My TV, it has no picture
Posted on May 18, 2008
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ... > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58] > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
Universal remote codes for NEC TV are:
003 004 005 009 010 085 089 095
0181 0004 0005 0009 0003 0010 0095 0141
Mar 08, 2012 | Televison & Video
Hi there I have an NEC croma vision FS 6802 TV and we have not got a remove, we can't turn the TV on without one... I have a universal remote (all for one) but it is not tuned... Please help Thanking...
Usually if one presses the channel up button it will turn the TV on. The universal should be able to control the TV but of course one needs to have the TV in the on condition to find it.
Hope this helps.
Nov 04, 2010 | Televison & Video
How do I get the code for my samsung TV remote control?
Please check the bellow link related to your issue:-
However these are the Remote Control Codes for different Samsung Models:
With the TV in standby, press the
{DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
  • With the TV in standby, press the
    {P.STD} {HELP} {SLEEP} {POWER} buttons on the remote.
    {P.STD} {MENU} {SLEEP} {POWER} buttons on the remote.
    {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
To exit, simply Power Off the TV.
Well i tried these codes on my SAMSUNG HITRON 21" CRT TV but did not worked. however at last i tried :
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting
Nov 01, 2010 | Samsung TV Remote Control
I bought my son a 19" philips tv model # 19pfl340d/ order to turn tv on it must be unplugged for 10-15 minutes.The first one I bought did the same thing and I returned it.this one is exactly the...
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
Nov 11, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Lost remote need code for universal remote control.
  1. Turn on your TV.
  2. On your Tune In remote, press TV and release.
  3. Press and hold Set until the green light on Tune In blinks once, pauses and then blinks twice. Now release the Set key.
  4. Enter the first three-digit TV code for your NEC from the list which follows:
    030, 056, 019
    These codes are listed in order of popularity, and the green light will blink twice if you perform this procedure correctly.
  5. Aim Tune In at your TV and press Power. Your TV should turn off. If it does not, repeat steps 2-5, trying each code listed in step 4 until you find the one that operates your TV.
Now Test Your TVWhy test? Many times more than one code appears to work. Testing is desirable to be sure you have the correct code for your TV or the other devices you are setting up.
  1. Press the Power key to turn on the TV, then press mute, channel scan ("CH") and volume ("VOL") keys. Tune channels 7 and 11 by entering the number followed by the Enter key.
  2. If your TV does not pass the test, return to Step 2 at the top of this page. Enter the next three-digit code and repeat the process.
May 11, 2009 | Televison & Video
NEC PX 42XM1A won't power on
Any chance you might think that it is your remote control faulty? As you need it to turn your plasma on from standby via remote (only). Let me know.
Apr 23, 2009 | Televison & Video
Older NEC TV mising a manual
Manual missing here as well... what i found out.... if you press the "menu" button for 3 seconds you can set it up automatically (grey button on the lower right) and have 1 additional menu by pressing menu again. Hope this helps!
Dec 01, 2007 | Televison & Video
Tv stuck in standby
If you can not turn on TV set with the power button on the TV its not a standby problem as this would by pass the standby. Theres most likly, on a set of this age, top have a poiwer regulator problem and is going to need a trained tech to assist you in this repair.
Sep 10, 2006 | Sony KV-32S42 32" TV
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
