Back to:
Tags:
PC Laptops
Generic problem for all PC Laptops
Battery not found in power management screen charge... (by 2 users)
posted by thefixer2008 on May 18, 2008
This issue has been posted on here before but no answer thtat fixed this issue was ever posted. AC adaptor, bios update and new battery all do not fix this problem
I replaced the battery but my charge light will go out after a few seconds.
If I remove and reinsert the battery the charge light will come on but then just go out again.
The battery meter doesn't see the battery but if I unplug the AC power the laptop stays running so it is being power by the battery.
I cleaned the contacts on the battery and laptop but it didn't help.
Comment by xlh1460, posted on Jan 20, 2008 I thought that might be it so I updated the BIOS. 9.30 was the newest I could find (I created a bootable CD) but that didn't help.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jun 06, 2008
computer does not recgonize the 90w adapter and there for won't charge
Solution #1
posted on May 18, 2008
Not Rated (0)
Dageezer
Rank:Guru Guru
Rating: 88%, 298 votes
The Charging circuit on the motherboard is bad, and the motherboard will need to be replaced.
Sorry
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on battery not found in power management screen charge light goes out:
I don't want to Accept this solution
Can you Help with these PC Laptops problems?
HP Compaq Presario V6000T (EZ855AV) PC...
Hello, Yesterday, I've start my computer and there was a...
Acer Aspire? 5100-5022 (LXABH0J091) PC...
Hi i purchased sony vaio vgn-n21m notebook about a year...
Dell Latitude D600 PC Notebook
Ok our laptop worked Sunday night; Monday morning before...
PC Laptops
I have used Memorex dvd+r discs to do my back up on, what...
Acer Aspire 3680 Laptop/Notebook 80GB...
I get a msg. that ISATAP driver software...
Loading problems.
Repair Service
Find PC Laptop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
