Question about Ionic Pro TURBO Air Purifier
IONICPRO TURBO IT KEEPS ON GOING TO THE CLEAN MODE.I HAVE CLEANED IT 8 TIMES.IT KEEPS ON GOING TO THE CLEAN MODE
  • 7 more comments
  • amhw May 24, 2008
    We just bought the Ionic Pro Turbo last night... and the light keeps going to clean..... It is getting frustrating... does it really need to be cleaned that often?
  • Anonymous Jun 17, 2008
    When turned on it goes to clean.
    I have cleaned and cleaned no help.
    Gary Ison
    GEIson@Ameritech.net
  • ubu20 Jun 21, 2008
    Mine does the same thing, keeps going to "clean". I wrote to the company and the answer I got was instructions on how to clean it, after I told them I already cleaned it. No help there!
  • henr7746 Aug 19, 2008
    Ditto to everyone above e've had ours less than 1 yr. Now all we need is someone to tell us how to fix it. Other than to buy a new one!
  • Anonymous Oct 04, 2008
    After cleaning the turbo and placing brand new blades in the machine, it continues to go to the clean mode.
  • mcalinj Jan 28, 2009
    The blades are sparkling clean but when you turn it on it goes to High and then immediately to clean mode.
  • NickNickname Feb 12, 2009
    The blades are clean but when you turn it on it goes to High and then immediately to clean mode.
  • jrerwin3 Feb 28, 2009
    same here trying to fix it right now
  • Anonymous Mar 02, 2009
    Mine shuts off and the blades are clean... Ionic pro charges delivery fee and gives you a use model back... I would never buy from this company again!
I had the same problem and was about to open the unit up to see if I could adjust the sensitivity of the "clean light" trigger. Yeah yeah I know.. high voltage and all... but I'm an electrical engineer (which means I would know exactly what killed my dumb-a$$ after the fact). While looking I discovered a separate set of contacts under the swivel door. That is to say, unplug the unit, open the door, and remove the metal filter part (the thing you clean) according to the instructions. Look just below the lower part of the door (in between the door and the case) and you'll see a metal post and another metal tab. When the door closes, the two make contact which completes the circuit. In my case, they were covered with dust. I took some long Q-tips and cleaned them off and the unit started working properly again. There may be other things to clean along the circuit, but I believe that this is a step that should be done each time you clean the filter. Good luck.
Posted on May 20, 2009
  • JoeBrewski Apr 29, 2011
    Underbite - I just bought one of these and it had the same symptoms you note out-of-the-box. Your solution 're: the tab and post' worked (for half of it, THANK YOU :) ). Prior to that it would not stay on for more than 5 minutes, period. Anyhow - The other 45% (it will now run for 4 or so hours and then shut off) - (1) Unplug, (2) Plug it back in and restart with a reset (hold down the power button for 15S before releasing.
    So in short, for those others in hell, a compilation: 1. Clean the blades, blahbladblah as they tell you 2. Clean the posts and the visible blade contacts with rubbing alcohol 3. MOST EFFECTIVE portion - Per Underbite's note, scrub the hell out of the 'hidden tab and post' underneath the swing door with a swab and rubbing alcohol (mine was more than a little dirty apparently coming out of the factory) 4. Clean the ionizing wire by-hand with rubbing alcohol. 5. Reset by holding down the power button for 15s or so when putting it on High. I just bought/received one of these by the way two days back, it was like this fresh-out-of-the-box - GOOD TIMES.
    Joe
Same problem here. The blades are sparkling clean and it goes directly to clean mode, seconds after I turn it on.
Posted on Jul 11, 2008
I think the unit is defective i git the same problem and keeps goin back to clean mode even the blades were just cleaned
Posted on Jun 13, 2008
  • Reedy1 Oct 29, 2011
    Breath hot air
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
Don't use water use a tissue
Posted on Oct 29, 2011
I just bought one a couple horus ago and same thing, I assume its defective I'm going to return it
Posted on Nov 10, 2008
I have had the same problem and its frustrating me.... I dont know what to do !!!
Posted on Oct 28, 2008
I have cleaned the blades but it keeps telling me I have to clean it and will not work.
Hi mystic9491,
I work for the Ionic Pro company. Make sure you are cleaning the ionzing wire too. Is that does not work, please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Feb 03, 2011 | Ionic Pro TURBO Air Purifier
Air purifier keeps making a noise even after we cleaned it several times and left it out to dry several hours.
Hi janandvince,
I work for the Ionic Pro company. Please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Dec 08, 2010 | Ionic Pro TURBO Air Purifier
I have cleaned my ionic pro several times works for a few minutes and then says clean again what can I do?
Please call customer service for Ionic Pro at 800-875-8577. They will provide troubleshooting instructions and if they do not correct the issue, they will give you instructions on how to get your unit replaced. Thank you.
Feb 08, 2010 | Ionic Pro TURBO Air Purifier
Buzzing sound
you need to turn it off and remove plates,put in kitchen sink and spray with windex and dry with paper towels, now clean the bottom of the three plates too.
before you reinstall the plates look down inside you will see three thin lines of metal,make sure there is no lint or dust on them,reinstall and let set for five min. to allow any windex that might still be wet then turn on low for a couple of min.then go to medium
Dec 24, 2009 | Ionic Pro TURBO Air Purifier
Repair an Ionic Pro
Here is the PDF manual. http://www.ionicpro.com/pics/ip_manual.pdf
Oct 24, 2008 | Ionic Pro CA200 Air Purifier
Ionic Pro Turbo
When you turn on it goes to clean but unit has been cleaned.
Dec 25, 2007 | Ionic Pro TURBO Air Purifier
Ionic Pro TURBO Air Purifier Logo
1,813 people viewed this question
Top Ionic Pro Air Purifiers Experts
Paul Cox
Level 1 Expert
Shehu Pro
Shehu Pro
Thomas Perkins
Thomas Perkins
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
