTCs will be deleted after 80 ignition switch ON cycles after the intermittent fault occurs.
The EATC module will retrieve only continuous (intermittent and hard) DTCs when carrying out this procedure.
•Retrieval of continuous DTCs can be initiated after cycling the ignition switch from OFF to ON. Normal operation of the climate control system stops when retrieving continuous DTCs.
•To retrieve continuous DTCs, press the OFF and DEFROST buttons simultaneously and release, then press the RECIRC button within 2 seconds . All vacuum fluorescent segments will be displayed if there are no continuous DTCs present. Continuous DTCs are indicated by the presence of the degrees Celsius symbol (°C) on the EATC module display. Record all DTCs displayed.
•If any DTCs appear, carry out the diagnostic procedure. Refer to the Electronic Automatic Temperature Control Module Diagnostic Trouble Code Index and follow the ACTION for each DTC given. See: Diagnostic Trouble Code Descriptions
•If a condition exists but no DTCs appear, GO to Symptom Chart Condition: The EATC System Is Inoperative, Intermittent or Incorrect Operation. See: Symptom Related Diagnostic Procedures
•To exit and retain all continuous DTCs, press any button except DEFROST. The EATC module will exit the retrieved continuous DTCs mode and retain all continuous DTCs.
•To exit and clear all continuous DTCs, press the DEFROST button. The EATC module will exit the retrieve continuous DTCs mode and all continuous DTCs will be cleared.
•Always exit the procedure before powering the system down (system turned OFF). Once the procedure is exited, the ignition switch must remain ON for at least 30 seconds to allow the door actuators to automatically recalibrate.
Electronic Automatic Temperature Control (EATC) Module and Electronic Manual Temperature Control (EMTC) Module Cold Boot Process The purpose of the cold boot process is to allow the EATC or EMTC module to re-initialize and calibrate the door actuators. To carry out the cold boot process, follow the steps below.
1.Turn the ignition switch to the OFF position.
2.Disconnect the EATC or EMTC module electrical connectors.
3.Wait one minute .
4.Connect the EATC or EMTC module electrical connectors.
5.Turn the ignition switch to the ON position.
6.Select any position except OFF on the EATC or EMTC module. The EATC or EMTC module will now initialize and calibrate the mode doors. Calibration of the mode doors will take approximately 30 seconds .
Dec 26, 2010 | 2005 Ford F-150
I have electronic controls for the heater, A/C and
You can try removing the panel connectors, resetting it and running the calibration test.
Open the ashtray, and pull on each lower cover of the center trim panel. This is held on with spring clips, 3 on each side ( black circles in the picture below ). When you get to the top, be careful, the Passenger Side Airbag Deactivation lamp is on the center trim panel and has small wires ( green circle ).
The blue circles are the cam over connectors on the HVAC control panel, pivot the bail out, and the connector wil unplug itself. Reattach and run the self test calibrate ( if it will take it ) listed below the picture.
May 13, 2010 | 2006 Ford F-150
My air conditioner does not work on my 2005 f150. All the display lights turn on at the same time and none of the buttons will control air or heat. Please advise.
I would start with disconnecting the EATC / EMTC ( Electronic Automatic / Manual Temperature Control ) panel.
Open the ash tray, and pull each lower corner out, they are held on with spring clips. Working your way up the center trim panel, there are 6 ( 3 on each side- black circles in the picture above ).
When you get to the top, be cautious, the Passenger side airbag deactivation lamp has small wires on it, don't pull too hard ( green circle above )
On the back of the EATC / EMTC panel are 2 cam over connectors ( blue circles in the picture above ), release the cam tab, and they will disconnect.
When you reconnect it, it will default to off. Next is to run the self test calibration process ( pay attention to the temperature range ).
I have found some times the EATC / EMTC panel will just freeze up, and disconnecting it, and recalibrating it will make it work again. Few of them have not seen a problem again in 2+ years.
3.Wait one minute .
May 04, 2010 | 2005 Ford F-150
2007 Mercury Mountaineer the eatc will turn off
this is for 2002
Dual Automatic Temperature Control Module Self-Test The DATC module self-test will retrieve on-demand (hard fault) DTCs only, it will not retrieve continuous DTCs. Continuous DTCs can be cleared when exiting the DATC module self-test. Make sure to retrieve continuous DTCs by carrying out the Dual Automatic Temperature Control Module — Retrieve Continuous DTCs procedure before clearing any continuous DTCs.
  • The DATC module self-test will not detect concerns associated with data link messages like engine coolant temperature or vehicle speed signals. A scan tool must be used to retrieve these concerns.
  • The DATC module self-test will detect concerns in the system control functions and will display on-demand (hard fault) DTCs for concerns that are present during the self-test. The vehicle interior temperature should be between 4°C - 38°C (40°F - 100°F) when performing the self-test. If the temperatures are not within the specified ranges, false DTCs may be displayed.
  • The self-test can be initiated after cycling the ignition switch from OFF to ON. Normal operation of the climate control system stops when the self-test is activated.
  • To enter the self-test press the OFF and FLOOR buttons simultaneously and release, then press the AUTO button within two seconds. The display will show a flashing blower icon for 20 seconds, after which all vacuum fluorescent segments will be displayed if there are no on-demand DTCs present. If DTCs are present the DATC module will display "00 00" and then on-demand DTCs. Record all DTCs displayed.
  • If any DTCs appear during the self-test, carry out the diagnostic procedure. Refer to the Dual Automatic Temperature Control Module Diagnostic Trouble Code Index and follow the ACTION for each DTC given.
  • If a condition exists but no DTCs appear during the self-test, GO to Symptom Chart Condition: The DATC System Is Inoperative, Intermittent or Incorrect Operation.
  • To exit the self-test and retain all continuous DTCs, press any button except DEFROST. The DATC module will exit the self-test and retain all continuous DTCs.
  • To exit the self-test and clear all continuous DTCs, press the DEFROST button. The DATC module will exit the self-test and all continuous DTCs will be cleared.
  • Always exit the self-test before powering the system down (system turned OFF). Once the self-test is exited the ignition switch must remain ON for at least 30 seconds to allow the temperature blend door actuators to automatically recalibrate.
  • Continuous DTCs will be deleted after 80 ignition switch ON cycles after the intermittent fault occurs.
Dual Automatic Temperature Control Module — Retrieve Continuous DTCs The DATC module will retrieve only continuous (intermittent) DTCs when carrying out this procedure.
  • Retrieval of continuous DTCs can be initiated after cycling the ignition switch from OFF to ON. Normal operation of the climate control system stops when retrieving continuous DTCs.
  • To retrieve continuous DTCs press the OFF and PANEL buttons simultaneously and release, then press the AUTO button within two seconds. All vacuum fluorescent segments will be displayed if there are no continuous DTCs present. Continuous DTCs are indicated by the presence of the degrees Celsius symbol (°C) on the DATC module display. Record all DTCs displayed.
  • If any DTCs appear, carry out the diagnostic procedure. Refer to the Dual Automatic Temperature Control Module Diagnostic Trouble Code Index and follow the ACTION for each DTC given.
  • If a condition exists but no DTCs appear, GO to Symptom Chart Condition: The DATC System Is Inoperative, Intermittent or Incorrect Operation.
  • To exit and retain all continuous DTCs, press any button except DEFROST. The DATC module will exit the retrieve continuous DTCs mode and retain all continuous DTCs.
  • To exit and clear all continuous DTCs, press the DEFROST button. The DATC module will exit the retrieve continuous DTCs mode and all continuous DTCs will be cleared.
  • Always exit the procedure before powering the system down (system turned OFF). Once the procedure is exited the ignition switch must remain ON for at least 30 seconds to allow the temperature blend door actuators to automatically recalibrate.
DTC Description Action Diagnostic Tool Display DATC Module Display B1251 1251 Air temperature internal sensor circuit open Go To Pinpoint Test A . B1253 1253 Air temperature internal sensor circuit short to ground Go To Pinpoint Test B . B1255 1255 Air temperature external sensor circuit open Go To Pinpoint Test C . B1257 1257 Air temperature external sensor circuit short to ground Go To Pinpoint Test D . B1259 1259 Solar radiation sensor circuit open Go To Pinpoint Test E . B1261 1261 Solar radiation sensor circuit short to ground Go To Pinpoint Test F . B1342 — ECU is defective INSTALL a new DATC module. B1676 1676 Battery voltage out of range CHECK circuit 729 (RD/WH) for a fault. If okay, REFER to Section 414-00 to diagnose the charging system fault. B2266 2266 Left side blend door circuit failure Go To Pinpoint Test G . B2267 2267 Right side blend door circuit failure Go To Pinpoint Test H . B2267 and B2268 2267 and 2268 Left side and right side blend door circuit failure Go To Pinpoint Test I . B2268 2268 Steering wheel climate control circuit open Go To Pinpoint Test J . B2269 2269 Steering wheel climate control circuit short to ground Go To Pinpoint Test K . B2477 2477 Module configuration failure RECONFIGURE the DATC module. REFER to Section 418-01.
Mar 01, 2010 | 2007 Mercury Mountaineer
Where is the electronicnautomatic temperature control module located on a 05 ford 150
I assume you have checked all fuses. It could be the heater control switch , the blower motor resister , I would start testing if power is getting pass the switch to the blower motor.
Nov 28, 2009 | 2005 Ford F-150
Heater displays everything but you cannot turn anything on ac will not turn on neither will the heat the buttons will not even light up please help
From the equipment description, I take this to be a EATC ( Electronic Automatic Temperature Control ) system.
You can try to run the EATC diagnostic test & recalibrate ( once you have confirmed it is not a fuse )
3.Wait one minute .
Nov 27, 2009 | 2005 Ford F-150
My Air panel just blinks power on and off. Is
Try the self test and calibrate for the HVAC panel :
3.Wait one minute .
Nov 02, 2009 | 2004 Ford F150
Error codes
Usally this is a bad control board or in some cases, a bad display board. they are fairly easy to replace and should be covered under a 5 year parts warranty (no labor). if its older than 5 years i would advise getting rid of it before putting any real money into it as Eurotechs are affectionatly know as Eurotrash in the industry and it WILL give you more problems. If you need a short dishwasher to fit under some shorter than standard counters, go with an ASKO. They are made by the same parent company, but are 50 times better. Good luck!
May 26, 2007 | EuroTech 24 in. EDW194E Built-in...
161 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
