Question about Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher
No water my kenmore dishwasher is not getting any water. when we try to select normal wash or water miser cycle, the motor turns on, I can tell water is getting to the dishwasher because i can hear it running under the sink and feel it in the flexpipe that feeds the dishwasher. It is not getting anything inside though. Just wondering if you have any ideas. Thanks
  • 2 more comments
  • getsdone May 27, 2008
    dishwasher is running and goes through it's cycles but gets no water. Water is getting to motor but not into washer
  • Anonymous Aug 10, 2008
    water not going into washer
  • cooperqb7 Sep 08, 2008
    I cannot get my disher washer to work. It just seems to have a mind of it's own. When i select the norm cycle I hear the water and it just sits at the bottom and the cycle runs out without washing anything. What is the issue?
  • catleland Apr 14, 2009
    My dishwasher goes through a normal cycle/time but there is no water getting to the dishwasher. This is a new problem and has never happened before. It is heating up.
    Scholar:
  • 110 Answers
SOUND LIKE YOU HAVE EITHER A FLOAT THAT IS STINKING OR A WATER INLET VAVLE THAT HAS FAILED. THE FOAT IS THE LITTLE MUSHROOM LIKE DOME WHICH IS PLACED AT THE FRONT LEFT SIDE UNDERNEATH THE BOTTOM RACK PULL UP GENTLY ON THE FLOAT UNTIL U HEAR A CLICK AND MAKE SURE THAT IT DROPS FREELY WITH NO DEBRIS UNDER IT SUCH AS SPOON, STRAWS, TOOTHPICK, ETC. IF THAT DOES NOT SOLVE THE ISSUES YOU HAVE A WATER INLET VAVLE THAT HAS GONE BAD
Posted on May 30, 2008
Kenmore ultra wash dishwasher gets stuck at 42 on the control panel
Be aware that all (well, almost all) dishwashers have a "thermal hold" period in their cycles. This is the point in the main wash cycle where the heater is turned on to heat the water to the optimum wash temperature (about 150 to 160 deg F), and during this time, the timer will stop advancing. Once the water has reached the desired temperature, the cycle will continue. IF it does not, then you have a water heating problem. This could be caused by a bad heating element, a bad controller, a bad thermostat or temperature sensor.
Mar 20, 2015 | Kenmore Dishwashers
If the element has a thermal fuse then it may still look good even when blown. The only way to check is to test for continuity across it. Unfortunately this can only be done from where the wires are connected onto the element. The water not heating up would stop the cycle, as it needs to hit temperature before continuing the cycle. This might not be the reason your machine is stopping, but hole this answers the questions and points you have made in your post
Oct 29, 2017 | Dishwashers
What is the sequence to reset kenmore dishwasher 665.16719000? The buttons from left to right are pots/pans, normal wash, water miser, china gentle, quick rinse, high temp, air dry, delay wash, start
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
All the lights will go solid at which point you press cancel to reset the board.
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore 24 in. 16052 Built-in Dishwasher
Kenmore ultra wash dishwasher has lock-on feature won't turn off
Hold the control lock in for more than four seconds. See if that works.
My website
s?a b?p t? t?i nh?
Jun 15, 2017 | Kenmore Dishwashers
Kenmore portable dishwasher not working
if you can get underneath it try spinning the motor manually (after turning off the circuit breaker). sometimes the motors on dishwashers get jammed.
May 29, 2009 | Kenmore 22422 Top Load Washer
Kenmore Ultra Wash Dishwasher Problem
there is no real way of checking the keypad. Not with a meter but if you push normal wash for example and it does not respond this usually means that you have a bad keypad
Nov 09, 2008 | Kenmore 15899 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher; Model 665.17539
I have a Kenmore 665 about 3 years old
Over the last couple months the touch pads have stopped working and I am now down to one control the water miser!
Do I need a new control pad and is that easy to install ?
Thank you for any sudgetstions
KC
Jan 15, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore model 665 dishwasher
the timer is bad.the 42 min cycle and the 6 min cycle share the same timeline.try northernparts.com for the part number and price.installing the timer isnt that difficult.
Jan 05, 2008 | Kenmore 24 in. 16304 Built-in Dishwasher
Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher Logo
123 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
