Ethernet card installation
I cant find da driver for my ethernet card and the only programme i can find is driver detective.which dont work on my pc.i am using a memory stick to transfer stuff from da laptop onto my pc.there was no disc with my card...please help....i need a programme that will install the driver
  • super-b May 19, 2008
    i dont know.and there is no serial numbers on it
  • 1,031 Answers
What the make of your ether card,the manufacturer
Posted on May 19, 2008
Ethernet dont work code28
Go out to Staples and buy an ethernet card. You can use this permanently or just to access the web to the drivers for the integrated port. That's what I had to do.
Apr 30, 2012 | Computers & Internet
I have an emachines t3256 desktop that i just reinstalled windows xp and now i cant get the network adapter to work its onboard and i cant find a driver on their website
Try installing a PCI ehternet card.Turn off the cpu then restart.The cpu will automatically (!?)detect the new hardware and even install the driver(generic).Then there you can get to the internet and get you E-machine drivers.It will also install the driver for your onboard ethernet(NIC) adapter and with that you are good to go.
Dec 04, 2010 | E-Machines eMachines Desktop PC
What ethernet driver do I need for dell optiplex gx260. There is no ethernet card. Just a slot for the enthernet cable.
check the Device Manager,
Go to Desktop/My Computer/Right Click/Properties/System Properties/Hardware Tab/Device Manager/look for Network Adaptor/ Expand it by clicking the + sign/Do u c any Ethernet Adaptor there or any yellow ? mark there....
If u dont c any Netwrok Adaptor then u dont have a network card installed in ur PC, if u have one then it will show up there, and if u dont ahve the correct driver or if's not installe dproperly then u will have the yellow ? amrk or an ! mark....
then in that case u will need the corect driver for the card to work....normaly Windows installs the required drivers for netwrork cards.....
Dec 17, 2009 | Dell OptiPlex GX260 PC Desktop
I need to download the ethernet drivers for the computer to detect the modem i cant connect to internet and i would like to know how to install the ethernet drivers without using the internet
If you dont have a manufacturer disk driver cd its difficult
you will need to download it in a cybercafe and load it on the machine
Use driverguide.com to download the driver.
Nov 13, 2009 | Compaq Computers & Internet
I recently had my hp pavillion dv 2000 with windows 2000 crash and it has been repaired but I am unable to connect to the internet. Turns out after a check I am missing my Ethernet card what can i do...
I the Ethernet card removed complete from your system or you mean to say your system do not detect your Ethernet card.
If the system do not detect your Ethernet card, then it is more of drivers related issues.
Re-install the drivers of your Ethernet card and try to connect.
This should solve your issue.
If there is no Ethernet card in laptop. Then, get one, install drivers for the same.. and try to connect. It will work.
Nov 04, 2009 | HP Pavilion dv2000t Notebook
Speedstream 6520 driver
Windows doesn't detect Ethernet connected devices. You could hook up a dozen Ethernet Modems and Windows would not see any of them, but they all would work fine using TCP/IP. It is not like you installed the DSL Modem/Router inside the case of the PC. You do know how Ethernet works, right? The only driver needed is the correct one for your Ethernet card, but that comes the Ethernet Card or the Motherboard Drivers CD for onboard Ethernet.
Found a few things, here are some websites to try:
Troubleshooting: Here
USB Driver for your Speedstream: Here
Sep 25, 2009 | Computers & Internet
My Ethernet card doesn't work on my n845wn Intel
It's possible the drivers are not installed.. To check if drivers are properly installed for the Ethernet card, if you have win XP
* go to Start>Control Panel>System> click on Hardware tab, then Device Manager
- once you're on Device Manager, look for network adapter, you should see something like "Via Rhine II Fast Ethernet Adapter", this is just an example, you may have a different brand of Ethernet adapter
- if you can see the Ethernet Adapter and it has a green icon beside it, it should be working fine, you can also double click on it, to view the Status
- if you don't see the Ethernet Adapter on the list, look under the section "Other Devices", if you see an "Ethernet Controller" on the list with a yellow exclamation point, it means the drivers for the Ethernet Adapter were not installed, which means the drivers has to be re-installed
- you need the manufacturer cd for the drivers
*Now if there's no "Ethernet Controller" on Other Devices section, it's possible the Ethernet card is not being detected by the computer
- you may have to unplug the Ethernet card physically from the computer (computer must be completely turned off) then try to insert the Ethernet card again and boot up the computer, if the computer detects the Ethernet card, you need to install the drivers
- If the computer doesn't detect the Ethernet card, most probably it's busted. You may have to replace it.. You can also try to install the Ethernet card on a different computer just to check if it's really the Ethernet card or the motherboard that's the problem..
May 10, 2009 | Intel Desktop Board D845WN Motherboard
T 180 desktop acer
Click on following link for audio driver and click on External Mirror 1
http://drivers.softpedia.com/progDownload/Acer-Aspire-T180-Audio-Driver-Download-37473.html
Click on following link for Ethernet driver and click on External Mirror 1
http://drivers.softpedia.com/progDownload/Acer-Aspire-T180-LAN-Driver-Download-37475.html
Regards,
Sandeep
Oct 18, 2008 | Acer Aspire™ T180 PC Desktop
Installing new Window xp and other devices didnt works
take the side of the computer off and look for the model number on your motherboard. you need to know if your using a network card or if its onboard Lan. if everything you need is onboard all you need to do is search your motherboard number on the internet and download the drivers. you need can select what you need, sound, lan etc. your goning to have to use a friends pc so you can download these files. when your Lan is installed go to the microsoft webpage and get the latest updates, that will solve the usb in your device manager
Sep 08, 2008 | Computers & Internet
Ethernet controller driver
i need an ethernet controller driver for my dell dimension 4600 the operating system is windows xp home edition
Sep 02, 2007 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
222 people viewed this question
David Payne
David Payne
