Question about HP Officejet 4355 All-In-One InkJet Printer
Paper jam but no paper at all
My HP 4355 shows that there is a paper jam. However, there is no paper at all. I have already checked carefully and followed every step provided at HP website but I still have the problem.
Any suggestion or solution? thanks
  • 1 more comment
  • salimbadshah May 30, 2008
    paper jam in 4355 but no paper within
  • Anonymous Jun 25, 2008
    Yes same thing here have you been able to fix it?
  • Anonymous Jul 03, 2008
    Problem Solver:
  • 5 Answers
Hey no problem just open all screw in your printer than
left side cadridge stand near big size black wheel out side one
plastic mark round sheet fit for correct possion on black wheel
ex; black wheel inside 125 number so plastic sheet no 6 position (black wheel bottom one small stage point so that point insert for always that plasti paper sheet) than fix to paste that possion after finish on your work just turn the 0 position on that black wheel
than close properly that problem solved.... but u go the redington service center same work but that cheet fellow u have charge the Rs.1350/- by nandhakumar, coimbatore
Posted on Jul 02, 2009
    Sergeant:
  • 253 Answers
All sencer of printer clean care fully.
Posted on Jun 30, 2008
2 Suggested Answers
  • 84 Answers
SOURCE: hp 4355 all in one
The paper movement mechanism may have some problem.
If not so the paper movement sensor in the inner part of left side is having the problem.
The timing wheel may be out of alignment or the sensors may have dust over them....
Posted on Feb 11, 2010
How do i fix a "fake" paper jam in my HP Officejet 6700 Premium
Try using compressed air to blow it out.. or use a compressor that can do 150 psi.. you might have dust in the sensor..
Aug 27, 2014 | Office Equipment & Supplies
Why do i have a false jam reading?
I understand that you're receiving what you believe to be a 'false' paper jam on your HP Photosmart C6280 All-in-One Printer. I would like to work with you today with resolving this issue. Paper jams can be real or false. The product might report a paper jam even when there is no jammed paper. A false paper jam may also be the result of having a bad paper jam at a point in time and that bad jam causing a hardware issue to the paper sensor or rollers. I am going to provide you with some additional troubleshooting steps that apply to both real and false paper jams. You did state that you already checked the paper pathway inside the printer and failed to find any evidence of paper being stuck, but please run the step-by-step troubleshooting below, even if you have already run some of the steps.
Here are the steps for clearing the path:
Photosmart c6280 False Paper Jam Messages
Try this blog for alternate clearing ideas for this printer. HP Photosmart C6280 error message Carriage Jam
Jul 02, 2014 | HP Photosmart C6280 Printer
Paper is not jaam but printer showing paper jaam again & again.
Several things can cause a jam. I can suggest checking the paper path very well, especially if you have had a jam in the past, a little piece of paper there could be triggering a sensor and causing the message. Another thing might be rollers worn out or dirty. If the rollers rotate 3 times and no pick up happen it will show paper jam, try a humid tissue to clean it.
Sep 07, 2010 | HP Officejet 4355 All-In-One InkJet...
Paper jam
Hello and Welcome to FixYa!
This is a common issue, but should be solved with care and delicacy because it requires a physical interaction with the machine, ok I could have mentioned the steps for clearing the Paper jam here, but I feel a pictorial representation will play much better role, so I'm linking you to the Hp Support page, please find the link below. All you have to do is to carefully follow the steps.
If in case you are having trouble/questions do ask us, We are help to help.
If you have already tried those steps, do tell me indeed in that case, I'll guide you further then.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
P.S: Clearing the Paper Jam
Aug 07, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
How can i clear carriage jam
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
Jun 08, 2010 | HP Officejet 4355 All-In-One InkJet...
4355 papar jam error solution
THE PRINTERS MANUFACTURED BY HP ARE HAVING THIS PROBLEM IN COMMON ALL THE WAY. WE SHOULD TAKE FOLLOWING PRISCPRIPTIONS WHILE RUNNING THESE PRINTERS
1. LOAD PAPERS AT SOME DISTANCE FROM THE PAPER LIFTER THAT MEANS KEEP THE PAPERS SOMEWHAT BEHING YOU KEEP THEM
2. WHEN THE PRINTERS ARE OLD THEM GET THEIR PAPER LIFTER CHECKED AND TRY TO PRINT ONE PAPER AT A TIME.
THANKS
PROUD TO BE AN INDIAN
KAMAL DEV JHALLI
HAVE A GOOD DAY
Nov 25, 2009 | HP Officejet 4355 All-In-One InkJet...
We are having problem with our HP Officejet 4355 All -in-one Inkjet Printer. When we are scanning the paper is not moving inside. I Think a piece is troubling inside. How to remove paper. How to open...
the scanner feeder mechanism may have some problem.
Get it serviced from nearest service centre or your vendor...
There is a door back of the printer to clear paper particles and jams. carefully open, clean and re fix it on its place.
Nov 05, 2009 | HP Officejet 4355 All-In-One InkJet...
Hp 4355 all in one
Jun 28, 2008 | HP Officejet 4355 All-In-One InkJet...
HP Officejet 4355 All-In-One InkJet Printer Logo
324 people viewed this question
Seeker5211
Seeker5211
