Question about Linksys Wireless-N WRT150N Router
WRT150N Stops responding after a while
I have a linksys WRT150N v1.1 with the latest firmware (1.01.9) wireless router and two computers with WIRED connections to this router. After a while of use i lose my Internet connection and then attempt to connect the router in order to release and refresh the ip, but the router does not responds, so i have to unplug the power cord on the router and replug it again in order for it to starts working normally again... for a while.
here is my configuration:
Router ip 192.168.1.1
Internet setup: Automatic DHCP
Network setup: DHCP server Disabled
Computer 1 has an static ip configured in windows XP of 192.168.1.100 with DNS server & Default gateway of 192.168.1.1.
Computer 2 same as computer one except the network ip is 192.168.1.101
Same Issue, can anyone help?
Posted on May 19, 2008
My wireless connection is running super slow AND I cant access the router via 192.168.1.1
You can try to reset your router
Reset the Linksys WRT150N wireless home router if you are experiencing connection issues or have forgotten your customized router login information. Resetting the Linksys WRT150N will erase your Internet connection settings, wireless security preferences and all other personal settings from the router. This procedure will restore the WRT150N back to its factory state.
Instructions
1 Locate the "Reset" button on the back panel of the router. The button is situated to the right of the Ethernet ports and to the left of the power port.
2 Press and hold the "Reset" button.
3 Release the "Reset" button after approximately five seconds. The device resets
Tips & Warnings
Use the Linksys WRT150N setup CD-ROM to run the setup wizard and reconfigure the router after the reset.
Dec 29, 2011 | Linksys Wireless-N WRT150N Router
Problem connecting to my wep encrypted wireless linksys wrt150n wireless router
Check the following things:
1. Other PCs making a connection?
2. Have updated to the latest firmware?
3. Do you connect after removing the wireless encryption?
4. Do you connect using a wired connection to the router (ethernet)?
3. Do you get a connection when you connect directly to the modem (bypass the router)?
If you can not connect after the above, chances are the unit is defective.
Jan 03, 2010 | LG BD390 Blu-Ray Player
WRT150N 0ccasionally wireless is lost. Repower gets it back
Where is the router located? There maybe devices that run the same frequency as the router that may interfere the wireless connection (e.g. microwave oven, cordless phone). It may help if you place the router in the middle of all your wireless computers, change the channel of your router (change it to channel 1 or 11), or securing your wireless network by changing your SSID (do not use default wireless network name as others maybe using the same) or use WPA or WPA2 to make sure that nobody uses your wireless network.
Jul 06, 2009 | Linksys Wireless-N WRT150N Router
Connection Drops . wrt150n disconnecting
This is a firmware issue with the newer Linksys routers, and most people are having the same issue. Don't expect a stable firmware release from the manufacturer any time soon.
Instead, if you want to fix the problem properly, head on over to www.dd-wrt.com and install their firmware. I did this in a last ditch effort before throwing out my router, and now the router hasn't acted up for more than 10 days.
Be sure to follow the instructions when flashing firmware, several of the steps are critical to not "bricking" your router. As usual, make sure you are on a WIRED connection, as flashing from a wireless connection is guaranteed to kill your router. When flashing dd-wrt's firmware, you must also first flash a "mini" or "micro" version before flashing the full version.
Jun 07, 2009 | Linksys Wireless-N WRT150N Router
Router problem
This is a problem with the router's firmware, so i suggest you go to linksys web site and download the latest firmware for this router and upgrade it , so everything will be working but if still the same problem after the update better call linksys support and have the router replace...
Feb 19, 2009 | Linksys WRT150N Wireless N Router -...
My internet icutting out unless i plug power adapter from router
Cannot detect the router
What version of the router do you have 1,0 or 1,1? This is located on the bottom of your router. There is a firmware update for both models, I will provide link. Also how is your laptop connected wired or wireless? Let me know and I will try to help you troubleshoot your problem. We always can set up your router manually.
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1169671597537&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=9753741396B13&displaypage=nodata&proxyid=1172713508141
Jan 10, 2008 | Linksys Wireless-N WRT150N Router
3rd party firmware broke my router!
did you check whether you have downloaded the correct firmware for your linksys???
Dec 02, 2007 | Linksys Wireless-N WRT150N Router
Linksys Wireless-N WRT150N Router Logo
256 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
