Question about Sentry Fireproof Safe
Sentry 3100 inner door panel removal to lubricate mechanism
I have a Sentry 3100 that was placed in the basement for 10 years. I can open and close it, but the dial is not smooth turning, but kind of notchy... I'd like to remove the inner plastic panel and see if I can lubricate the mechanism, but don't know if I can.... anyone have any information about removing the panel, or lubricating the dial and inner parts?
I found the owner's manual and after reading it, it said there was a screw I could remove and pop off the panel. I found the screw in an indented area, removed it, but the cover would not just pop off. There is one tab on the left side and one on the right side I had to pry with a screwdriver, and then it did come off... turns out there was no rust inside. I think it is built out of pot metal castings for the most part which won't rust... there are a few steel disks there, and I lightly oiled them....
All is good, now... and the safe is back in use.
Posted on May 19, 2008
Removed inner door panels on my 11 Pilot to reupholster arm rests. After I reassembled the panels I am unable to open the doors. I put everything together properly, do Pilots have a door tamper secu
you must have either broke a plastic clip at the lock area look good or one of the little arms came off look good you will find hte problem .bothe doors , did you brake a wire ? look good
Dec 01, 2014 | Cars & Trucks
Cannot get dryer door to close/latch properly.
Hi stay at home MOM
  1. what is the Model of Dryer?
  2. do you pull to open or push button to open DRYER Door?
  3. hinges on the right or the left?
  4. door inner n outer panels plastic?
  5. is there a door seal on the door?
  6. when you did your removal of lint, did you remove DOOR?
  7. picture front of dryer area and door of dryer will help.
Sep 27, 2014 | Dryers
Door wont latch shut
while holding the door handle up to open try to separate the fingers in the door latch if they wont separate.. the rods inside the door may have broken loose from the mechanism..this requires removal of the inner door panel to look at..
Dec 23, 2013 | Mercury Sable Cars & Trucks
Rear door will not open on my ford focus ghia t reg
Hi chance are the mechanism inside door jamming. Short of forcing off the inner panel in order to clean lubricate etc I find the best way to get this open is to get someone to keep activating your central locking open and shut while you simply keep trying the door handle at the same time and this can some times just catch the latch in just the right position to get the door open ( you dont need to forcefully be pulling on the handle as the latch will either simply click over on the fine spring latch mechanism or not force is not going to help).
Once and if you manage to get door open take off the inner door card panel and oil lubricate mechanism. rather than then shut door simply use a screw driver on latch to test and worth then working back and forth. If still jamming replace latch.
Dec 01, 2013 | Cars & Trucks
How do I change the safe's combination?
with door open, remove panel on back of door. remove the nut holding the three wheels in place and mark original location and then relocate the pin on back wheel. Reinstall nut. test visually to make sure you know the correct combination and be able to open it without watching the wheels in the door before closing and latching it again.
May 16, 2013 | Sentry Fireproof Security Safe Combination
I have a 1997 ford thunderbird lx and the other day when i went to close the door when i got out it,it wuldnt shut i slammed it a couple times n it still wouldnt shut i really need help because i cant...
Here's something that might help you. Look at the door theres a little hook that grabs the striker on car, hold the door handle "open" and move the hook to the open position try to close the door. That should solve your problem. Hope that helps you.
Aug 05, 2011 | Ford Thunderbird Cars & Trucks
Rear doors will not close just keep bouncing open
Before you take the inner door panel apart try to spray an oil like WD40 into the door latch mechanism & Open & close many times. The return spring for the latch has stuck and it needs some waking up. Getting then inner panel off does not help that much in access.
Dec 31, 2009 | 1998 Volkswagen Golf
I do not know the combination number. We have a 3100 sentry Thank you Donna
if it is open already... Take off the plastic inside cover. lock the door "WITH IT OPEN " . turn it several times to the right then watch the inside most slot line up. Write that # down. Turn it to the left past that number and continue on till the middle slot lines up to the inner most slot. Write that # down. Then turn to the right until the outer most slot in the last disk lines up to the other two and write that # down.... Then OPEN the door. Now you put the combination where you wont love it hopefully. This will only work if the safe is locked open. Hope it helps.
Apr 08, 2009 | Sentry Fireproof Safe
Spring lock thingy *chuckle*
the inner door lock assembly.unscrew door handle window winder handle and unscrew lock knob.door panel should be held on by plastic push on plugs,pull off from the bottom up ,remove screws, if any. When plugs have been seperated lift panel upwards to clear top of inner door panel.Undo inner door handle and release from lock joiner rod.close to the inner door handle is a plastic rod link should be white rotate outer part until its released.the door lock<key>has a plate holding it to the door remove it and remove the lock from the rod.Remove outr door handle and remove from the rod At the bottom of the door is a bolt holding the window channel,remove the channel by unbolting,pull back window rubber and wiggle steel channel down until it slides out so the inner lock can be accessed.Remove the three large screws holding the outer door lock.it should be able to be removed. place the locks next to each other so you dont mix up the rods when you swap them over.assembly is the reverse order wind the window all the way up before you start.
Jun 13, 2008 | 1981 Ford F 100
Sentry Fireproof Safe Logo
1,027 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
