Question about Microsoft Xbox 360 Console
Xbox 360 live states MTU failed - Microsoft Xbox 360 Console
  • 5 more comments
  • Anonymous Sep 30, 2008
    mine started doing this tonight too for some reason.
    same problem with MTU and I dont know how to fix it!!
  • p8nter Sep 30, 2008
    Same problem, I've had the same set up for two years, now after the update , my mtu setting is wrong. WTF!!!!!! Anyone know what to do??
  • skipper1212 Nov 30, 2008
    I just bought the wireless adapter and everything was fine during the xbox live test until the mtu. It said that the thing had been "timed out" I went to my network settings, changed the mtu to 1364. Went back it didn't work.I turned off everything in the network (router, computers and xbox) and turned it back on and it still had the error. Help!
  • Anonymous Feb 14, 2009
    mtu failed how i get it to work
  • Anonymous Apr 03, 2009
    .....same here!!!! in call of duty 4 im stuck in setting up game!! it says it cycled out important.
  • wikiyp May 11, 2010
    Solution Link . . . www.MicrosoftXbox360Console.com,
How do u solve mtu on the 360.thanks
Posted on Nov 22, 2008
Well there are some updates i think theve ended by now though maybe you should check youre mtu settings they need to be hgiher than 1365 or right at 1365 hope tis helps
Posted on Oct 24, 2008
I live in Canada and ever since last night's Xbox Live "update", my xbox live hasn't been able to connect neither. What the...??!?
Posted on Sep 30, 2008
  • dsafasf Sep 30, 2008
    FROM THE OFFICIAL XBOX WEBSITE:
    Xbox LIVE Service StatusStatus:
    As
    we gear up to bring you the New Xbox Experience, Xbox LIVE and the Xbox
    LIVE page on Xbox.com will be down for 24 hours, beginning on September
    29, 2008 from 12:01 AM PST until 11:59 PM PST. During this time you
    will not be able to access Xbox LIVE.
For some reason i cant connect to live, it says that my mtu has failed. any surgesstions how i solve this??
Posted on Sep 29, 2008
Not enough mtu to go to xbox live at hotel
An MTU is the largest physical packet size, measure in Bytes that a network is capable of transmitting.. If messages are larger than the MTU they are divided into smaller packets before they can be sent. All networks have different MTU's which the owner of the network set at what they want to set it at. 576 is a very common MTU if you connect through PPP. 1500 is the most common MTU for Ethernet connections. The Xbox Live system requires your network to have a certain Maximum Transmission Unit (MTU). MTU values are important to the performance of online games. If this test fails, you can adjust the MTU setting on your network router or equivalent device to resolve the problem. Xbox live requires the network you use to have a maximum MTU. This is key to online gamesing. If the MTU fails then you have to adjust the router you are using. If you cannot access the router to adjust the MTU the you will not be able to play online games.
Mar 22, 2011 | Microsoft Xbox 360 Console
I can't connect my Xbox 360 into LIVE because the
This option is available via the web interface under the WAN Settings screen.
Nov 29, 2009 | 3Com OfficeConnect Wireless Router
Trying to set up xbox live.
you need to make an xbox live profile not mtu for offline. You have to make a new profile.
Jun 23, 2009 | Microsoft Xbox 360 Console
Xbox live cant connect mtu failed
This appears to be a common problem, most likely due to the recent Xbox Live server maintenance. Nothing we can do except for wait until Microsoft fixes things on their end.
Sep 30, 2008 | Microsoft Xbox 360 Console
Mtu failing
ther is no probs with ur xbox it will com on today
Mtu settings on xbox 360
ur xbox will be fine naw it was turned off by xbox for 24h on the 29 th
Hi can you please help me i was on xbox live tryed to connect with a router and now my 360 is askin for an ip address,but we do not no it can you please help thanks Paul
Aug 02, 2008 | Microsoft Xbox 360 Console
Mtu failed
what kind of router are you using to connect your xbox 360 to? usually you can define the MTU size in the router configuration.. default for xbox 360 live is 1364 ... check out your web configuration on your router to see if you can change this!
May 02, 2008 | Computers & Internet
MTU fail actiontec gt704wg
I opened my xbox 360 and i did not see a switch any where. don't do it its a lie.
Jan 06, 2008 | Actiontec (GT704WG) Router
XBox 360 MTU Failed with Router
MTU of 1500 is the standard TCP/IP message length. Only MS Vista allows that to be changed dynamically. If your ISP uses 1500 then you need to use it too. Your Xbox protocol may be blocked by your ISP. You may want to give them a ring...
Jan 04, 2008 | Linksys Wireless-G Broadband Router
Microsoft Xbox 360 Console Logo
355 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
