Question about Frigidaire Refrigerators
The compressor recently went out on a 4 year old fridge, model frs26lf8cwi, and was replaced under warrenty. Still under warenty but has quit cooling again
    Brigadier General:
  • 6,966 Answers
Although the possibility that the new compressor just died likewise, it is more probable that there was a leak and the refrigerant has just evaporated. The leak could have originated in the new joints of the tubing from the new compressor to the old system. No refrigerant would result to no cooling even if the compressor is running. Sounds like another service call to the same group of repair persons who did the initial repair.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 18, 2008
My fridge freezer is less than 2 years old and the freezer is not working could it still be under warrenty?
If your fridge is self defrosting then you probably have a stuck defrost timer motor/switch. I can usually be found on the bottom of the front ourside of the fridge. You can try to advance it with a screw driver until you hear a click and once you do hear that click the fan and the compressor should turn on. Ifthey do then you will need to have the defrost timer replaced. After two years I doubt it is in warrenty. The only things that should be in warrenty is the compressor and all of the related tubing in the hermedically sealed unit..
I have had this problem many times and since I am a retierd HVAC engineer I was able to fix these defrost timers, mainly the actual motors that had dried bushings. You would first have to take the timer apart and get into those bushings and use a small amount of a good light oil like 3 in 1 oli. That usually does the trick.
Hope this helped you. If it did then would you please let me know, I would be courious to know.
Good luck,
Jun 26, 2014 | Beko Fridge/freezer Thermostat Genuine...
Kelvnator fridge motor clicks on and off repeatedly but not cooling it comes on roughly every 3 mins for about 4 seconds then clicks back off again. This fridge is over 20 years old and I'm not sure...
20 Years is a long time and we need to suspect quite a number of components. It is possible that the compressor is quiting as it overloads and then restarts when as the temperature is not maintained. Please check the capacitor to the motor, check the relay . Also if the pressure switch is faulty it can cut off. So a full check up starting with the compressor , the gas pressure and the electrical switching relay must be confirmed.
Sep 29, 2011 | Kelvinator KBM5100MB
Hi, my Hotpoint ff200e fridge freezer is cooling but not freezing, compressor wires are warm and compressor itself is quite warm, top fridge is not cooling enough, then the lights on control panel start...
Hi.. feel the dividing rdge between fridge and freezer.. is it warm?.. chances are that the little fan at the back of the fridge freezer that helps cool the compressor, has snagged own it's own wire... it's a weak fan, like you get in a computer, but it does a lot of work.. without it, the coolent does not do it's job, which results in your device not cooling things properly
Apr 24, 2017 | Hotpoint HTM17BBSSA Top Freezer...
Sounds like the fridge is running but it and the freezer are not cold
if compressor running and no cooling, sounds like a gas problem. if compressor is v hot to touch as in you couldnt hold your hand on it def gas.
unless under any kind of warenty i would recomend a new fridge
Sep 23, 2010 | Refrigerators
The fridge is not cooling,no fan noise but light on
Make sure that the compressor is working, You will need to take the fridge out and check the compressor motor for the start up on switch on > If not check the starter/contactor which could be defective and fitted to the motor. replace if faulty. Use a clamp tester or get help to finalise on this observation. Use a multimeter for checking for the voltage to the fan also. It might be possible that some rodents could have biten off your wires while you were out. so lets hope this is possible and so take a good look inside. If not check your compressor, starter. Good day
Aug 02, 2010 | Liebherr KIU 1640 Premium Compact...
My kitchen aid (5 year old)fridge keeps quitting--no cooling.
Please change it Compressor because The pump of it compressor is not working properly
Apr 13, 2010 | KitchenAid Architect KBRA20ERSS Bottom...
Maytag french door fridge crapped out....again
buzzing sound comes from freezer fan or ice maker fan. They are located behind the freezer rear wall. These freezer fan cools the freezer and the refrigerator. The ice maker fan supply air to ice maker.
Jul 22, 2009 | Maytag MFD2560HES Bottom Freezer French...
Fridge not working properly
Your compressor has most likely gone out or you have had a freon leak. I would say the compressor is the culprit. You need to have a appliance company come out to make sure, hopefully it's under warrenty, if not, it's usually better to buy a new fridge than to fix it. It's usually more expensive to fix old fridges than to just replace them completely.
Aug 25, 2008 | Samsung RS2630SH Side by Side Refrigerator
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Nov 08, 2007 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
46 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
