Question about Maytag Neptune MDG5500AW Gas Dryer
Heat stops after a few minutes, control board already replaced
Have a Maytag Neptune Dryer, Model number MDG5500AWW (gas). Last week (No lights on panel, no power when you hit the start button). Had a serviceman out who said it was the control board, showed it to us and could see visible brown marks at top of the control board (looks like a circuit board) where it looked like something blew. Total repair cost would be $293 ($170 part plus the labor).
The repairman plugged the old board back in because we probably weren't going to fix it and he said it started to work when he leaned on it, and in fact after he left it did work with the exception of the heat cutting out part way into the cycle (say, after about 5 minutes or so). My husband got ambitious and decided to try to fix it himself, located a circuit board for $170 and installed it. Things looked good, he thought it was working fine, but when I did laundry myself, I noticed the same problem with the heat. With sensor or timed heat it seems like it starts to heat up, when I stop the dryer and stick my hand in it feels very warm but then after more time it goes cold.
Thank you very much ~
Anne & Rik
Reply
Forward
  • 770 Answers
Thanks for the Chat session I hope I fixed your problem I would like to email you the complete service manual on your model if that is ok it will show you everything and how to break it down please post your email
Thanks Gary
Posted on May 19, 2008
NO HEAT MDG5500AWW 56780829AX DRYER TURNS BUT NO
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
We own a Maytag Neptune Dryer Model No. MDG5500AWW and have already replaced the mother board. The dryer began beeping periodically and then it just won't start - controls are frozen but they do light up....
If you hear random beeping and a double beep sound when you are pressing a key it means that your problem is the keypad itself, not the board. The keypad on this model is the entire console (not a cheap part @ $200 but this was a very well built dryer so probably worth the repair). You most likely have one of the keys that is shorted out on the console that is causing all of your troubles.
Get yourself a new key-panel part number 33002536 and replace it and you should have your problems solved.
Good luck and please let me know if you have any other questions on this!!
Aug 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AWW gas dryer ignites, then flame goes out
The 'radiant sensor/ needs to be replaced. This sensor tells the system that the flame is lit and everything is good. Go to repairclinic.com
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500aww-%3d%3di2681&PartID=2681
Oct 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag dryer model number MDE5500AYW has lights on, but won't switch settings. It is stuck in time dry at 18 minutes. Yesterday it was on sensor dry 47 minutes. Do I need a new control board inside...
OK, your control board and LED are integrated, so you will need to just replace the control board. I would try a hard reset before replacing the board. Pull the plug or, shut down the appropriate breaker switch for 5 minutes. Re apply power after the 5 minutes are up. if you continue to experience this fault, replace the control board asap.
CONTROL PANEL(CLICK HERE TO ORDER)
Aug 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
I replaced the thermistor on maytag neptune gas dryer, model #MDG5500AWW.It still will not start .Do I have to reset the control panel first to get it running?
did you forget to plug the door switch back in? or anything else? oh..it didn't start before...ok. you probably should have replaced the thermal fuse..it's white with 2 wires on it.
Jun 10, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
MayTag Neptune MDG9700AW Gas Dryer
Check the lint tubing and also for lint underneath the dryer. There is a blockage somewhere for this to happen. This is a built in safety feature for gas dryers that others don't have.
Jun 01, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer model # mdg5500aww sensor not working is just starts a 37 minutes
How do I lift the top panel of my Maytag Neptune dryer model MDG5500AWW?
Jan 13, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
256 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
