Question about Refrigerators
My samsung fridge/freezer srs536np keeps turning off but when i turn power off and backon again it will run , but sometime it can turn off again and if i di the same again it will run
  • stanga Mar 11, 2009
    as described in problem and fix section ! with one difference,i wll switch it on/off at the wall ! it will start up then turn off about 3 hours later and not start up again until i turn it on and off again!
  • 828 Answers
If it is the thermostat from which you are turning it off and then back on again from it is possible that the thermostat is bad and in need of replacement. A thermostat turns off with temperature. Before it will turn back on for cooling the differential must be overcome. If it shuts off at 34°F it will not restart until its temperature reaches the higher built in differential temperature.
Also if you shut the refrigerator off while it is running you should not turn it back to the on position for five to 10 minutes. This is necessary to allow the pressures to equalize with-in the refrigeration system .
Posted on May 18, 2008
Hi I have pressed the vacation button on my side by side refrigerator/freezer as we are going away for 8 weeks. The display has lit up but there is no difference in the way the fridge is operating - same...
The settings will reset to a lower settting as the fridge/freezer will not be disturbed . So wait for the fridge to run and shut down and it will continue to run in this low mode to save power but to keep the food in prime condition. The fridge alone will not be shut down.
Aug 31, 2011 | Samsung SRS20DTD Side by Side Refrigerator
Samsung SRS536 side/side fridge no auto start, now weak cooling
you give a pretty good discription;i would say this machine has leaked gas, the hole is not visable to the human eye therefore the machine is working and working trying to maintain the advice to you is buy yourself a new fridge,because this one will cost to much money to repair.adrian,,,,,,
Jul 31, 2010 | Samsung Refrigerators
Temperature monitor of freezer flashes
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 16, 2010 | Freezers
Fridge defrosting
Sounds like the defrost is cycling on and off. The model number is incorrect and I will need a correct model number to help you better. Sea Breeze
Aug 25, 2009 | Samsung Refrigerators
Freezer and fridge don't cool at all. everything else works fine
There is a fault with samsung fridges that when it goes on defrost it will not start the compressor or the fans again. If you turn on the power the fridge should run for a couple of hours and then stop if so you will need to get a tech out to order a samsung yellow sensor and a fridge defrost isolation sensor. If the fridge does not work at all if you would like i will talk you a couple of little checks before calling someone out.
Hope this helps
Jan 05, 2009 | Samsung RS2630SH Side by Side Refrigerator
Ice forming on freezer
The drain is plugged. This fridge will defrost every 8 hrs or so. When it does , it will melt the frost that has built up on the evaporator. This melted frost will run down a drain under the evaporator to a drain in the bottom directly under the evaporator. When the drain gets plugged the water cannot drain out of the freezer compartment. After several defrost cycles the melted frost will overflow onto the freezer floor. When the fridge starts back up it will freez this water is the bottom of the fridge. sometimes this water that is now ice will melt on the next defrost cycle and actually run out into the floor. You will have to unplug the fridge or turn it off, then remove the cover to the evaporator. Get a hair dryer and melt the ice aruond the evaporator and drain. Once the ice is removed, check the drain and try to clear it. Once clear, replace everything but the shelves. Plug the fridge back in or turn it back on. Observe and listen for the evaporator fan. It should be running now. When working on the ice on the evaporator always be carefull. The defrost heater can be damaged if up push or pull on it too much.
Nov 15, 2008 | Samsung RF265AA Bottom Freezer French Door...
Samsung fridge freezer not cold enough
Hello whiten61,
You said, You noticed there was condensation in my fridge and a strange smell coming from it, also my freezer was cold but didn't seem to be cold enough, I have a digital display and it was still showing -22 for freezer and 3 for fridge. I turned the power off on the wall and when i turned it back on which was straight away it shown -3 for freezer and 16 for fridge... I then noticed the ice cream in freezer very watery, however ice in freezer still frozen? i pressed the quick freeze button which eventually the temperature came back up but i keep getting the exact same problem... Can you help. thank you.
Samsung side by side refrigerator SR-S2025CVW
How old is the fridge?
You did all the right things!!
But this sounds like a bad thermostat.
or a bad control switch.
Unfortunately it sounds like you may need service to do an hands on diagnoses and replacement of one of these parts I listed here!
Let me know how you do! Or if you need something else.
We do have very good sponsors here on this site that do repair work, should you take this course!
Please remember to leave a rating.
Oct 14, 2008 | Samsung RS2630SH Side by Side Refrigerator
Hot point Fridge/ freezer
All the cooling is in the freezer and the control in the fridge side only controls a damper to let in cold air as needed. To do what you want you have to replace the thermostat to a lower temp rated unit
Nov 22, 2007 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
325 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
