posted by northend on May 18, 2008
I have a 50 inch toshiba rear projection tv.Yesterday it just shut off.It has no picture and when you try to turn the power on,you get nothing,and the power light flashes off and on.
Comment by northend, posted on May 18, 2008
Its a toshiba 50h71.The blinking power light blinks constantly.When you plug it in and hit the power button,you first hear the sound as if the tv is gonna come on but you get nothing on the screen,no sound or picture and the power light just keeps blinking off and on as long as I keep the power on.
1 Other User Has The Same Problem
Comment by Liemnguyen, posted on May 18, 2008
My TV ., It has not picture
Solution #1
please post the model number of your set and also let me know how many times the light is blinking as its most likely an error code. But need the info on model number and mumber of blinks to determine what the problem most likely is.
Comment by Slinteriors, posted on May 18, 2008
Check the solder connections on capacitors C809 and C810 they are located on the left side of the chassis looking in from behind also check fuse FL860 as the solder joints could open that fuse. usually when the power led lights but the set wont power up its those two capacitors with bad solder joint on the negative side.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Projection Televisions
Email this problem
Email this problem
This Problem Also Relates To:
Panasonic PT-51HX42 51 in. Rear Projection Television
Panasonic PT-53WX53 53 in. Rear Projection HDTV-Ready Television
Panasonic PT-52LCX65 44 in. HDTV Television
Panasonic PT-51HX41 51 in. Rear Projection Television
Panasonic PT-53TW53 53 in. Rear Projection HDTV-Ready Television
Panasonic PT-43LC14 43 in. Rear Projection HDTV Television
Sony KP-53HS30 53 in. Rear Projection HDTV-Ready Television
Can you Help with these Projection Televisions problems?
Hitachi 43UWX10B 43 in. Rear Projection...
C50-F550P
C50-F550P
My C50-F550P does not come on.... Answer This...
Repair Service
Find Projection TV Repairman Near You:
