Home | Apple | iPod classic Silver Digital Media Player | Red x icon on my ipod
Apple iPod classic Silver Digital Media Player
Problem for Apple iPod classic Silver Digital Media Player
By mindblower2u on May 18, 2008
my ipod is nopt responding to an of my commands and its displaying a red X icon encircled with a red cicle and it s not even connecting to mycomputer plzz help me 2 work it out
Same Problem
May 16, 2009
-   MY IPOD HAS A BIG RED X I HAVE TRIED EVERYTHING AND APPLE WANT $150 TO FIX IT I DONT KNOW WHAT TO DOOOOOO -   CLASSYBITCH
Apr 29, 2009
-   HOLY SMOKES the hitting it on the carpet totally worked...it made the clicking sound and everything!! thank you SO MUCH!! yayyyy!! -   Guest
Apr 10, 2009
-   theres a reboot system -   Guest
Apr 07, 2009
-   i just dropped my ipod the littlest bit and i got this problem and i have tried resetting and hitting it nothing works -   Guest
Mar 07, 2009
-   ya my ipod got the red x and if i put my ear up to the back i can hear some noices soooo the harddrive is probibly fucked. so ya were all screwed -   brittnaybear
Solution #1
posted on May 18, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Solution #2
posted on Apr 28, 2009
Very Helpful)
my_volume
Rank: Apprentice
Rating: 100%, 3 votes
Ok I want to thank JUSTHATGUY for his help. I did your steps and they worked like a charm! It freaked me out when it made the noise but i still can;t believe i worked. If any of y'all have a problem just follow his steps. Thank man!
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #3
posted on Aug 03, 2008
Very Helpful)
er_bear
Rank: Apprentice
Rating: 100%, 2 votes
Thanks for the copy and paste instructions from the Apple website, but these steps are not solutions. The folks above are trying to say they've tried all these steps and none are working, what now?
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #4
posted on Mar 30, 2009
Very Helpful)
justhatguy
Rank: Apprentice
Rating: 99%, 38 votes
Hey, I had the same problem and did everything I could think of to fix it (apple store, resetting it, draining the charge). Then I started freaking out because I didn't want to spend the money on a new hard drive or a new iPod. So I did a little searching and found this on another forum:
"Some times when you drop your ipod the lens inside skips. (kinda like a record player) reset your ipod by holding the middle and menu button until you hear clicking. then with one hand hold the ipod firmly and hit the side of it onto the PALM of your other hand. Sometimes this jumps the needle back into place but not all the time."
I did this using the palm method, and it didn't work. But then I hit the side of the ipod on the ground (carpet of course) about two or three times. It made a funny noise and then turned on and started working like before. What a relief. Hope this helps.
Was this helpful?
Yes
No
37 people thought this was helpful
Solution #5
posted on Jan 28, 2009
Helpful)
marsman35
Rank: Apprentice
Rating: 88%, 2 votes
If all attemps to reset your ipod have failed it is possible that the hard drive has crashed and will need to be replaced. If your ipod is still under warranty and you know it hasn't been dropped you can try to send it back to Apple. Otherwise you can look to some aftermarket solutions for parts or repair services.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #6
posted on Jan 18, 2009
Somewhat Helpful)
beanerwhip
Rank: Apprentice
Rating: 81%, 4 votes
Okay first thing you wanna do is go to itunes.com and download version 8.0 or whatever the new one is and then type in under search firewire scroll down to downloads and download the first one labled and its the only one that says firewire in it ---"hit the save button after you hit the download button on it" ---(HAVE IPOD DISCONNECTED THE WHOLE TIME FROM THE COMPUTER) turn the ipod on then hold the center and middle button as soon as the screen goes blank plug it into the computer WHILE THE FILES ARE STILL BEING DOWNLOADED DO NOT WAIT UNTIL AFTER DOWNLOADING IS COMPLETE!!!! then once it is plugged in and the files are downloaded an itunes repair screen will pop hit the repair button wait till it finishes restart the computer and it should be workin
Was this helpful?
Yes
No
Solution #7
posted on Jul 20, 2009
Somewhat Helpful)
whazupyo
Rank: Apprentice
Rating: 75%, 1 votes
I tried Justthatguy's idea and it worked! K, here's the thing. It didn't work after at least 15-20 times of hitting it on the carpet/palm of my hand. I finally didn't care if I broke the thing and I pounded it on the carpet extremely hard while performing a reset. After about 3 very hard bumps to the side of the unit, a new reset screen popped up on my ipod. I then plugged it into my computer and Itunes finaly recognized it!
Was this helpful?
Yes
No
Solution #8
posted on Jun 18, 2009
Somewhat Helpful)
carverhodo
Rank: Apprentice
thank you justhatguy for your help.I didn't know what to do until i found your solution.Other people with the same problem i think you should go with justhatguy.
Was this helpful?
Yes
No
Solution #9
posted on Aug 26, 2009
Not Rated)
med23
Rank: Apprentice
Rating: 0%, 0 votes
Ok I'm having the same problem as everyone else but Justthatguy's solution isn't working! It doesn't make a noise or anything when I reset it. It acts like it's going to work...the apple pops up then back to the dreadful Red X!! What am I doing wrong?
Was this helpful?
Yes
No
Solution #10
posted on Jun 24, 2009
Not Rated)
herry22
Rank: Apprentice
Rating: 0%, 0 votes
JUSTHATGUY!!! YOU DA MAN!! It worked like a charm!!
Was this helpful?
Yes
No
Solution #11
posted on Jun 20, 2009
Not Rated)
Fuzzums
Rank: Apprentice
Rating: 0%, 0 votes
JUST THAT GUY! MORE LIKE JUST THAT GOD!!! THANK YOU SOO MUCH JUSTTHATGUY!
Was this helpful?
Yes
No
Solution #12
posted on Jun 12, 2009
Not Rated)
msaquarius77
Rank: Apprentice
Rating: 0%, 0 votes
I would like to thank JUSTHATGUY!! You are AWESOM!! My ipod was frozen for a week before I found your solution. I am forever grateful!
Was this helpful?
Yes
No
Popular Solutions for Apple iPod classic Silver
Questions and Unsolved Problems for Apple iPod classic Silver
Do you recommend Apple iPod classic Silver Digital Media Player?
Answer
Answer
when i turn it on the apple logo will stay on and wont go away ev en after i reset
Answer
Ipod classic 120gb responds to menu controls but tracks do not play
Answer
my ipod when im on itunes it doesnt register the i pod and the message of the bottom of the screen... (More)
Answer
the scrole pad and buttons ant working on my ipod classic 80g what do i do
Answer
White horizontal line on ipod appeared and will not go away. It is a problem when viewing video.... (More)
10 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 02, 2009
waht do i do
Comment by marko_j_17, posted on Dec 11, 2008
hi i have the same problem with the others... i did the instructions given below however the red X with a circle still appear in the screen of my 120g ipod classic video.... please help me...
Comment by Guest, posted on Jul 29, 2008
My Ipod has a red x with a circle and cannot connect to my computer and will not reset completely.
Comment by fleming74, posted on Jul 27, 2008
i am having trouble with my ipod classic, the red x icon, i turn on the hold switch then quickly off then i dont have any time before the apple appears and then when i push the select and menu then the x appears then it turns off......... (and its charged) charged it all last night.
Comment by Guest, posted on Jul 11, 2008
Same with me! Computer won't recognise it and resetting doesn't do anything!!! Any other tips?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Apple iPod classic Silver...:
Top MP3 and Digital Med... Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more MP3 and Digital Med... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
