Question about GE Microwave Ovens
We just purchased a GE microwave, model #WES1384SM2SS, serial #SM17533M. I have just one question: CAN YOU LEAVE THE BROWNING SHELF INSIDE THE MICROWAVE IF YOU JUST WANT TO MICROWAVE SOMETHING, NOT BROWNING ANYTHING AT THE SAME TIME?
    Genius:
  • 1,142 Answers
No dont leave it in it is not suggested to leave it in if the shelf is not being used
Posted on May 18, 2008
WHERE CAN I FIND A DOOR SWITCH FOR MY GE MICROWAVE WES1384SM2SS
Most microwave ovens use generic "microswitches" for door switching. You will need to open your oven, and find what they look like, and then match them.
I bought replacements here:
Allied Electronics Electronic Components Distributor
but any electronics distributor will have them. Inexpensive, only a few dollars eacy. My ovens actually use 4 switches on the doors, and more than one were bad.
Jun 04, 2015 | GE Microwave Ovens
WHAT WILL MAKE MY GE MICROWAVE WES1384SM2SS FUSE KEEP BLOWING I REPLACED IT ONCE AND AS SOON AS I OPEN THE DOOR IT BLEW AGAIN
The fuse is there to protect your home in case something has gone wrong inside your microwave. Since the fuse has blown twice, you can safely assume that there is something wrong inside. It may be fixable, it may not be economic to fix it. Impossible to troubleshoot electronics without the unit and test equipment.
GE JES1288SH03 Microwave browning oven (2006. How/where do I access to replace interior light bulb?
The lamp is located inside your microwave oven. The outside enclosure has to be removed to access it. Beware of dangerous voltages exposed when the cover is removed.
Feb 10, 2015 | GE Microwave Ovens
I need instructions for 10in. microwave browner
Only place I've found is here: CorningWare Browner Instructions
As these dishes were designed by Corning for a 650 watt over, you can recalculate preheat and cooking times for your oven with the following formula:
650/(your oven's wattage) x (listed preheat time or cook time)
For example, for a Corning MW-9 dish, they list 4 minutes maximum preheat time. I have a 1,580 watt oven. So 650/1580 = .41 x 4 minutes = 1.64 minutes and about a minute and a half preheat. (MAX).
Mar 09, 2014 | CorningWare Microwave Ovens
Wes1384sm2ss
It didn't come with one?
Oct 21, 2013 | Microwave Ovens
I HAVE A GE MICROWAVE/BROWNER NODEL WES1384SM2SS. IT HAS STOPPED RUNNING. I CAN SET IT UP TO COOK BUT WHEN I HIT THE START BUTTON NOTHING HAPPENS.
Re: GE JES1384SF Mine quit working so I unplugged it and put a pot of boiling water in it and let the steam dissolve whatever was gumming things up. I used an electric hot plate to keep the water boiling. I let it boil for a couple of hours. I left the door 2/3 open. The microwave is working again. It is four years old and has been used every day, many times a day before it stopped working.
Jan 08, 2011 | GE JES1384SF Microwave Oven
Model WES1384SM2SS runs bur no heat?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Dec 09, 2010 | General Electric Microwave Oven
GE Microwave wes1384sm2ss quit cooking. it
Owners of a GE WES model might want to look at this blog post.
Nov 28, 2009 | GE JE1640 Microwave Oven
I need a manual for Emerson Microwave mwg9111sl
When replacing the bulb in an Emerson, Microwave. Model mwg9111sl. Can you replace the bulb or the socket and bulb?
Jun 01, 2009 | Emerson MW8168B Microwave Oven
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
232 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
